The six disc changer on my Jaguar XK8 won't eject the disc cassette and the head read E01...any thoughts? Regards David
  • 2,071 Answers
The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
If the disc starts to spin slowly and doesn’t come up to speed, the spindle motor that’s attached to the turntable platter is a common problem. There could also be a problem with the spindle motor driver controller IC or the power supply regulator that supplies voltage to the driver IC. If the disc starts to spin and then spins really fast, or stops and starts to spin backwards, your problem is the laser pick-up assembly or the servo control circuit. If you continue to have problems after cleaning and checking the other things listed above, you may have a problem with the player's alignment. Of course, one of the problems you'll face checking alignments on a DVD/CD player is that you’re going to need to use an oscilloscope on most of them. If you have the proper tools and equipment, the first thing to look at is the RF pattern of the unit while its playing. It should be a sharp and clear pattern. If it's dull and smeared, then the laser could be weak.
Also, in these units are very critical alignments called the focus/tracking gains and offsets. When these alignments are off, it can often cause intermittent troubles. As the unit ages and parts change value, so do these alignments, and will need to be checked. In my time as service technician repairing DVD/CD players, 65% of the laser pick-up assembles I have tested were good and only needed a small adjustment. Today's technology makes it unfeasible for a shop to hook up a DVD/CD player, and even some recorders, to their equipment and make these adjustments because of the cost involved.
To clean the lens you must use very little pressure. Take a cotton swab and barely moisten it with plain, non-scented, or oily type alcohol. In a swirling motion, very gently rub the lens until you’ve covered it entirely. Then repeat using the dry end.
If the cleaning didn’t help, don’t despair just yet. You can see if there’s a problem elsewhere in the unit by using a few simple tricks and tips.
First thing you want to see if the unit’s laser is in good working order. This method isn’t foolproof, but most of the time works admirably. When you insert a disc, see if you can look up underneath where the disc sits on the turntable. Observe the laser lens going up and down. If the lens is trying to focus, that’s good! After a few seconds of the lens trying to focus, the platter should start to spin. On almost every CD/DVD unit I've encountered, the unit won't spin unless the laser has properly focused on the surface of the disc. If the unit spins up and and then shuts down, you should check and make sure the laser pick-up assembly slider mechanism is working without any obstructions and that the small chrome rail that it slides on is slightly greased. Don’t go overboard with the grease though, as too much can cause all sorts of problems
Hope it may help you;
Regards,
VOTIT
Posted on Sep 30, 2008
  • 4,234 Answers
The E01 is a mechanism error. Basically the unit is telling you that the cassette is tuck (like you don't know that already!!). What has happened is that the mechanism has jammed. No cleaning of the lens or rails or alignment will fix this. This is strictly a mechanical problem. Sometimes you can open up the unit and see what has jammed and clear it. I have seen CDs that have not seated in the carriers correctly cause this. If you can move the CD enough to seat properly, it may clear itself. If n ot, than the unit must be dis-assembled and rebuilt. This involves "re-timing" the gearing inside that may require a service manual.
The botom line is that you will need to examine the mechanism for any obvious jam and try to clear it. If you don't feel confident in doing this, please do not attempt it. You would be better off bringing the unit to a repair facility.
Dan
My CD player is reading "No Disc"
The laser has most likely failed or needs to be adjusted. If you cannot take it out and take it apart, and use small tools and a meter, replace it or have it professionally done.
Jun 09, 2014 | CD Changer Player 2000 Jaguar XK8
Jaguar 6 disc player not working
If you are getting power to the unit and you hear it clicking and making a sound when you hit the eject button, the this means that a CD is jammed in the track and while it was changing it got stuck and now causes you to see an ERROR message.
What you do is while hitting the eject button, wiggle the CD MAGAZINE up and down and side ways. This will cause the CD to fall into place and your magazine will pop out.
KennyV
Jun 22, 2012 | 2005 Jaguar X-Type
Cd player won't eject or play cd's in my jaguar xk8
The Cd loader mechanism is faulty. Replace it.
Jun 06, 2012 | NAD L40 CD Player
Cds are stuck in the changer
Hi.
Ensure that the CD changer is powered, check cable and connection.
Disconnect battery for one minute and try again.
If that does not work, disconnect battery again, and try repeatedly pressing the eject on changer while someone else connect power back.
If that does not work the changer must be taken apart to remove the disks. Disassembly involves removing external cover, and usually it is not too complex.
Regards.
May 22, 2010 | Jeep Liberty Six Disc CD Changer -...
Cd player code and ac
E01 means disc changer malfunction which usually means the cd is not inserted in the disc magazine
Dec 08, 2008 | 1999 Mitsubishi Montero Sport
Blaupunkt IDC-A09 5 Disc Changer
Hi try unpluging both the cd and the head unit from power for 30 mkins or more. this should reset the system. plug the head unit in 1st then the cd.
regards
Mark
www.blueice-electronics.co.uk
Jul 23, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Unable to eject cd magizine. Error 2
power off. open the cd changer unit. look for the motor that, when turning, performs the eject mechanism. now turn this motor by hand in the proper direction until cassette is fully ejected.
Jul 22, 2007 | Clarion DC625 6-Disc CD Changer
148 people viewed this question
 Grubhead
Grubhead
