I needto get instructions re connecting my Dell Monitor to my new laptop as I have miss placed my instruction CD .your assistance needed .Thank you.. dennis.soan@gmail.com
    Genius:
  • 1,250 Answers
You can connect for this you have to attach VGA cable of the dell monitor to the VGA port of the laptop, and power cable of the monitor to the power source
Posted on Sep 30, 2008
How do I install my 22w2 to my Dell Computer with Windows XP 2002
Windows install first Available some points:-
A> Fresh Windows XP CD not damage cd, if cd damage may be some file miss and installation after problem show.
B> DVD Rom Drive.
C> You DELL pc support Windows XP.
Installation Process:-
> Insert CD to DVD ROM driver and boot CD.
> If CD not select first boot then open bios and select CD first boot.
> Then follow instruction step by step like language, which drive install windows (C Drive select), format option (select quick format), new user create etc.
Thanks..
Sep 06, 2013 | Westinghouse Electric LCM-22W2 Monitor
Restore dell m5040 to factory specs
Place the Dell recovery CD in the CD drive and boot up the Dell with this recovery CD then follow the instructions.
Jun 25, 2012 | Dell Inspiron M5030 Laptop
My dell inspiron 1525 laptop wont boot no matter what I do..Please help I need this fixed and running again asap..This is the error I keep getting. Windows XP could not start because the following file...
If you have or can find a cd of the same version of XP follow the instructions at this link.
http://support.microsoft.com/kb/314477
Good luck.
If this helps you resolve your problem, please
consider giving me a rating of 4.It will help me as well. Thank you.
Nov 26, 2010 | Dell XPS M1530 Laptop
CRASHED DELL INSPIRON B130
As you cannot power up I cannot see it being an AVG problem although it seems strange that it happened after you installed it.
As you needed to download an anti virus prog because you thought you had some then we will presume you were on the internet unprotected. A big mistake!!!
If you have a virus/trojan stopping your system from starting then you need to download the following on another PC and burn to disc. You must also make sure you laptop is connected to the internet or follow the instructions on the website below.
If this does not work then it is a problem with your laptop.
Here's the link full instructions and download here (at the bottom of the instructions.)
http://www.raymond.cc/blog/archives/2008/07/26/free-f-secure-rescue-cd-300-to-clean-virus-from-unbootable-windows/
May 05, 2010 | Dell Inspiron B130 Notebook
Dell D600 cd rom replacement instructions
There should be a screw on the bottom holding the cd rom in place. Unscrew the screw and then with one end of a paper clip put it in the small hole on the front of the cd rom and the door should open. Now go ahead and pull the cd-rom out.
Now you can go ahead and put the new cd-rom in place and put the screw in and then turn on the laptop and let it boot up into windows and windows might redetect it. Go into my computer and you should see your cd-rom in there.
Jan 23, 2010 | Dell Latitude D600: Pentium M 1.6GHz,...
Problem with Fan - Dell Laptop Inspiron B130 ?
If the fan is dead, then the laptop will shut itself off after a short while to prevent heat damage. It is normal for the fan to spin up when you turn on the laptop and then stop turning. The fan will kick in again when it is needed as heat builds up. The system fan has absolutely nothing to do with the lcd lighting up.......seriously.
If the laptop is running, but the screen goes dark after a few seconds, it sounds more like the backlight on the lcd panel is shot. From what you describe, I assume that your lcd is not 'lit up' at all, but you can see a faint image on the screen. If this is the case, then either the inverter board is shot, or the backlight for the lcd panel is dead. You can try calling Dell at 1-800-www-dell and try to purchase an inverter board. They are cheap, and it would be worth the gamble to buy one, because if the backlight is shot, then you need a new lcd panel - $350+ (the backlight is part of it and not replaceable). The inverter board is located at the bottom of the display module, right behind the dell logo at the bottom of the display. It's quite easy to get at.
Here's a good test. Shut the laptop off, and attach a computer monitor to the 15 pin vga connector at the left side of the laptop. Turn on the laptop and the monitor should show you an image. If not, try holding the blue 'fn' key and press and release the f8 key. This should switch you over to the external monitor. If the laptop works fine when connected to an external monitor but has no image, then it's definitely not the fan, and you should try an inverter board. If still no good with a new inverter board, you can still use the laptop with an external monitor.
Hope this helps!.......let me know how you make out.
Dec 12, 2009 | Dell Inspiron B130 Notebook
Device manager and network adapter missing
you need to reinstall the drivers for your network, such as the ethernet and the wireless drivers. try to check if you still have the dell resource cd drivers disc. you need to insert that disc and check for the network drivers install them one at a time. if you no longer have the drivers disc then you can download it from a diff computer that has an internet connection. this is the website http://support.dell.com
click on the drivers and download and click on the green icon to enter the service tag. after that it will display all the drivers. you can download just the network first and save it to a storage device. then install that to your computer and download the rest of the drivers after you connected to the internet.
Oct 15, 2009 | Dell Inspiron 1501 Notebook
I am trying to install my new X223W monitor to my IBM thinkpad laptop. I can't do it even though I have the 15 Point connections and the power cord installed correctly. No pic on the monitor.
Go to your helps directory in the Thinkpad and there should be a helps to assist you with you monitor to laptop connection.
Also look at the monitor instruction to see if you have missed a step or two.
There is also an IBM forum online for IBM Thinkpad owners to get specific help.
Aug 05, 2009 | Acer 22" X223w LCD Monitor
Bootmgr missing
This website has info and instructions on how to creat a cd to help you fix the boot problem.
http://www.tinyempire.com/notes/ntldrismissing.htm
copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 16, 2008 | IBM ThinkPad T23 2647 Notebook
Password forgoten.................
You can use this free software.
Read the instructions first, then scroll down and download the cd-image. How to make the cd is explained under the download link for cd.
Also the use is not difficult. Make sure your BIOS is set to boot from CD. restart the computer with the cd in the drive. follow the instructions, and answer the questions. Most answers will be the default answer, so it's really simple...
Success
Apr 01, 2008 | Dell Inspiron 6400 Notebook
Computers & Internet Logo
David Payne
David Payne
