Question about Intel D845GVSR Motherboard
Window frequintly restart winxp sp2
  • gary wittingslow May 11, 2010
    how many ram sticks?
    any questionmarks in device manager?
    should be a ram or driver issue
    try 1 stick of ram only if you have more than 1 installed
    Scholar:
  • 76 Answers
I agree with bundyguru could be RAM. I have seen crazy problems with RAM. I also agree to minimize hardware and try to isolate the issue. (if you are comfortable in doin so)
Posted on Oct 01, 2008
I have ASUS WL-167G v3 Wireless USB Adapter. It works well with my MacBook but when I connect it to my WinXP PC, it detects the two networks that I have in my house, but does not connect to neither. Both...
You mentioned that you have Windows XP SP1... You need to install at least SP2 or even SP3 for this adapter to work. If this computer doesn't have internet access at all, then you can usually get SP2 or SP3 on a disc for free from Microsoft.
Feb 28, 2011 | ASUS Computers & Internet
Tip
How to change your winxp sp2 to sp3
there is some games you can't play in winxp sp2, like gta IV online.
you have to reinstall or format your computer just to turn your operating system in winxp sp3, just to play this game. do'nt waste your time to format or reinstall your hard drive just follow this quick step
Step 1: Run Regedit by Clicking on Start -> Run , type in regedit and press enter
Step 2: Make a backup of your registry (just in case)
Step 3: Browse to "HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlWindows"
Step 4: Modify the value of "CSDVersion" from "0x00000200" (SP2) to the Windows XP SP3 value of "0x00000300"
Step 5: Close registry editor
Step 6: Reboot
Step 7: Start GTA and freakin enjoy it already!
on Jan 16, 2010 | Microsoft Windows XP Professional SP2
Screen goes blank after booting with WinXP SP2 CD.
Hi, your will need to delete your windows XP re format that part of your hard drive, then re install XP
Jul 04, 2010 | Microsoft Windows XP Professional SP2
E-machine C2881 runs good with winxp sp1 hang winxp sp2
Press F8 repeatedly after turning on power and select safe mode. Then go to ctrl/panel - add/remove apps and remove sp2. Reboot.
May 16, 2010 | FIC Crusader VC37GV (73-40682-00)...
Windows XP SP2 Repair
Solution: Rename the C:\WINDOWS\SYSTEM32\CATROOT2 folder to something such as catold to prevent WinXP's Setup program from locating the folder and halting the installation. If you are still in Setup, press SHIFT-F10 to launch a command prompt from within Setup. At the command prompt, type cd\win dows\System32 to open the System32 folder and then type rename CATROOT2 catold, press ENTER, restart the computer, and attempt the upgrade again.
If you cannot reach a command prompt from Setup, reboot the computer from a Win95, Win98, or WinMe startup disk and rename the folder from the command prompt. You can also launch a command prompt by booting from the WinXP installation CD and running the Recovery Console.
Mar 25, 2009 | Toshiba Satellite 5105-S501 Notebook
HOW INSTALL XP-SP2 I COMPAQ PRESARIO CQ40-133TU
before installing device manager and write down drivers for
display
audio
video
network
then with cd in drive while pressing f7 restart then choose option cd dvd\cd press enter follow instructions
will ask to delete selected click to delete read all instructions it will confirm deletion then once it returns to a selected
then continue winxp will install
Feb 01, 2009 | Compaq Audio card Sound Card
XP RESTARTS
this is caused because a file of your pc has become corrupt and your XP needs to be reinstalled.
Dec 31, 2008 | Microsoft Windows Xp Home Edition Sp2...
Integrate SP2 in WinXP CD
Step 1
Create 3 folders - C:\WINXPSP2 C:\SP2 and C:\XPBOOT
Step 2
Copy the entire Windows XP CD into folder C:\WINXPSP2
Step 3
You will have to download the SP2 Update, which is 250MB.  Rename the Service Pack file to XP-SP2.EXE  Extract the Service Pack from the Run Dialog using the command:  C:\XP-SP2.EXE -U -X:C:\SP2
Step 4
Open Start/Run... and type the command:  C:\SP1106\update\update.exe -s:C:\WINXPSP1
Click OK
Folder C:\WINXPSP2contains: Windows XP SP2
How to Create a Windows XP SP1 CD Bootable
Step 1
Download xpboot.zip  Code:  Code:  http://thro.port5.com/xpboot.zip
( no download manager !! )
Extract xpboot.zip file (xpboot.bin) in to the folder C:\XPBOOT
Step 2
Start Nero - Burning Rom.  Select File > New... from the menu.  1.) Select CD-ROM (Boot)  2.) Select Image file from Source of boot image data  3.) Set Kind of emulation: to No Emulation  4.) Set Load segment of sectors (hex!): to 07C0  5.) Set Number of loaded sectors: to 4  6.) Press the Browse... button
Step 3
Select All Files (*.*) from File of type:  Locate boot.bin in the folder C:\XPBOOT
Step 4
Click ISO tab  Set File-/Directory length to ISO Level 1 (Max. of 11 = 8 + 3 chars)  Set Format to Mode 1  Set Character Set to ISO 9660  Check all Relax ISO Restrictions
Step 5
Click Label Tab  Select ISO9660 from the drop down box.  Enter the Volume Label as WB2PFRE_EN  Enter the System Identifier as WB2PFRE_EN  Enter the Volume Set as WB2PFRE_EN  Enter the Publisher as MICROSOFT CORPORATION  Enter the Data Preparer as MICROSOFT CORPORATION  Enter the Application as WB2PFRE_EN
* For Windows XP Professional OEM substitute WB2PFRE_EN with WXPOEM_EN  * For Windows XP Home OEM substitute WB2PFRE_EN with WXHOEM_EN
Step 6
Click Burn tab  Check Write  Check Finalize CD (No further writing possible!)  Set Write Method to Disk-At-Once
Press New button
Step 7
Locate the folder C:\WINXPSP2  Select everything in the folder and drag it to the ISO compilation panel.  Click the Write CD Dialog button.
Press Write
You're done.
Oct 19, 2008 | Computers & Internet
Class installer cannot install device A4tech webcam PK-7MAR
unplug the webcam and try uninstalling the driver first then reinstall with this driver http://www.a4tech.com/ennew/driver/CameraA.zip
then restart your PC and plug your webcam again.
It should run on WinXP SP2, Vista ang 64 bit
Jun 04, 2008 | A4tech Xmaster PK-835 Webcam
All needed drivers for WinXp.
The Toshiba website had directions for getting drivers. You will need to provide your model number and follow links to get help. Good luck
Feb 18, 2008 | Toshiba Satellite A135 Notebook
Intel D845GVSR Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
