Question about HP Color LaserJet 2600n Printer
Cant remove the hp 2600 cartridge from machine
Hi im trying to remove my hp 2600 cartridge from the machine and it wount release on the right hand side.
Hi
i have the same problem, but i can´t fix it, i just get in a PLANE screwdriver onto the rigth side of the cartridge RETENEDOR and push the white piece to the rigth and at the same time push up too.. and after a few times, you can release the cartidges easily
I hope to i can help you, sorry but my english is too bad jeje
Regards from venezuela
Posted on Oct 07, 2008
Where is the ink cartridge located on the HP c3140 and how to I get to it?
From the manual:
Make sure the HP All-in-One is on.
Caution If the HP All-in-One is off when you open the print cartridge door
to access the print cartridges, the HP All-in-One will not release the
cartridges for changing. You might damage the HP All-in-One if the print
cartridges are not docked safely when you try to remove them.
2. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
3. Open the print cartridge door.
The print carriage moves to the far right side of the HP All-in-One.
4. Wait until the print carriage is idle and silent, and then lightly press down on a
print cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge
from the slot on the right.
Chapter 1
14 HP Photosmart C3100 All-in-One series
HP All-in-One overview
1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black and photo print cartridge
Jul 24, 2011 | HP PhotoSmart C3140 All-In-One InkJet...
I am getting an error code of 10.1000 in my 2600 n printer, I have tried changing the cartridge twice with no luck.
If this error occurs upon initial power-up on the printer, remove all cartridges to check for the orange packing tape. If present, remove it before reinstalling the toners.
Dec 23, 2010 | HP Color LaserJet 2600n Printer
How do I insert new ink cartridges in my HP 4385 all in one printer?
Buy a New model of printer... not that HP 4385... it so cheap yah...
Sep 23, 2010 | Computers & Internet
How to load ink catritridge #4&5
plz follow the steps below:
Step 1 Locate the "On" button located on the top right side of the Lexmark 2600 Series Printer Scanner. Turn the unit on by pressing and releasing the "On" button one time.
  • Step 2 Raise the scanner unit until it locks into place. Allow the print cartridge carrier to move to the loading position. Wait for the print cartridge carrier to stop moving.
  • Step 3 Locate the color print cartridge in the carrier on the right. Release the empty color print cartridge by pressing down on the cartridge carrier latch. Raise the cartridge carrier lid. Remove the empty color cartridge by pulling it straight up. Place the empty cartridge in the plastic bag and set aside for recycling.
  • Step 4 Remove the new color cartridge from its packaging. Remove the protective tape from the nozzle and connector on the back and bottom of the color cartridge. Dispose of the protective tape.
  • Step 5 Install the new color cartridge into the right cartridge carrier slot. Close the cartridge carrier lid. Press down on the cartridge carrier lid until it clicks into place.
  • Step 6 Raise the scanning unit slightly. Release the scanning unit support. Close the scanning unit.
  • If u find this post helpful, then plz vote it.
    Thanks
    Apr 27, 2010 | Lexmark X2600 InkJet Printer
    HP 2600 cartridge stuck in the printer
    This is most likely a broken part, It is probably the drive connection to the transfer belt.
    It's fairly common for these to break, and the part is not available as a spare (unless you strip one from another printer).
    Jan 29, 2010 | HP Color LaserJet 2600n Printer
    Cartridge housing out of position
    there is a solenoid at the right hand side of the machine when you open it you have to get a snall slat screw driver to release the solenoid then you will be able to spin the carousel
    Oct 12, 2009 | HP LaserJet 2550L Printer
    HP Photosmart 2600/2700 series all-in-one printer problem
    Check the expiration date on the cartridge, you may just need a new one. The date is printed on the side of the cartridge. They also just go bad sometimes.
    Aug 11, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
    HP 2600 Cartridge Jam on Right Side
    If they are locked in on the right side, the cartridge drive(s) are not being retracted when the front door is opened. There will be a broken part, which is difficut to obtain, and requires a major stripdown of the printer to find and repalace.
    It can be easier and MUCH quicker to replace the whole gear assembly on the right hand side of the printer. These ARE available, and can also be removed from another printer with other faults/damage which renders that one BER.
    Jun 17, 2009 | HP Color LaserJet 2600n Printer
    HP Photosmart 2600/2700/series all-in-one printer error message remove and check printer cartridge on the right when I had been using this cartridge for a while. I have cleaned the cartridge with...
    try to reset the HP Photosmart printer, power off, remove the main supply cable, leave it for 30 sec... and restart the printer...below link might be useful for more troubleshooting tips..
    http://etech.maiila.com
    Nov 01, 2008 | HP Computers & Internet
    I can't find my manual--model C4280-----I need to replace the black ink cartridge---I've got the door open and can see the cartridges---how do I release them to come out?? Thanks, Dennis Crawford
    To replace the print cartridges
    1.
    CAUTION: If the HP All-in-One is off when you open the print cartridge door to
    access the print cartridges, the HP All-in-One will not release the cartridges for
    changing. You might damage the HP All-in-One if the print cartridges are not
    4. Wait until the print carriage is idle and silent, and then lightly press down on a print
    slot on the left.
    If you are replacing the black or photo print cartridge, remove the print cartridge from
    2 Print cartridge slot for the black and photo print cartridges
    5. Pull the print cartridge toward you out of its slot.
    6. If you are removing the black print cartridge in order to install the photo print cartridge,
    store the black print cartridge in the print cartridge protector or an airtight plastic
    container.
    7. Remove the new print cartridge from its packaging and, being careful to touch only
    the black plastic, gently remove the plastic tape by using the pink pull tab.
    If you go here you can download the user manual.
    http://h10032.www1.hp.com/ctg/Manual/c00896316.pdf
    Jun 18, 2008 | HP Office Equipment & Supplies
    HP Color LaserJet 2600n Printer Logo
    133 people viewed this question
    Ben Johnson
