Question about Cameras
Shutter sticks i have fuji 4.1 mega pixel camera that the lens acts like it get ina bind iv'e tried compressed air to blow out any trash but it still sticks
5 Suggested Answers
StuartB
  • 807 Answers
SOURCE: I have a FinePix Fuji
You don't say which camera model it is.
Probably an option to format it somewhere in the settings.
Switch it to the mode where you view/erase pictures and look for it there.
Sometimes you get option to erase1, erase all, format card.
Posted on Mar 26, 2008
  • 18 Answers
SOURCE: Lens plastic cover little sheets wont open.
I need to remove front cover and look for an obstruction or possible substance spilled or splashed in camera. N/C for estimates! www.flcamerarepair.com Art Schneider (40 years exp.)
Posted on May 09, 2008
SOURCE: cybershot sony 7.2 mega pixels optical zoom 3X-
i'm having the same problem!! I'd like to know what to do to fix this issue.
when i turn it on "turn the power off and on again" and it says it over and over again when i do it.....the lens doesn't come out anymore . It can show my pictures but thats it.
Posted on Jun 25, 2008
t00nz
  • 4738 Answers
SOURCE: have canon Powershot A75 3.2 Mega pixel camera .. Now it is having display issue. Once i open my camera lens come out power come but unable to see the image in lcd to shoot.. Can you assist
First try pressing the DISPLAY button. If that doesn't fix it then this sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on May 17, 2009
t00nz
  • 4738 Answers
SOURCE: its shutter is not opening
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Posted on Dec 20, 2009
Lens will not extend, gets LENS error
Hi
Thanks for using FixYa. To start with try to blow compressed air around the lens cover so that if there is any dirt it cleans if off. You can also stick a thin strip of paper between the lens shutter and the outer support ring & move it in a way that it clears the debris that's stuck in there. If still the issue is not resolved then you'll have to replace the lens assembly & lens mechanism to fix this issue. It is recommended to be done by a professional. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 16, 2010 | Canon PowerShot G5 Digital Camera
Not able to take picture. Camera turns off ,lens will not retact..
Hi
Thanks
Rylee
Sep 15, 2010 | Olympus FE-170 Digital Camera
Lens error
Hi
Thanks
Rylee
Sep 15, 2010 | Nikon Coolpix S210 Digital Camera
I WANT TO SEND 11 PAGES OF A DOCUMENT BY EMAIL HOW CAN I MAKE IT SMALLER
Turn down the picture quality and it will require less memory
Example 10 mega pixel camera
change it from 10 Mega pixel to 5 mega pixel
Mar 07, 2010 | Fuji FinePix 2600 Zoom Digital Camera
Power Shot A620 Canon 7.1 mega pixel 3 years
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
Dec 30, 2009 | Canon PowerShot A620 Digital Camera
Fuji E900
Try the video function.
If this works fine then it is most probably the shutter sticking.
To confirm the shutter is sticking turn the camera on, put the zoom to full optical and turn it to face you so you can see into the lens. Watch the inner part of the lens when you take a picture. You should see the shutter fire across the lens. Lines on pictures or over exposed pictures are caused by gaps in the shutter or the shutter failing to fire altogether.
Moisture residue on the shutter leafs is the common cause for this problem.
Some people on here have their own views about what causes lines on photo's. Someone even said digital cameras do not have a shutter and problems were due to software issues....
I have dealt with 100's of different models, including Fuji's E900 and always have found moisture residue to be the cause.
Dec 11, 2009 | Fuji FinePix E900 Zoom Digital Camera
My F470 Fuji Fine Pix takes stripey pictures but when it is in movie mode it is fine
Your cameras shutter is sticking. lines on photo's or over exposed photo's are due to the shutter not closing completely over the lens.
Video is fine because it does not use the shutter.
The shutter will require cleaning.
Oct 29, 2009 | Fuji FinePix F470 Digital Camera
The camera goes on but lens error appears on sscreen and the lens does not protrude out. shutter is half open
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Nov 23, 2008 | Nikon Cameras
Lens error
Place the camera flat on its back on the kitchen table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Mar 24, 2008 | GE A730 Digital Camera
Lens cover jamming
Try blowing lots of compressed air around the open lens shutter to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Also with the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. A grain of sand in the mechanism is usually the culprit, and you want to try to dislodge it.
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and it will void your warranty):
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Aug 28, 2006 | Samsung Digimax 250 Digital Camera
Cameras Logo
29 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
