Question about OEM Systems Bluetooth Headsets - Model BTCC1357A Headset
Using Tesco bought AOEM GW-BT-002 Bluetooth earpiece with laptop
Im trying to use this headset with my laptop, it seems to initially connect, then I cant seem to use it. It doesnt show up in the audio properties at all. When I try and select it within the 3rd party messaging software, it doesnt appear. Can you guys suggest a course of action? Is it a driver issue? Im using XP Professional SP2 with a dell D600 latitude laptop.
3 Suggested Answers
SOURCE: new bluetooth earpiece, no instructions
Push and hold both vol(+) and vol (-) at the same time for approx 2 secs. The headset will falsh green and red lights. Get your phone to search for bluetooth devices. It should find the headset. Enter pairing code 1234 in phone. Done.
Posted on Feb 21, 2008
SOURCE: CANNOT PAIR AOEM BLUETOOTH HEADSET TO LG SHINE KE970 MOBILE PHONE
Posted on Jul 13, 2008
The mamual says to hold the - and + volume keys at the same time for approx. 2 seconds till the light starts to flash green and red. The pairing code is 1234
Posted on Aug 26, 2008
How do I pair my Bluetooth blue action BT-EVE033
BlueAction Brushed Aluminum Bluetooth Earpieces (Hot Pink)
www.tesonicusa.com > Bluethooth
Please wait... Gift Certificates · My Account ... BlueAction Brushed AluminumBluetooth Earpieces (Hot Pink). Image 1 ... Item Code: BT-EVE033-HPK. Color: Hot ...
BlueAction Brushed Aluminum Bluetooth Earpieces (Silver ...
It is 100% universal and can be use with all Bluetooth appliances. Auto paring function ... Gift Certificates · My Account. Whole Sale Sign ... BlueAction Brushed AluminumBluetooth Earpieces (Silver). Image 1 ... Item Code: BT-EVE033-SIL ... Multipoint techonology, pairing with TWO Bluetooth devices simultaneously. - Sleek ...
Jan 07, 2016 | Radio Communications
Lost My pin for the bluetooth AOEM GW-BT-002 headset. the generic 0000 pin does not work and neighter does the 8888
Hi johan56s The pin is 1234. Hope this helps ???
My problem is,that i can make a call using my ear piece,but not sure on how to receive a call via ear piece.If i just answear via Mobile, can only hear through phone.Wish i didn't mislay my handbooks. Hope someone can help. Cheers Waveslider123
May 24, 2010 | Motorola Cell Phones
Pairing with Nokia N95
hi,
I posted the manual to this headset here
http://www.fixya.com/support/t526500-cannot_pair_aoem_bluetooth_headset_lg
Jan 29, 2009 | OEM Systems Bluetooth Headsets - Model...
Jabra vbt185z difficulties using voice commands
go to your phone tools and find voice command blue tooth and follow prompts . its all in the phone . the tooth is run by the phone. your blue tooth is only a reciever, the phone is the boss. good luck
Jan 15, 2009 | Jabra BT350 Bluetooth Headset Headset
Power up
follow the steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the AOEM device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Hope this helps
Season's Greetings from Fixya!
Chris (ziraffa)
Dec 14, 2008 | Motorola Mobility HS850 Consumer Headset
Apr 19, 2008 | Radio Communications
Mar 31, 2008 | OEM Systems Bluetooth Headsets - Model...
Bluetooth to mobile pairing
Jan 05, 2008 | OEM Systems Bluetooth Headsets - Model...
New bluetooth earpiece, no instructions
Radio Communications Logo
309 people viewed this question
Top OEM Systems Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you an OEM Systems Radio Communication Expert? Answer questions, earn points and help others
