Question about Digi (76000200)
Rj45 male to db9 male cable for ups
I just need to build a cable whose one ends connect to ups( DB9 female rs232 port) & the other one to pc (rj45 8pin male connector).
any help should be appreciated....
  • Carl Navarro
    Carl Navarro May 11, 2010
    Do you think you might need to post the brand of UPS since the pinouts might be different?
    Scholar:
  • 87 Answers
If you have a BackUPS CS, you are probably either using it with the USB cable that is supplied or with the 940-0128A supplied by APC, which permits running the UPS in dumb mode. By building your own cable, you can now run the BackUPS CS models (and perhaps also the ES models) using smart signalling and have all the same information that is available as running it in USB mode.
The jack in the UPS may be easily use a 8 pin RJ45 connector. It is easy to construct the cable by cutting off one end of a standard RJ45-8 ethernet cable and wiring the other end (three wires) into a standard DB9F female serial port connector.
PC Signal PC pin UPS Pin UPS signal RxD 2 2 TxD TxD 3 8 RxD GND 5 7 Ground FG Shield 4 Frame Ground Though these UPSes are USB UPSes, APC supplies a serial cable (typically with a green DB9 F connector) that has 940-0128A stamped into one side of the plastic serial port connector.
Here is suggested scheme of original 940-0128A cable
APC Part# - 940-0128A computer --------- Inside the Connector--------- UPS DB9-F | | RJ45 pin - signal | | Pin - Color | | 4 DSR ->|---+ | | | diode resistor | 6 DTR ->|---+---->|----///---o kill power | 8 Orange | | 1 DCD <-|----+ | | | | 2 RxD <-|----+----------------+--o low battery| 3 Brown | | | 7 RTS ->|----------+--///--+ | | | | | +--///--+ | | | | 8 RI <-|----+----------------+--o on battery | 2 Black | | | 9 CTS <-|----+ | | signal | 5 GND --|-----------------------o ground | 7 Red | | 3 TxD | | | chassis | Chassis/GND |-----------------------o ground | 4 Black | | | Not connected | 1, 5, 6, 9, 10 --------------------------------------
Posted on Oct 24, 2008
Not connect from console port
Verify that the correct settings and cable/connectors (rollover cable, correct COM port specified) are being used when establishing the console connection.
From the manual-
3.9.2 Connecting to an IBM or Compatible Device
To connect an IBM PC or compatible device, running the VT terminal emulation, to an
Enterasys Networks module Console port (Figure 3-20), proceed as follows:
1. Connect the RJ45 connector at one end of the cable (not supplied) to the Console port on the
Enterasys Networks module.
Connecting to Console Port for Local Management
Hardware Installation 3-31
2. Plug the RJ45 connector at the other end of the cable into the RJ45-to-DB9 adapter (supplied
with the device).
3. Connect the RJ45-to-DB9 adapter to the communications port on the PC.
4. Turn on the PC and configure your VT emulation package with the following parameters:
Parameter Setting
Mode: 7 Bit Control
Transmit: Transmit=9600
Bits Parity: 8 Bits, No Parity
Stop Bit: 1 Stop Bit
source: Install Guide for Enterasys 1H582-25 / 1H582-51 (http://www.retrevo.com/support/Enterasys-1H582-51-Switches-manual/id/2785dj098/t/2/)
Jun 22, 2011 | Enterasys MATRIX E1 (1h582-51-g)...
Does a de/db9 to dvi-d female adapter even exist? Is there a combination of adapters I might be able to use? I need an adapter with one female de/db9 to connect to my computer whose other end is a...
Looks like it does exist...
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=380342442870&hlp=false
Are you sure its a DB9 and not an hd15?
Jun 11, 2011 | Televison & Video
Need driver for CISCO DB9 TO RJ45 6FT CABLE 72-3383-0 for my notebook
If I am understanding correctly, you are using a serial to ethernet cable. The serial cable plugs into your laptop and the ethernet end plugs into the CONSOLE port on the Cisco.
From here you use a terminal emulation program like "Hyperterminal" to connect via the serial port. As long as your serial port is installed, no other drivers are necessary.
May 02, 2011 | Cisco Compatible DB9 to RJ45 Console...
Hello I am trying to do a pin out on an rs232 db9 male to rj45 adapter so that I can connect a tut xl 1010 with a workstation and I was wondering if a regular straight through pin out would work
No. Straight through will not work. However, adapter cables and connectors do exist for exactly this application. Most local electronics shops like Radio Shack should have them in stock and they only cost a few dollars.
I hope this helps.
Aug 20, 2009 | Tut Systems XL-1010 (766796510108) Bridge
My adapter DB9 FEMALE TO DB25 FEMALE doesnt allow me to see my Printer
Are you tring to run a parallel printer from a serial port? If so then it will not work at all. You would need a serial to prallel adaptor that also has the software drivers needed to convert the signal.
Jun 13, 2009 | Parallel 25 Foot DB9 Female to DB25 Male...
I have an MSI motherborad model MS-7366 and I need to plug a DB9 male to 10 pin header pc blanking plate I just need to make sure I am pluging it in the right place
LOOK AT THE ROWS ON PINS ON THE PLUG IN CABLE ,THAT THE MALE END. AND THE LABTOP HAS THE FEMALE END AND IF FOTH LOOK THE SAME THAN PLUG IT IN, BUT THE MALE END MAY NOT HAVE ALL THE PIN LIKE IN THE FEMALE PLUG LOOK LIKE THAT OKAY
MAKE SURE ALL THE PINS ARE STRAGHT
CANDYMANGANDY
Jan 28, 2009 | Intel Motherboard
Meaning of Db and the use of Db9-male Cabl
The D is the shape of the connector when looked at it on it's side. The second letter (A,B,C,D,E) defines the amount of pins in the D connector. "DB9" is actually called DE by the standard and the E=9 pins. A=15, B=25, C=37, D=50, E=9. This standard was set in place by ITT Corp (Not the school) in 1952, and DE-9 connectors were used for tons of applications. (Machinery, Cars, etc). If you are only referring to the computer uses, the connector is widely known as RS-232 or a "Serial" port. These ports in computers were/are used for devices like early printers, scanners, networking hardware, or even as a method of connecting to the Internet at one point.
Dec 05, 2008 | Parallel 6 Foot DB9 Male - DB9 Female Null...
I cann't connect to my switch
The primary connection method for those switches would be serial connection. In the box there should have been a DB9 serial to RJ45 cable. Hyperterminal default settings would allow you to connect.
Jul 25, 2008 | 3Com 4500 24-Port Ethernet Switch
What is the right rs232 cable to connect a Denon 3808CI reciever and a Phillips RFX9600 serial extender
OK LOOKING AT THE SPECS FOR THE EXTENDER YOU DO NOT NEED TO WORRY ABOUT THE SERIAL CONNECTIONS, WHEN USING THE SERIAL CONNECTIONS YOU NEED RS232 CODE STRINGS TO CONTROL THE DENON OR ANYOTHER DEVICE THROUGH THIS EXTENDER USING THE RS232 CONNECTIONS.
IT LOOKS LIKE YOU CONNECT AN I/R EMITTER FROM AN MINI JACK I/R CONTROL PORT ON THE BACK AND THE OTHER END TO THE I/R WINDOW ON THE DENON
Feb 27, 2008 | Denon AVR 3808Ci Receiver
Digi (76000200) Logo
1,862 people viewed this question
Top Digi Computers & Internet Experts
doggzzz
Level 1 Expert
Alun Cox
Don Hart
Are you a Digi Computer and Internet Expert? Answer questions, earn points and help others
