Correct cable for printers
What is the correct cable used for printers
What is the correct cable for RX600 EPSON PRINTER?
Posted on Dec 05, 2008
  • 30 Answers
Many printers now require an IEEE 1284 and Bi-Directional. USB cables shouldn't be longer than 15 feet.
Posted on Sep 30, 2008
Xerox printer
Depending on what port do you have on the back (or side) of the printer (USB, parallel, serial). Use the correct cable (USB, parallel, or serial cable) to connect the printer to the correct port on the computer (USB, parallel, or serial). You need to install the software driver on the computer before it will work. Google the name and model of the printer to download the driver to your computer.
Nov 09, 2013 | Office Equipment & Supplies
I have connected the cable from the printer to the lap top correctly but it still comes back saying the the laptop cannot recognise the printer. The connection was bought from Currays and I was assured it...
Hi graham_mcleo
The printer came with a install disc ( cdrom ) .
Disconnect the printer , launch the cdrom , follow instructions and wait for the driver/software to be correctly installed . Connect the printer with usb and power cables , swich printer on . Windows should recognize a new hardware and a message should pop on your screen telling installation was successfull or hardware is ready to use , depending on what system you are using .
Aug 11, 2011 | Computers & Internet
I would like to print off of my lap top HP paodion dv7-1451nr Where is the port for the USB cable ? Is there a program/Cd I need for this?
Printers do not have a standard USB port. Instead, they use a port that is a bit more square. The cable you'll need is USB one one side and Printer on the other wide. These are extremely easy to find at an electronics retailer and are commonly known as a printer cable.
Whether or not you'll need a program/CD depends on your computer. After you have the correct cable, you can try connecting the printer to your laptop and seeing if the driver already exists/works correctly. If no luck, you can use the Internet to go to Canon's website and download the correct driver for your printer. That should get things going with no Program/CD needed.
Mar 01, 2011 | Canon MP560 All-In-One InkJet Printer
Fuser error 924.01
924 .01
Open thermistor check
failure. Fuser page
count between 0 and
99,999.
• Noisy thermistor signal.
• Intermittent connection.
• Thermistor cable not connected or
thermistor actually open.
Go to “924.xx—Hot fuser
service check” on page 2-91.
Error Code 923.xx, 924.xx, and 925.xx may display for a hot fuser failure.
CAUTION: .The fuser may be hot, use caution before removing or servicing.
CAUTION: There is a danger from hazardous voltage in the area of the printer where you are
working. Unplug the printer before you begin, or use caution if the printer must receive power in
order to perform the task.
Service tip: Set the Fuser Temperature to NORMAL before starting this service check. In Diagnostics mode, In
Diagnostics mode, select EP SETUP, and Fuser Temp.
1 Fuser assembly
Fuser to system board
cable
Check the thermistor cable for correct installation to J5 on the fuser
card. If installed correctly, check for correct installation of J10 on the
system board. If all cables are installed correctly, go to step 2.
2 Fuser top cover assembly
(thermistor/thermistor cable
assembly)
Turn the printer off and disconnect the thermistor cable from J5 on
the fuser board. Measure the resistance between the two pins on the
thermistor cable, if the resistance measures infinity (open circuit),
replace the fuser top cover assembly.
3 Fuser to system board
cable.
System board
Fuser assembly
Reconnect the thermistor cable to J5 on the fuser board. Disconnect
the fuser to system board cable from J10 on the system board and
measure the resistance between J10-3 and J10-4 on the cable. If the
resistance measures infinity (open circuit) check the continuity of
pins 3 and 4 of the cable. If correct, replace the fuser assembly. See
“Fuser assembly removal” on page 4-26. If incorrect, replace the
fuser to system board cable.
Note: If the error code still displays, replace the system board. See
“System board and inner shield removal” on page 4-76.
Most likely just replace the fuser (part of usage kit)
Enter Diagnostic mode:
1. Press and hold (Down Arrow) and (Up Arrow).
2. Turn on the printer.
3. Release the buttons when Performing Self Test displays.
Mar 29, 2010 | IBM Infoprint 1572 Laser Printer
We have a 9855 Monarch barcode Printer. We are
If the printer display just shows Ready, but doesn't print, there could be a few things wrong.
1 - no data is going to the printer
2 - data is going to the printer, but it is not the printer's native language
3 - cable connectivity issues
4 - wrong cable is being used
5 - if wireless, data is not going to the correct IP
If using a 3rd party application, make sure that you've chosen the correct Monarch printer, as well as printing to the correct port. Sometime people print to LPT instead of Serial, as an example.
If using 3rd party drivers, make sure of the same thing.
To see if the printer actually works, press both of the arrows on the display, at the same time, after the printer is at the ready screen. As long as have the printer configured correctly (ribbon, supply type, etc.), the printer should print out a couple of labels.
Oct 26, 2009 | Paxar Monarch 9855 Barcode Label Printers...
Fax test fails on "Using Correct Type of Phone Cord with Fax"
HP printer will support only cable with 2 wire in it.
they are designed in such a way. use the cable that came with the printer
Sep 29, 2009 | HP OfficeJet 6310 All-in-One Printer...
Dont know if I have the right cords specifically what is the connection process.
If you go to the Canon support site here you can downlod easy setup instructions. This page has some other manuals and user guides that may also be of use.
Here are the basic usb cable instructions:
Connect the USB Cable Correctly (i70 / i80 / iP90) Instructions to connect the USB Cable Correctly to the printer (i70 / i80 / iP90). Before connecting the cable
After confirming the printer and computer are turned off, connect them using the USB cable (sold separately).
Note: Below is an example of what a standard 'A to B' USB Cable looks like.
How to connect the USB cable
  • Plug the flat connector of the cable into the USB port of the computer.
    Note: If there are two or more USB ports in the computer, any available port may be used.
  • Plug the squarish connector of the cable into the USB cable receptacle of the printer.
<1> Computer's USB Port
<2> Printer's USB Cable Receptacle
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 20, 2009 | Canon PIXMA iP90 InkJet Printer
Printer has connected but offline.
your printer correctly installed to your pc the printer driver I mean did your install it correctly? The usb cables has correctly attach to the CPU and printer? Thier is no broken wires of your usb cable did you try to replaced it with new one usb cable.
Apr 18, 2009 | HP Deskjet 2360 InkJet Printer
Looking for correct printer cable for HP PSC 2175 machine. Cannot locate one.
the printer use USB cable. you can get a printer cable (A/B-USB cable) crom any of the computer store.
as far as the AC cable, use can use any of the computer AC cable.
Mar 09, 2009 | HP PSC 2175 All-In-One InkJet Printer
101 people viewed this question
k24674
