Question about Acer TravelMate 4200 Notebook
Travelmate 4200 wallpaper does not "center"
I have an Acer Travelmate 4200.
At some point while surfing the web I wanted to save an image and accidently clicked "Set as background". Since then whenever I use a wallpaper, it sets the wallpaper completely off centre in the top left corner of the screen - as if the laptop sees the screen as being alot bigger than it really is.
I used to be able to fix this - it would re-center by changing the screen resolution to something else then back again, but only within the Intel Graphics Accelerator program - doing the same with only the screen properties panel did not move the picture at all.
I've tried re-installing screen drivers to no avail. Even with the Intel Graphics Accelerator program uninstalled, it still moves the wallpaper to the top-left of the screen, only now I have no way of putting it in the center again.
I've also tried changing the screen resolution under the screen properties panel, advanced, adapter then "List all modes", but no luck there.
I suspect active desktop might have someting to do with it, but have no webpage syncronized with the desktop.
Any advice would be greatly appreciated!
  • GuiltySpark Sep 30, 2008
    Would you believe 10 mins after posting this I found a solution?
    In registry - 2 values: WallpaperOriginX and WallpaperOriginY
    Both had values of '-200' or lower, I changed both to '0' and the wallpaper is now actually centered.
    I'm still curious why they would be altered in the first place...maybe mozilla thinks I run a dual-screen desktop?
How to use zedge on my iphone 5s as ringtone or wallpaper
For wallpaper
  1. To change your iPhone wallpaper (either one; the process is the same), start by making sure you've got the image you want to use on your iPhone. You can get the image onto your phone by taking a picture with the built-in camera, with Photo Steam if you use iCloud, by saving an image from the web, or by adding photos to iPhone from your desktop.
  2. Once the image is on your phone, go to your home screen and tap the Settings app.
  3. In Settings, tap Wallpapers & Brightness (this is the iOS 7 name. If you're using an earlier version of the iOS, it's called Brightness & Wallpaper).
For ringtones
  1. Download the ringtone
  2. Save the file
  3. Transfer the file to your phone via iTunes
Jan 06, 2014 | zedge.net Computers & Internet
Cmos battery acer travelmate 4200
most times the battery is located under the ram chips
there is also 2 pins that can be shorted together that will reset the bios password if you cannot see the battery when opening the ram door.
please rate my help++++Thanks for using FIXYA
May 07, 2010 | Acer TravelMate 4200 Notebook
Need a hard drive for my acer 4200
You can buy that to the acer center or you may browse the manufacturer website and search your laptop model. Or you may buy that in ebay go to www.ebay.com
search your laptop model and the battery compatibility.
Apr 01, 2010 | Acer TravelMate 4200 Notebook
Can a laptop screen be replaced
The screen can be replace, there are several LCD screen suppliers on the internet.
I found LCD Parts very satisfactory - click on this link to their WEB site :-
www.lcdparts.net
Dec 26, 2009 | Acer TravelMate 4200 Notebook
How do I re-format Acer 4200 TravelMate hard drive?
Windows Reinstallation Disk option:
Insert Windows Reinstallation disk into tray, Boot to CD/DVD-ROM by pressing F12 at initial boot screens, delete existing Windows partition, re-create partition, and then follow steps to reinstall Windows. This will lead you to an option for formatting hard drive. I recommend choosing the full format versus the quick, from this point you can let windows install, or just shut the computer down when the format finishes. You will have to watch the progress, though, if you don't want the install to commence.
Boot disk option:
For XP, 95, 98, or ME, follow the instructions at this MS article page. It will walk you through creating a boot disk that will allow you to format.
You will need a floppy disk or CD
Apr 03, 2009 | Acer TravelMate 4200 Notebook
Travelmate 4200 touchpad mouse doesn't work.
go to the computer hardware point or servicestation.
Mar 06, 2009 | Acer TravelMate 4200 Notebook
System restore stopped working
Hello, Troubleshoot System Restore:
Some common problems that could cause System Restore not to work properly and their solutions include the following:
• There is less than 200 MB of free space available on the computer—free up some space on the hard drive by deleting unused files or images.
• After rebooting, the restoration is unsuccessful—choose an earlier restore point and try again.
• Restoration was denied due to non-administrator status—log out and then back in as an administrator.
• The System Restore Service is not running—Open Administrative Tools, click Computer Management, and then click Services and Applications. Click Services, and double-click System Restore Services from the list. Verify the service is started and running. If not, under Service status, click Start and change the startup type to Automatic.
*Your vote is highly be appreciated. Thanks in advance. I hope this helps you. Drop me a comment if you have questions. I will assist you.
Dec 28, 2008 | Acer TravelMate 4200 Notebook
Screen is dark and needs to be brighter
look on your keyboard for the key with the 'fn' meaning function and then press the up arrow key on the keyboard. This will make the screen brighter this happens when you are on your battery to save power. You can also do it manually by accident.
Dec 04, 2008 | Acer TravelMate 4200 Notebook
Acer 4200 travelmate laptop
http://www.eserviceinfo.com/index.php?what=search2&searchstring=TravelMate+4100%2C+4600+series
go there you will find the service manuel in .rar compressed file !
go winrar.com or winzip.com to get the decompression software!
you might want to buy that power jack on ebay if its not done yet !
make shure you use a magnetic bracelet not to burn the laptop with static electricity!
Jan 13, 2008 | Acer TravelMate 4200 Notebook
Acer TravelMate 4200 Notebook Logo
71 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
