How to Find Your Own IP Address
I want to see my ip address on my macintosh os x
  • 30 Answers
  1. Open the System Preferences application
  2. Click the Network icon
  3. Select Network Status from the Show drop down field
  4. Look for the Built-in Ethernet item, or other applicable network interface
  5. Look for the IP address that is shown to the right
Posted on Sep 30, 2008
My ip address fails on and doesnt connect to internet
Hello, I do not what O.S. you have, but on Windows 10 to reset the TCP/IP address, you need go to
from the taskbar , click Star icon/ in the search field enter CMD and then press enter / The Command Prompt window displays
- to view you IP Address, enter ipconfig and then press Enter; the numbers and dots represent you address / display represent your address.
  • To release your IP address, enter ipconfig/release and press Enter.
  • To renew your IP address, enter ipconfig/renew and press
  • Enter
    When you finish close the CMD windows
    Apr 20, 2017 | Internet Computers & Internet
    Tip
    Configure PS121 with MAC OS X
    Configure NETGEAR PS121 print server with MAC OS 10.4.X and may work for other version of MAC OS X
    Please sure that the printer is working in direct connection with the computer.
    1. Now connect the printer to the USB port of the printserver and then the ethernet cable from the router to the Printserver ethernet port.
    2. Press the diagonistic tool button on the printserver for 10 sec (All the lights will blink amber), you will recieve a print page with Port name,Ip address of the printer and other details.
    3. The ip address will be given from the router,If no ip address, powercycle the router, printserver and the printer. Press the diagonistic tool button again.
    Click on “Print and Fax” icon
    Click on the “+” icon to add a new printer
    Click on the “IP Printer” icon
    Select “Line Printer Daemon – LPD”
    1. In the Address field, enter the IP address of the PS121
    2. In the Queue field, enter L1
    3. In the Name field, enter L1
    4. Select the printer manufacturer from the pull down
    5. Select the printer model from the scroll box
    6. Click Add
    a. Click once on L1 to select it
    b. Click on Printer Setup
    Click on the “Installable Options” pulldown menu and select “Name & Location”
    1. Change Printer Name to IP address of PS121
    2. Change Location to: IP_.ip of PS121
    3. Click on Apply Changes
    The Macintosh is now ready to print.
    on Mar 18, 2010 | NetGear PS121 Print Server
    Ip address dynamic
    Dynamic and Static addressing are the two main methods used for IP address assignments. Dynamic IP addresses are automatically obtained and nothing needs to be done on the user end. However, Static IP address information must be configured manually. If you do not have a router, you need to input your static IP information directly into your Apple Macintosh.
    Click "Apple > System Preferences." Click the "Network" icon. Click the "TCP/IP" tab. Choose "Manually" in the Configure drop-down menu. Click in "Show" and choose your Ethernet device. This is usually called Built-in Ethernet. Enter your IP address into the IP Address field. Enter the Subnet Mask into the Subnet Mask field. If your service provider did not provide you with one, use the default of "255.255.255.0". Enter the Gateway address into the Router field. Enter the DNS Server into the DNS Servers field. Two should have been provided to you. Push the "Apply Now" button to confirm changes.
    Apr 07, 2013 | Belkin Ethernet Adapter F5D5050 Network...
    Belkin f9k11009v1, Macintosh unable to connect
    First see if you are able to connect to the internet wired to the router,
    -If you are able to connect using the wire connection then I suggest to turn off the wireless security settings for the time being and see what happens.
    Wireless
    See if you are able to ping your router.
    Ref: http://www.wikihow.com/Ping-on-Mac-OS
    -Make sure that the TCP/IP settings are set to DHCP and make sure that it is getting an IP address and Default Gateway.
    If you are able to ping the router then see if you are able to ping google by name and by IP. (An IP address for google,com is 74.125.141.100)
    If you are able to ping both then you should be able to access the internet.
    If you are able to ping only the google's IP address then you have a DNS issue.
    -See if you can set your DNS address manualy to 8.8.8.8 and 8.8.4.4. Ref: https://developers.google.com/speed/public-dns/
    If you are able to ping only google by name then see if you are able to access google by typing in the replied IP address in the address bar of your web browser on a computer that is working fine.
    -If you are not able to access google with the address then you may have something stooping you on your machine. Check for firewalls and antivirus to see if they have any network configurations.
    Dec 18, 2012 | Belkin F5D7234-4 Router
    How do I find my ip address?
    In windows 7, xp, vista:
    START, ALL PROGRAMS, ACCESSORIES, COMMAND PROMPT
    type in ipconfig,
    ENTER,
    IP IS SERIES OF NUMBERS
    if you are using ppp with modem then will change every time you log in.
    Mac OS X computer:
    APPLE MENU, SYSTEM PREFERENCES, VIEW MENU, NETWORK, IN PREFERENCE, NETWORK PORT,
    if you are connected it will be there.
    OS X 10.4 OR 10.3:
    APPLE MENU, LOCATION, NETWORK PREFERENCES, SHOW, NETWORK STATUS,
    Sep 06, 2012 | Dell Computers & Internet
    I'm using two Macintosh Computers. I followed the quick setup wizard, all the right lights are lit. I've reset my broadband modem, I've reset the Dynex Router. Yet I can't make contact...
    Richard have you tried setting up static ip addresses on the MACs
    If you have other p.c's on network with auto ip assignment then alter the DHCP server lease to 192.168.1.10 to 192.168.1.240
    then make ip address static 192.168.1.241 subnet mask 255.255.255.0 default gateway 192.168.1.1 and on the other mac
    make ip address static 192.168.1.242 subnet mask 255.255.255.0 default gateway 192.168.1.1
    http://www.macinstruct.com/node/550
    Jul 07, 2017 | Dynex DX-E402 Router
    Ip address
    No. Formatting your PC will not change your IP Address if it is set to automatically obtain it. Your router's DHCP server will allocate the same IP Address your computer is using.
    Apr 01, 2009 | NEC ND-6650A DVD RW Dual Layer Burner
    Connecting to xbox live with speedstream 4100
    force the gateway on the xbox configuration... retrieve gate from command prompt of your pc depending on the os.
    Jan 28, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
    Connecting to xbox live with a speedstream 4100
    I have to repair my connection to get internet
    Are you running a virus scanner or internet security software?
    Is it active and has it been updated recently?
    Do you perform periodic full scan of your systems and are they clean?
    Do you run any apyware packages?
    Are they active and have they been updated lately?
    Do you perform periodic scans with them and is your system clean?
    Not all virus scanners, etc catch all problems. Some catch different items.
    Consider using free online services from some of the security vendors to double check your product. Several to consider
    Trend Micro
    Fsecure (www.fsecure.com and search for online scanner)
    Symantec
    Consider free spyware software for additional checks if you have not choosen to purchase a product to do this.
    Lavasoft
    Spybot
    Clean up the issues found and see if the problems are eliminated.
    Using the following instructions from the zonet website to get your IP address will also reveal your router's address in the default gateway entry (assuming your computer receives it's IP information via DHCP from the router or has been staticslly configured correctly). This will be the value you utilize instead of 192.168.1.1 to access the router's configuration.
    spacer.gif Q: How can I find the IP address of my computer? spacer.gif A: Windows 95, 98, and ME:
    Click on Start.
    Then click on Run.
    The Run Dialogue Box will appear. Type "winipcfg" in the window as shown then click OK.
    The IP Configuration window will appear, displaying your Ethernet Adapter Information.
    Select your adapter from the drop down menu.
    If you do not see your adapter in the drop down menu, your adapter is not properly installed.
    After selecting your adapter, it will display your IP address, subnet mask, and default gateway.
    Click OK to close the IP Configuration window.
    Windows 2000 and XP:
    Click on Start and select Run.
    Type cmd then click OK.
    From the Command Prompt, enter ipconfig. It will return your IP address, subnet mask, and default gateway.
    Type exit to close the command prompt.
    Macintosh 8.x and 9.x:
    Click on the Apple Menu>Control Panels>TCP/IP.
    Select your Ethernet adapter from the Connect Via drop-down menu.
    Under Setup, select Using DHCP Server from the Configure drop-down menu, if connecting to a router DHCP server. This is the most common setting when using a router. In this configuration, your computer will be automatically assigned an IP address by the router.
    You must reboot your computer to "renew" your IP address.
    Macintosh OS X:
    Click on Apple Menu>System Preferences>Network>TCP/IP.
    Linux:
    At the command line type /sbin/ifconfig and you will get a listing of information. Your IP is shown after inet addr.
    Dec 08, 2007 | Zonet ZSR0104CP (zsr0104cp) Router
    Computers & Internet Logo
    66 people viewed this question
    David Payne
    David Payne
