Question about Canon imageRUNNER 3300 All-In-One Laser Printer
I am receving error code Eoooo64
I am getting this code when i use 2 sided copying. This problem does not arise when i use single side copying.
I have canon irc2100. colour dust is also printed with the material on the page, plz send me solution
Posted on Nov 06, 2008
How can I print single sided copies?
There should be a copy options button on the screen (often the left hand side). If you are copying a double sided page to make single sided copies choose 2 sided to 1 sided.
Or if you are copying 1 sided to 1 sided, make sure this option is selected (it is usually the default). Hopefully this helps!
Mar 21, 2017 | Office Equipment & Supplies
Kyocera Taskalfa 552ci will not copy single sided. 0800 Jam but will so may other functions...
the service manual says to replace the main pcb before you do this try to upgrade firmware even if it is current or try a different ADF the DIMM could be the problem if the board has 1 try cleaning the contacts with an eraser welcome to Kyocera repair
Mar 07, 2017 | Kyocera Office Equipment & Supplies
Error code E000064-0000
E064-0000 Description The presence of a high-voltage error is communicated by the composite power supply PCB (The output for primary charging, developing, or transfer has deviated from a specific level of voltage) Causes The contact has poor connection. The wiring is faulty. The composite power supply PCB is faulty. The DC controller PCB is faulty. proce Remedy 1. Contact Is any of the contacts of the primary charging roller, developing assembly, or transfer charging roller soiled? Or, is there poor contact? YES: Clean the contact, and set it once again. 2. Wiring Is the wiring between the contacts for the following normal: DC controller PCB (J301), composite power supply PCB (J136), primary charging roller, developing assembly, transfer charging roller? a. DC controller PCB (J301) <-> composite power supply PCB (J136) b. composite power supply PCB (J130-7) <-> primary charging roller contact c. composite power supply PCB (J130-1) <-> developing assembly contact d. composite power supply PCB (FT133) <-> transfer roller contact NO: Correct the connection. 3. Composite power supply PCB, DC controller PCB Try replacing the composite power supply PCB. Is the problem corrected? YES: Yes. NO: Replace the DC controller PCB
Nov 19, 2014 | Canon Ir 3300 Black & White Copier
Bizhub C652 has horizontal lines.
its important to find out whether the \'lines\' are in scan direction/ or only through Radf or only from scan glass,
if the lines are only showing when documents are fed throught the Radf, then the problem lies with the document scan plate( left of the main glass platen (about 2" in width)) or with the scan plate blade cleaner
if the lines ONLY appear when copying from the Glass then the issue lies within the optics (probably nothing more than a clean will be needed)
another question would be to ask if the lines are solid (black line overprinting image) or if they are \'missing\' lines where the image has failed to copy, sometimes it can be hard to work out which side the fault lies,so try shaded greys as a copy original .
if the scan lines are appearing on both Radf and Glassplatten ,mode then the issue may be dirty optics/ccd sensor or it could e an indication of the ccd failing or image control pwb in error while interpreting the image file.
what to do
1) place a grey sheet of paper in the Radf and have the copier photocopy both sides of the original and print to single sided sheets ( so the printer turns the original over to complete the task)
observe the result.
2) have the copier photocopy directly from the platten glass- single sided.
observe the result.
ckeck to see if the error has appeared on both sets of prints ,
if the error has only appeared in the first set of prints then the issue may be a tiny DOT on the slit glass (left of platten) - a dot on this glass will indeed appear as a Line as the original is scanned across the glass.
hhope thhis helps
Feb 19, 2014 | Konica Minolta Bizhub C652 Color&b/w...
Duplex copying on xerox phaser 3300mfp
I have the same problem and was told by the telephone helpdesk that the machine cannot copy double-sided to double-side. The duplexing referred to is copying 2 single-sided documents onto one single sheet on both sides....Like whoever does that! This is misleading on Xerox's part . Colin B.
Jul 08, 2012 | Xerox Phaser 3300Mfp/X Mono P/C/F/S 30Ppm...
How do you scan a double sided document?
You put your papers into the document feeder, then on the LCD screen there is a button that says 2 sided. Touch that button and select what you need. If you have a bunch of single sided pages that you want 2 sided then select 1,1-2. If you have a bunch of double sided pages that you need copied then select 2-2 and then puch the copy button.
Oct 11, 2011 | Sharp MX-2700N Color Copier
I wont you to help me as to how i can make a photocopy using my canon ir 3100cn machine. than you
have you ever operated a copier? it,s so simple place the originals face up on the DADF. SELECT the no. of copies. there will be option available on display for selecting whether you want B&W or color copies like b&w, auto color, full color etc. there will be copy ratio button for zoom(25%-400%). Now press start button.
For two sided copying press "two sided". There you will have mainly two options (i) 1>2 sided:- converts two single sided documents in to a two sided copy (ii)2>2 sided:- converts a 2 sided document into a 2 sided document. normally both will be done in book type for normal orientation.
Apr 11, 2011 | Canon iRC3100 Printer
Single copy out of double original w/o using paper feeder
Does your machine have double siding capabilities?
If so on the control panel under original / copy. select 1:2, this will give you a double sided copy from a pair of single originals even off the glass.
Jan 13, 2009 | Minolta DI2510 Black and White Copier
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
old marine
old marine
