Question about Epson Aculaser C1100 Printer
Epson C1100 Service required C0085
I'm getting a message 'Service Required C0085' can anybody tell me what the problem is?
If I restart the printer it dissapears for for a couple of hours then returns.
Thank in advance
John
SOURCE: Epson aculaser c1100 cant access empty ink cartridge.
go to the reset menu (right arrow and then down arrow until reset menu is displayed) on the lcd display and then choose change toner #(right arrow until the desired toner is displayed) Hope this helps
Posted on Oct 04, 2007
  • 7 Answers
SOURCE: Epson Aculaser C1100 - E511
The E511 error comes when you power up the printer. The noise of the "warm up" is the black rubber transfer belt on the Photo Conductor Unit spinning through one rev to check for a little silver square on the edge of the belt. You can turn the belt manually to see this square.
If this square is not found, Epson will tell you to throw away an otherwise fine PCU.
Solution:
a) Remove PCU and check the transfer belt for the square. Clean WITHOUT alcohol.
b) check the sensor that reads this square - a small black oblong "camera" in the heart of the printer on the LHS. Clean.
c) If the square is damaged, replace with a piece of tin foil. Superglue on carefully, making sure all the edges are glued but not your fingers!
You don't need to put the new square in exactly the same place, just above or below on the belt is fine.
Posted on Mar 24, 2008
  • 3 Answers
"C open" might be connected to the "B open" problem. Look here:
http://www.fixya.com/support/t452370-hatch_b_open_error
Posted on Apr 24, 2008
SOURCE: Epson rx 500 "service required"
Press on off, load expulsion, byw,color and stop all at the same time, wait until it is on. then press color and then shut down.
Posted on Jun 25, 2008
SOURCE: Epson Pro 7600 Service required error
You need to be able to clear the counters in the printer that tell the printer to stop working.
In order to do that you must
1. Turn printer off
2. you must hold down the "Paper Source, Paper Feed, Select Feed, Cut/Eject" buttons all at the sime time while you turn the printer back on.
3. From there navigate through the menues to clear the counter that pertains to you or all.
(Error 00000101 is pertains to the print head motor)
Word of warning -
Those counters can be a pain as they cause the printer to stop working however you do need to get your printer serviced by a tech as soon as you can because the error is a warning, reset the counters lets you finsih a job, but if it goes unserviced too long it will actually break down all togther.
So even after you rest the counters you absolutly must get your printer serviced soon.
Posted on Nov 21, 2008
After changing the black cartridge of epson aculaser c1100, a message flashed: Service Req E511
Welcome to FixYa, the world's largest product support community.
The message E 511: Service Required is commonly due to the Photo Conductor Unit's tabs getting stuck. So the first thing we need to do is to remove the PHoto Conductor Unit. Here are the step to remove the Photo Conductor Unit off of your EPSON Aculaser C1100.
1. Turn the printer on, and open cover B.
2. Raise the yellow lever inside cover B.
3. Remove the photoconductor unit.
4. Check the white tabs on the underside of the photoconductor unit. These are spring-loaded plastic tabs that should depress when you press and release it. If the white tabs no longer spring back you need to replace the photoconductor unit.
After removing or ultimately replacing the photoconductor unit, please follow the step by step giude on how to remove the photoconductor unit in reverse order.
Jun 09, 2011 | Epson Aculaser C1100 Printer
Get the message service required E527
E527 is the error of the home position sensor its dirty with toner you should clean it b0a512e.jpg
Oct 05, 2010 | Epson Aculaser C1100 Printer
I've a notice in epson aculaser 1100 lcd (service reg E511)
The E511 error for your Epson Aculaser  in most cases means that its motor has malfunctioned or something is preventing the motor from working properly.
Jan 26, 2009 | Epson Aculaser C1100 Printer
Service required error 511
first put away cartridge then power on .if not startuo still u have to open your prinmter back side.one tray there is your printer RAM.refix it with in its slot.
Nov 15, 2008 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 Printer Problem service required e511
Errrrmmmm, how about you tell us what the problem is.
Bloke walks into the doctor surgery and says "Doctor, help me I'm ill" the doctor asks "What is wrong with you?" to which the patient replys "You're the doctor, you tell me"!
Jul 05, 2008 | Epson Aculaser C1100 Printer
Epson c1100
Probably need a new photoconductor - cheaper to buy a new printer....
Jun 23, 2008 | Epson Aculaser C1100 Printer
SERVICE REQ. C0082
C0082= CPU error ( TLB miss exception {Load/Fetch}), requires service personell to fix.
Jun 09, 2008 | Epson Aculaser C1100 Printer
Epson aculaser c 1100
What was the service error code It would look something like Service Required E510. This show on the panel and/or in the status monitor
Without this code all we know is your printer has something wrong with it.
Sep 14, 2007 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 Printer Logo
253 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
