PAPER WILL NOT PASS THROUGH PRINTER, WHEN PRINTING
First check that when printer is power on the motors r moving or not
Posted on Sep 30, 2008
Printing black paper
check grounds on the main board or clean formatter
Mar 19, 2014 | HP LaserJet 5000n Printer
MY LIPI PB2 PASSBOOK READY LED CONTINUOUSLY BLIKS WHEN I SWITCH ON MY PASS BOOK PRINTER
Olivetti Printer Is Required Calibration
1 Open Your Cover Of Printer
2 Than Move Head Left Side
3 Than Push three Key Than Printer Power On
4 Just Some Beep Is Comeing
5 Close Cover Of Printer
6 Press Station 1 Two Time
7 Than Insert Blank Paper
8 Press Station 2
9 Printer Removed The Paper Automatically
10 Than Again Insert Paper
11 Printer Some Printing
12 Than Printer On/Off
13 Than Printer On
Your Problem Is Solved
Regards
yogendra Sharma
Jul 08, 2012 | Office Equipment & Supplies
Printer showing error message ...."printing
This means that your machine has received a print job that is teling it to print on paper that is loaded or supposed to be loaded in the bypass feed tray. You will either need to delete the print job using the operation panel or simple load some letter size paper in the bypass tray over on the right side of the machine.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 18, 2010 | Panasonic Workio DP-3030 Printer
How to stop red blinking "paper"? couldn't stop
There is probably a paper jam since you shut it off as it was printing. Turn off the printer. Remove the tray and look inside. Remove any sheets of paper you see. Open the back of the printer (the pass-thru door) and remove any paper you see. Turn on the printer. If that fails, check the blink status against the manual's troubleshooting guide to locate a different solution.
Aug 27, 2010 | Brother HL-2040 Laser Printer
Hi! printing flight boarding passes on Epson
run it through a cleaning mode.
in ctrl panel
select printer and r click go to
properties and then the
maintenance tab.
Run clean
Run Nozzle check
When it prints correctly
ensure you select paper size as A4 and print your pass.
Pleazse rate my help++++Thanks for using Fixya
Jun 04, 2010 | Epson Stylus C46 InkJet Printer
This is my 3d iP90 in 18 mo. w/same problem: not dragging paper
That is a fairly fragile printer, if you pack them in luggage they put other bags on top which bends the frame of the printer so that paper can't pass thru anymore. The only repair is to replace the entire print engine which costs more than a new printer.
Oct 09, 2009 | Canon PIXMA iP90 Mobile Printer
PRINTER CARTRIDGE STALLED
Is there someting stuck in the printer like a pencil or a keychain, something small that would allow paper to pass but also trigger a sensor in the printer as the printer can detect that paper is being passed unevenly.
Question: does it just say that the ink cartridge is stalled or does the cartarige really stall?
Feb 20, 2008 | Computers & Internet
Canon printer
clean the feeder rupper or replace them
Jan 07, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
By Pass tray printing
I had this problem when printing checks in Quickbooks, I resolved the problem by going to File, Printer Set up, then select checks/paychecks, then select Options next to printer drop down box, then select Paper tab, Input tray select "Bypass Tray"
Not sure if this is your application, but it did resolve my issue.
Nov 13, 2006 | Ricoh Aficio CL3500N Laser Printer
jasbo
jasbo
