Monitor MAG 570V
Offer where skim become clear scheme of the monitor MAG 570V.Found 3 pieces, but indications beside them not clear. Wait the answer to ceeec@abv.bg, since until can understand where in put to assign the questions.Excuse me unless has got there where it is necessary, since I not quite understand in english and use the translator.So can me to direct please.
  • lokr Oct 22, 2008
3 Suggested Answers
SOURCE: MAG innovision LT917s problems
K I just fixed mine! I hope you still have your screen dude. Its easy. Take the screen apart, and take the monitor part off, open up the part thats attached to the back, and remove the big silicon peace thats attached with the golden bolts. Look at the capacitors, if they are bulged up then they are broken, go to radioshack and buy some new ones, they are 470uF 25v 105C, but 470uF 35v and 85C will work as well. Solder them off and put the new ones on, connect everything and it'll work like new. Just did it today and saved myself 200 from buying a new screen!
Posted on Jun 18, 2008
SOURCE: My mag Innovision flat lcd monitor is blank after 3 seconds..
It is not easy. I slip a knife in the bottom edge and slowly work my way around the bottom opening it a little by little. Once you get the bottom and part of each side you can push the plastic towards the top and it will pop off. There are plastic clips holding the bezel down. I always break a couple on opening, but at least the monitor gets fixed. This is not made to open, so good luck.
Posted on Sep 22, 2009
P0702 p1685 fault code on 2.7crd merc transmission
DTC P0702 - Transmission Control System Electrical
There is a code in the ****** control module and need to check harnesses and wiring, as first step.
DTC P1685 - Skim Invalid Key
Transponder ID (in ignition key) is monitored with ignition on. DTC will set if transponder ID read by Smart Key Immobilizer Module (SKIM) does not match any transponder ID's stored in SKIM memory. Possible Causes:
- Incorrect VIN In PCM
- Invalid SKIM Key Present
- No Communication With SKIM
- No VIN Programmed In The PCM
- PCM SKIM Trouble Codes Set
I would suggest clearing all these codes, and drive it until the problem arises again, or the check engine light comes on, and then check for codes again. To clear the codes you will need to remove the negative battery cable, and touch it to the positive cable, for about 15 seconds. Then re hook and all the modules will be reset. If this isnt work, visit your Trans Service.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Oct 27, 2011 | 2002 Jeep Grand Cherokee
I forgot my skypephone s2 security code is there a master reset code
i cant connect skype phone to to computer from today what is the problem ? will it be solved if i reset it and how to do it ? please answer me
email: pi4nemate@abv.bg
Feb 11, 2011 | Cell Phones
Slightly Blurred images on monitor
If it is a CRT monitor then the tube may be going out. A new monitor is about $129 for many of the cheap monitors I suggest you swap it for a newer flat screen.
Dave
Jul 04, 2017 | Mag Innovision InnoVision 786 PF 17" CRT...
My yahoo account was abused
unlucky id say you have lost it and they probably cant help. sorry.
Sep 24, 2009 | Ahead Software Nero 6.0 (60045) for PC
Power supply to Mag 780 Model
No, it has a normal, seperate power cord. But the socket in the monitor is very small, it's a small round one. When facing the monitor from the back, it's located directly to the right of the monitor-stand, at the bottom-side of the screen. Just put the monitor on it's side to see it clearly.
It's all explained with pictures in your monitor's manual which you can download from the official website here: http://www.maginnovision.com/Support/Downloads.aspx?sn=464
Aug 23, 2009 | Mag Innovision LT776s 17" LCD Monitor
I have motherboard Compaq #277498-001 P5008640WP8N2BSM AS#253242-002 DG#011346 and can't find information for jumpers setting, please for help-marior77@abv.bg
What model does this MB belong to? If it is a newerMB the only jumper settings you should see would be the clear BIOS jumper. Alot of the newer motherboard settings are done thru the BIOS.
http://www.compaq.com/cpq-country/cpq_support.html
try looking here
good luck
May 16, 2009 | Compaq ( 277498-001) Motherboard
Jan 29, 2009 | Mag Innovision LT976S 19" Flat Panel LCD...
Mag Innovision LT576s won't power up
Clearly your monitors are evil. Try turning them on at home and see how you fair out. :)
Cheers,
Mike
Oct 07, 2007 | Mag Innovision LT576s 15" Flat Panel LCD...
Width problem
To have unlock your control (auto-adjust ...) you have to hold down the "menu Key" for about an 10 seconds. This will unlock your monitor! peroludiarom@abv.bg
May 30, 2006 | Samsung SyncMaster 753S 17" CRT Monitor
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
