Question about Hotpoint HSS25GFP Side by Side Refrigerator
Fridge freezer noise problem
I have purchased a sumsung RL 33 SBSW a year ago, but these day it makes some strange noise coming out from the inside back, maily when it is opened then closed again, it starts duzzing for a while then stops. I am worried about this problem. Is there any one there who can help.
your help is much appreciated
    New Friend:
    Problem Solver:
  • 10 Answers
Hi!! you will need to replace a sensor in the fridge behind the back cover! this is due to iceup around the fan in this back cover! even if you defrost it, it will do it again so turn off from plug for 24 hours but leave the fridge door open other wise it wont totaly defrost! then open back cover in fridge with care and you will see a small white plastic attached on double wire which is pluged in to a socket on the right side in a squre box! very rare somtimes the heating element goes too which has to be tested! you can use a steam machine to defrost it in an hour which is safe providing you dont put steam in to the electics in the squre box! oh make sure you take plug out before you start to steam. take care when doind this to take off back cover in fridge as if you force out the cover without melting the ice behind it it will damage the cover! in expert hands it looks easy so good luck!
Posted on Mar 01, 2013
  • AHMET TARIK Mar 01, 2013
    hi!! you will need to replace a sensor in the fridge behind the back cover! this is due to iceup around the fan in this back cover! even if you defrost it, it will do it again so turn off from plug for 24 hours but leave the fridge door open other wise it wont totaly defrost! then open back cover in fridge with care and you will see a small white plastic attached on double wire which is pluged in to a socket on the right side in a squre box! very rare somtimes the heating element goes too which has to be tested! you can use a steam machine to defrost it in an hour which is safe providing you dont put steam in to the electics in the squre box! oh make sure you take plug out before you start to steam. take care when doind this to take off back cover in fridge as if you force out the cover without melting the ice behind it it will damage the cover! in expert hands it looks easy so good luck!
Yes...The same thing happens to me. It's coming from the back of the freezer and it's where ice gets clogged around the blades. The best thing to do is turn it off and defrost it. Even though there's no ice inside the freezer, being frost free, this will sort your problem i'm sure....
Posted on Oct 12, 2008
Strange Clicking
You have a minimum 90 day warenty,normally one year.Take the unit back and get a new one.This is why you get a warnty with things you purchase,so if anything goes wrong,you can get it replaced.Or repaired,your option.
Apr 14, 2014 | Weslo Cadence G 5.9 Treadmill
Brakes making noise
check any high or rough spots on rotor or drums or pads
Apr 12, 2014 | 2000 Enfield Bullet 350
Fuel filter whistling
where is the hooter on a 2005 polo player lacated
Apr 23, 2013 | 2004 Volkswagen Polo 1.4
I have a Tevion 32 inch LCD (Model LCD3210id ), purchased from Aldi stores about 4 years ago. The screen has started flickering and it is making a slight crackling sound from the back. One, has anyon
Those sounds would be either your power converter/supply inside the TC or/and faulty cabling inside that has been worn out resulting in noises and flickering.
Dec 24, 2012 | Televison & Video
Weird sound coming out of the rotary unit inside gas heater
It may be your inducer motor making the noise. If there are any hoses hooked to the housing, make sure they are clear of blockage and moisture. Look for any way to drip a few drops of oil onto the motor shaft, it may help. If the unit is more than 10 years old, you might as well change the inducer motor as a precaution. It will fail at a most inconvenient time anyway.
Dec 23, 2009 | Goodman GMS90703BXA Heater
Strange noise coming from SUzuki SV650 front part of engine..
noises are tough to troubleshoot without being able to hear it. I don't know of any common problems, but Clymer sells a manual for SV 650's up to year 2002. If yours is newer, the manual may still be of some help because I don't think the SV's have changed much over the years.
Jun 18, 2009 | 2004 Suzuki SV 650
My kenmore refrigerator kept running.
from your description it sounds like your hearing the start relay trying to start your compressor. most likely this relay is bad and needs replacing.
Dec 18, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
78 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De GO PATS
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
