How do I repair a VCR tape? My vcr chewed a special video taken in Ireland and I can't replace it.
  • 55 Answers
You could cut of the damaged part and use thin clear office tape to mend it.
Place the ends overlapping and cut with sharp carpet knife or with scissors.
I have repaired quite a few tapes succesfully.
You will lose the damaged section of the content on the tape.
Posted on Sep 30, 2008
Awia HV-FX7500K has started to chew the vhs tape & Now everytime you place the VHS in the VCR it reads and ejects it within 5 seconds.
The biggest cause of that is a worn pinch roller. Replacement is the only cure. You could take off the top cover and watch an old tape being inserted. You will soon see where the tape goes wrong.
Sep 18, 2014 | Televison & Video
How do I stop the vcr chewing tapes?
Probably bad drive belt need replacing.
My player eats the vcr tapes!
It is most likely that the pinch roller will need replacing. Once these become glazed (shiny) the tape slips over them, resulting in 'chewing' as the edges of the tape ride up or down the capstan shaft and into the top or base 'rabbit' of the exit guide nearby. Replace the roller, clean the tape path (capstan, guides, heads, take up arm, etc., *gently of course*) with alcohol solution or methylated spirit - do not use q-tips to clean the drum.
VCR should be OK after that. No further repair should be necessary here, and rubber pinch rollers for VCRs are not expensive to order as a generic part for this model.
Mar 02, 2011 | Sanyo DVW-5000 DVD Player/VCR
Why is my vcr chewing up tapes
The answer is easy take the top off the unit, and with an old video tape try it and watch what the video does. This is the only way really as the causes of tape damage are many, including objects that have got into the works. The only tape chew fault that can be put down to a single thing, is the crinkle bottom or top edge. Which is caused by the pinch roller being worn.
Once you see what it does you can post again and describe it, we are FixYa should be able to pin it down.
Feb 03, 2010 | Philips VR750 VHS VCR
Video tape will not eject
Try removing the cover from the VCR. Make sure the plug is removed!!! Wouldn't want you to get a whack of 240 volts. The tape is probably snagged in the reel.You may have to cut the tape to remove it as it will be probably chewed. Before you screw the cover back on to the VCR. Plug the VCR in, and then try to insert a 'new' tape. (perhaps a cartoon tape or one that is of little value to you will be in order, as you don't want to wreck another tape of value). Make sure the tape plays and ejects correctly before replacing cover. If not try and locate the problem, remebering that the VCR is still plugged into the MAINS! Be careful. I reckon the tape is just twistyed on the reel though.
Good Luck.
Hughie.
Jun 02, 2009 | Televison & Video
Tape chewing
use a vcr cleaning tape.
Feb 18, 2009 | LG XBR446 DVD Recorder/VCR
Tvcombi
You need to send it to a repair center because the problem might be a bad idle on the vcr deck player ,and you can not be able to fix it.Good luck.
Jul 25, 2008 | Televison & Video
Picture is snowy and isn't clear
If you are using the RF out to connect to the VCR to your TV, perhaps the connecting Cable is faulty? And if you are connecting the VCR using the Audio Out / Video Out Cables, try replacing only the Video Out cable. In 95% of the cases, it is only the connecting cables which go faulty. If the above solution does not solve the problem, then we consider options. How old is the machine? if it is more than 5-6 years old, you need to get a service done. For chewing of tapes, 99% of the time it is a bad Pinch Roller(it is big (approx. 1 inch high. on the right side of the mechanism assy.)replace, and your chewing problem will go away.
Sep 29, 2007 | Sanyo VWM-900 VHS VCR
This model is the W528 VCR, but my manual includes both models
Does it do this with other television sets? If so, then it indicates the problem resides in the VCR. Rolling as you describe suggests either the VCR isn't producing a clean enough vertical sync pulse in the video signal, or the TV circuitry isn't processing the pulse properly. First, try cleaning the heads (not just the video head, but also the audio/control head which is to the right of the rotating video head. If this doesn't fix the problem, an electronic problem is likely. Unless this is a high dollar unit, repair is not recommended, as VCRs of the last 10 years or so are essentially disposable. I've done some looking on the 'net regarding copy protection, and it doesn't look like this is an issue here.
May 02, 2007 | Toshiba W522 VHS VCR
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
Electro Med Services...
