Question about Apple iPod MA446LL/A MP3 Player
No Battery power remains connect ipod to power
Hi
I have a 30gb video ipod (5th Gen I think).
Bought it from ebay.It worked absolutley fine but I did change the battery.
I synched it with my PC and transferred my music on to it.
I think I may have unplugged it while it was charging.
Now, although the battery is full, the Ipod keeps dying after a few seconds ofplay and then just displays the message" no battery remains connect to power. What can I do to fix the problem?
regards
H
  • monster pod Dec 22, 2008
    Thanks for that, I'ver tried the solution but I think the hard disk has gone as well now. thanks for all your help.
  • pingp May 11, 2010
    So did you replace the battery yourself?
    and if you did, did this only start happening after the battery was replaced?
    Jaxon
    Scholar:
  • 42 Answers
Sounds like your battery circuit is not working properly. Since you have opened it before, open it again and check to see that the little plug where you put the battery tab in is pushed down to make a good connection. Sometimes the plug connector is in the up position and needs to be gently put back down to have good contact.
You could have also messed up the battery connector when you disconnected the first battery to change it. Sometimes that happens if too much force is used. I use a pair of tweazers to just gently pull the battery tab out of its plug. I also use the tweazers to gently push it back in without moving the connector up and down.
You could also have a bad battery. Have you tried putting the old battery back in to see if that works.
Hope that helps.
Posted on Dec 19, 2008
In trying to replace battery I severed a cable that appears to go to the disable switch. Switch was on orange so now I can not turn Ipod on. Is there a fix?
always be careful when opening electronics; you should know or at least have an understanding of basic locations and wiring. i can tell you for sure; solder the cable back to where it was connected and you should recover power. note the cabe may be insulated so just twisting both end together might not work. you need to remove the insulation before you reconnect both ends.
Apr 10, 2016 | Apple iPod MA446LL/A MP3 Player
Head unit connot find ipod
hmmm..does the Ipod that works, have same version as the one that does not?
Mar 10, 2008 | Alpine CDE-9881 CD Player
How can I use JVC AVX810 with Iphone? Currently IPOD works fine with the USB cable but IPHONE is not recognised. Maybe there is an adaptor that can solve it?
JVC KS-PD100 iPod Interface Adapter (257KSPD100, sold separately). This optional iPod Interface Adapter supports audio playback for the following iPod models - iPod click-wheel (3rd gen), iPod photo (4th gen), iPod mini (1st/2nd gen), iPod nano (1st/2nd/3rd/4th gen), iPod video (5th gen), and iPod classic (80/120/160GB). The KS-PD100 is not compatible with the iPod touch (1st/2nd/3rd gen), iPod nano (5th gen), or iPhone (2G/3G/3GS). This iPod interface will also not charge the iPod nano (4th generation). *Apple firmware updates may change functionality results.
There u go.....
Jan 29, 2010 | JVC KW-AVX810 Car DVD Player
I want to know which generation is the Ipod 30G model A1136, thanks
There are two 5th gen iPods, A1136 model is the older 2005 model, not the later 2006 model.
Here is Apples link: http://support.apple.com/kb/HT1353#ipodfifth2 which will show the differences, but not by model number. The reason I know this model number is the first 5th gen 2005 is because I have one. Also older 2005 should have '2005' engraved on rear.
May 29, 2009 | Apple iPod classic 5th Generation
IPOD 30GB Video 5th Gen will not Power ON
sadly it's dead...go to apple.com and buy a refurbished unit or ebay.
Apr 03, 2009 | Apple iPod MA446LL/A MP3 Player
30GB 5th gen ipod video does not play any songs
I have had the same problem on my sisters ipod. Unfortunately I could not fix it. You can take it down to the apple store and have their genius bar look at it, even though most of the time I know more about ipods than they do they will at least be aware the problem exists. I pulled the hard drive out and put it into another iPod to test it. The hard drive is fine. My best guess is that a transistor or something on the circuit board went bad and is not allowing for that function. What I did was sold it on eBay as broken for $86 bucks. I then went to apple.com/store and scrolled to the bottom left of the page and they sell refurbished ipods that appear new with the same warrenty as a new one. We bought my sister a 80GB classic for $179 minus the $86 we got from the broken one. It was nice to have the new one for less than a $100 total. It's either that or find someone that knows how to replace the circuit board which costs around $70 bucks used. Good luck.
Aug 20, 2008 | Apple iPod MA446LL/A MP3 Player
IPod White - 2005, 30GB, A1136A, Generation 5th
No there is no heat associated with this rainbow affect.
Jun 19, 2008 | Apple iPod MA446LL/A MP3 Player
Full operation from D3?
I think you need an Ipod adapter, for sale on Ebay from $35 to $50. It is a module not just ibus to Ipod cable.
Feb 19, 2008 | Pioneer AVIC-D3 Car DVD Player
IPod Battery
You should try using a different USB cable and connecting to a different USB port and seeing if the problem persists. If it does, the problem's probably with the iPod's logic board.
Jan 01, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod video 5th gen issue with downloading music
You should try using a different USB cable as it's very possible the cable is damaged. If that's not the problem, the logic board is probably defective and you can either replace it if you're comfortable enough opening your iPod or sell the iPod listing the defects on eBay.
Dec 08, 2007 | Apple iPod MA446LL/A MP3 Player
Apple iPod MA446LL/A MP3 Player Logo
506 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
