Question about Konica Office Equipment & Supplies
Drivers for bizhub210 for 64 bit Operating system
We are having 2 Nos of Konica Minolta BizHub 210 printers and currently we are planning to upgrade to 64 bit operating system in our organization. So I would like to know how/where i can get the drivers for the same.
I would appreciate your help in this regard.
  • Konica Master
  • 6,674 Answers
Konicaminolta web site.
Posted on Jan 17, 2015
  • 8 Answers
SOURCE: Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Posted on Feb 02, 2008
SOURCE: machine trouble call service c0500
Try to power it up with the STOP button pressed.
If not call service team.
Posted on Oct 10, 2009
SOURCE: service manual for KONICA MINOLTA Bizhub 210/162
serves cood fo32
Posted on Jun 13, 2010
xeerie
  • 347 Answers
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
Posted on Jun 19, 2010
hamzaskilltd
  • 316 Answers
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
Posted on Aug 07, 2010
LOOKING FOR LINK TO DOWNLOAD KONICA MINOLTA BIZHUB 162 DRIVERS FOR WINDOWS 8 64BIT OPERATING SYSTEM
Go to konica-minolta.eu then you select customer support then download center then drivers then you select the correct driver from list given.
Apr 21, 2015 | Konica Minolta Office Equipment & Supplies
Can i see konica minolta bizhub 211 drum picture please
OPC Drum for Konica Minolta bizhub 210/162/211/163/182/215/164/
Feb 05, 2015 | Konica Minolta bizhub Office Equipment &...
Is it possible to scan using 210 model scanner by network?
Yes, it is possible ti use Konica Minolta bizhub 210 photocopier as a network printer.For this simply purchase network card Model NC-502 for bizhub 210.
Dec 17, 2010 | Konica Minolta bizhub 180 All-In-One...
Driver for konica minolta
http://onyxftp.mykonicaminolta.com/download/Search.aspx?ht=
Just pick black and white products under the Product Group tab. Then bizhub 250 under Product. Then Drivers under File Type. Then pick your operating system. Scroll down a bit and it will show files that are available.
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 19, 2010 | Konica Minolta bizhub C250 All-In-One...
My copier is konica minolta bizhub 210 have problem error code M1. please help me solution.
My Friend You must do general service in your photocopier and then you must program your machine.
Sep 29, 2010 | Konica Minolta bizhub 180 All-In-One...
I connect the konica minolta bizhub 210 to my win xp system then i try to print but i can't the system show the message "failed to print" what is this .please help me
SOLUTION:- Follow these steps. 1-First of all take a usb cable. 2-Connect its one end to Bizhub 210 and the other end to your computer. 3-you will see your computer will show a notification " Found new hardware". 4-Now insert the printer Driver disc of Bizhub 210 in CD-ROM. 5-autoplay will show at the desktop 6-Now click on "Install Printer" 7-Follow the instructions and install the drivers. 8-when the drivers are correctly installed you will see printer icon of bizhub 210 in "Printer and Faxes" at control panel of your computer. 9-Now right click on this icon and click on "Properties" 10-now click on "PRINTING PREFERENCES" tab. 11-select Paper size, i.e if you are using A4 size in bizhub 210 then select paper size=A4 from the list. 12-now give a print command.ctrl+p. of any document. 13-printer will start printing.
if still having problem, then please do check the usb cable, it may be broken. if there is any other printers are installed on your computer which are not in use then remove them/ delete them. use konica minolta bizhub 210 as a default printer.
Jun 28, 2010 | Konica Minolta bizhub 180 All-In-One...
REMEDY TO SOLVING ERRORS COF32 AND CO650 IN KONICA MINOLTA BIZHUB 211.
to remove code "COF32" from your machine, simply change the developer with the new one. code will remove.
wish you best of luck............
Jun 12, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Driver konica minolta 210 bizhub for type processor 64 bits
Hi plujan,
As far as I am aware, the driver for this product is not available for the 64bit O/S.
I can only suggest trying the 32bit version.
You can find drivers here
http://m-press.uk.com/support.php
Click on Software and Drivers, then use the drop down menus.
Good luck
Sep 22, 2009 | Konica Minolta magicolor 2500W Laser...
503 people viewed this question
Top Konica Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Jojo
Are you a Konica Office Equipment and Supply Expert? Answer questions, earn points and help others
