Question about Kitchen Ranges
We have a Neff B1432 Single Oven. The interior light has gone and needs the bulb changing. The instruction leaflet says to - Unscrew the lamp cover by turning anti-clockwise. It does not move . Help !
  • 1,462 Answers
They are often very stiff due to crud burning on. use mole grips and there is a risk you will break bulb cover but that is not the end of the world.
make sure you use a heat proof bulb as a replacement
Posted on Sep 30, 2008
Removal of interior oven light
Most require a simple 1/4" nut driver to remove 2 screws that hold the glass housing over the bulb. Then just unscrew the bulb and install new one.
Sep 06, 2014 | Neff B1421 Electric Single Oven
Common heating faults with Neff B1432 single oven
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Neff fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Neff B1432 Single circotherm plus Electric...
The light has gone in my neffu1422 oven and i can not unscrew it as described in the manual - answer please
Get a cloth and wrap it around pair of grips or similar, and grip the glass with the grips to unscrew the glass cover, do not apply too much pressure to the glass, as you will possibly break it.
If it still will not unscrew, then it may be neccesswery to break it to get it off.
Mar 08, 2010 | Neff B1432 Single circotherm plus Electric...
Oven will not get hot
you will need to replace main oven element it will have burnt out and gone open circuit just like a light bulb, they are easy to change and not expensive.
hope this helps
May 01, 2009 | Neff B1421 Electric Single Oven
Neff B1432 Oven Not Heating; oven light flickering
If the fan is working o/k then you need a new element fitting.
Remove the panel at the rear of the oven, there you will see the element, remove the fixing screws and ease the element forward,taking care not to lose the wires, disconnect the leads and fit new element.
The light flickering is probably the bulb not screwed in propely or a bad contact, nothing to worry about.
Plz rate my solution.
Dec 19, 2008 | Neff B1432 Single circotherm plus Electric...
Neff B1432 2002 Element blown
did you check the old element with a multimeter to make sure it is in fact faulty?
check continuity across the thermostat as well
Nov 28, 2008 | Neff B1432 Single circotherm plus Electric...
Neff cooker model b1422nogb bulb replace
Unscrew glass cover anti-clockise, likewise unscrew bulb, and replace.
Apr 28, 2008 | Neff B1421 Electric Single Oven
Change Bulbs in Neff U1661 Oven
You don't need to slide the oven out, just remove the glass covers with a flat bladed screwdriver and then unscrew the old bulbs. Replacement is the opposite.
Bulbs available from Homebase, Wickes, BandQ etc etc.
Apr 27, 2008 | Neff U1661 Double circotherm super...
Kitchen Ranges Logo
146 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
