I teach Algebra 2 some of my students calc will do the above problem but some of their calc give them a data type error when they ask it to write it like a fraction. The only difference I have found in the calc is that the ones that are not working are working with a 2.53 operating system. Is there anyway to get this to work.
For a moment I was puzzled by you question. After trying several configuration changes I finally figured out what the problem is.
You get the DATA type ERROR if you use the MathPrint templates (the two stacked squares).
In Math or Classic IO you can display complex fractions as fractions, just do not enter them through the template you access through the ALPHA F1 key combination. You can do that even for the older OS's (1.12 ). and with the number type set to REAL. Use the usual linear way. You do not need to set the calculator to CLASSIC..
The command [Math][1:>Frac] or ToFrac is a post operation, meaning you enter the numerator and denominator then press [Math][1:>Frac] then [ENTER]. the result will be displayed as a fraction (real or complex).
Here is what I get (18/ 13)-((27/13)i. If in MATH Print display mode, the real and imaginary parts are displayed as stacked fractions. I am using OS 2.56 MP for TINspire with TI84 keyboard. On OS version 1.12 the real and imaginary parts are displayed with the bar /. As to OS 2.53 MP Os I cannot say, because I do not have a calculator with that version. It is possible that OS 2.53MP has a bug, but I would not bet on it. By all means the sudents should uograded the calculator to 2.55 MP.
We have been using the math button not the F1 but we still get this message on calc. with a 2.53 operating system. This is what we have been typing in 9/(2+3i) , Enter, Math, 1, Enter. and I keep getting a data error. Do I just need to tell all these students to try updating their operating systems?
