Question about Logitech X-530 Computer Speakers
Setup I have just bought a logitech x530 subwoofer and 5 speakers PIDA542 connected it up but not getting any sound can you help please.
  • linx100 Oct 02, 2008
    thanyou very much was a big help take care.
  • Anonymous Oct 04, 2008
    no sound
Good Morning:
Hope that you are wellJ
Connecting the speakers correctly seems to be the biggest issue.
Try this diagram: http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=2913&p_created=1125714076&p_sid=gel419fj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9OCw4JnBfcHJvZHM9ODQ0LDE3LDY0MCZwX2NhdHM9JnBfcHY9My42NDAmcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1OTyBTT1VORA**&p_li=&p_topview=1
Be sure that you are not set to stereo
You must have at least a 6 channel card.
Also:
After verifying that the connections are made correctly, the sound card needs to be checked to make sure it is setup correctly. There are many sound card manufacturers so we cannot possibly cover every make and model. We recommend contacting the manufacturer of the sound card to make sure the sound card is setup correctly for use with analog 5.1 speaker systems.
When a software DVD player is being used to watch a DVD, the audio output needs to be set to surround sound mode. Please refer to the user manual for the software DVD player to check the settings.
Many DVDs have more than 1 sound format available. Just as the sound card and the software DVD player, the DVD itself has to be set to the correct sound format.
Finally you can test to see if the speakers are working correctly by plugging the front channel cable coming from the sound card to the rear channel connector on the subwoofer. If sound comes out of the rear speakers, then there is no problem with the speakers. The problem could be with the software DVD player, or the audio setting on the DVD.
If I can be of further assistance, please let me know.
And, remember; always include the type of Operating System and the type of computer you own, when you submit your questions. It simply makes for much faster solutions.
Have a wonderful morning.
Posted on Sep 30, 2008
I have a Logitech x530 subwoofer and I want to use it for my laptop. Don't what type of cable or connection to use. Help me out guys.
i had to get a 3.5mm male to 3x female 3.5mm lead from ebay that works well for me. any audio shop should have them.
Aug 24, 2016 | Logitech Audio Players & Recorders
HOW DO I GET ALL 5 SPEAKERS TO WORK ON TELEVISION?
I presume you have a sound system (surround ) dvd etc the speakers are usually connected at back these are all colour coded so should be no problem hope this helps you cheers
Jan 24, 2011 | Logitech X530 5 Speakers
5.1 surround sound system
perhaps you wired the subwoofer backwards, you got the positive and the negative mixed up on one of the speakers
Dec 26, 2009 | Audio Players & Recorders
No Sound For Logitech X530
dont know if this will help but when i plugged my speakers in the green light would not even come on and i decided to take them apart and in the sub. there are two fuses the one on the circuit board was blown so i un soldered it and got a new one. replaced it and works great. hope it helps
Oct 29, 2008 | Audio Players & Recorders
Subwoofer and center box problems with Logitech X530
Hi Sainty,
this is just a shot in the dark, but have you attempted to play around with your sound driver's configuration? I'm unfamiliar with the newer Nforce stuff, but try looking around in the sound manager Nvidia uses. It sounds like it's been configured to swap speakers. (As an example, I'm using the realtek audio manager on an asus p5k-vm board myself, and the option shows up as "Swap Center/ Subwoofer Output" in my configuration.)
Dec 10, 2007 | Logitech X-530 Computer Speakers
LOGITECH X530
Locate the Audio output on your TV and connect it to ur X530 Audio input. Locate ur Audio output (exa. AUX-OUT, MONITOR OUT, ETC..) on ur Home audio then connect it to ur X530 audio input. Goodluck
Aug 11, 2007 | Logitech X-530 Computer Speakers
Logitech speakers will only play on 2 speakers not 5
Liamog, i bought the exact same speakers and sound card, and i had the exact same problem as you. I tried for days to fix it and it turns out that its only a setting you have to enable in your sound card settigns. If you go into your EAX console for your creative sound card you will find a thing that sams CMSS 3D, and all you have to do is select the button that says Enable CMSS 3d surround. I hope this will fix your problem. Alex.
Nov 11, 2006 | Logitech X-530 Computer Speakers
Logitech X-530 Computer Speakers Logo
264 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
