I donot have a ethernet connection on my computer so I am trying to use a usb cord which does fit but I dont think the modem is responding or I need a driver for my computer. what can I do?
  • 6,487 Answers
In order for you to use the USB conenction from your modem you need to run first the setup CD for your modem because it needs to install the software for that modem so you can use it via USB...
Hope that helps...........
Posted on Sep 30, 2008
Can't connect using usb cable
Try using Ethernet. That is always the recommended way to connect to the modem, and it works almost 100% of the time without having to install additional software or perform any additional configuration. If you must use USB for some reason then you will need to make sure you have the drivers installed properly before connecting the modem to your computer.
Mar 31, 2014 | Siemens Speedstream 6520 Modem Router With...
I've got an Everex 3400+ and when I plug my cable in from my cable modem into the internal modem it's not showing that it's connected. Is there a driver I need to download. can you recommend a network...
Please dont connect a cable modem to an internal modem.
These are not the same types of device.
you need to connect from the cable modem to the ETHERNET port.
They look similar but ethernet is slightly larger.
Dont use a telephone cord for the ethernet connection it is the wrong one.
Sep 14, 2009 | Everex GA3400 Refurbished AMD Desktop...
Trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Jul 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Unable to set up wireless router
Shut down your computer, unplug the cable modem and the switch. Connect all three - computer to switch, switch to modem. Make sure that the ethernet cable between the router and the modem is in the router uplink port and that the computer is plugged into one of the four ports that look alike. Wait 30 seconds - plug in the modem. Wait another 30 seconds, plug in the router, wait another 30 seconds and boot the computer. Open a browser and see if you have internet access. If you still don't, then try to check the browser by typing 192.168.1.1 into the address bar of the browser. That should give you the browser sign in screen. The Linksys default is to leave the user name blank and type admin for the password. That should give you access to the router so you can check the settings. If this doesn't work, document carefully what happens and post again with your results and we'll try to go from there.
Jun 08, 2009 | Arris Touchstone 450a (CM450) Modem
How To: USB hookup for computer while having ethernet hookup to Xbox 360.
USB to PC is fine, make sure you have the original installation disk for it. Then you can connect the Xbox via network cable. There shouldn't be any problem as your modem can take 2 connections by the sound of it.
May 21, 2009 | Westell Wirespeed LiteLine 6100...
Cannot connect ot xbox live my ip address test fails
if you dont have a router, you can either have the xbox or the pc conneted to the internet, not both. you have to have an eithernet cord or a usb 2.0 high speed usb chord that goes directly from the xbox to the modem. you cannot go from the modem to the computer then to the xbox.
Jan 24, 2009 | Microsoft Xbox 360 Console
Toshiba Cable Modem PCX1100u
OK. First of all you do not need a special or seperate driver for the Ethernet port. Its factory loaded with your OS.
All you need to do is plug the Ethernet cable into the LAN port on your HP Desktop and then into the LAN port (not the WAN port) of your cable modem.
The second thing is if its only a cable modem, then I suggest you proceed with caution as there is NO built-in firewall on a cable modem. Yes you will get on the net, but you are likely to be attacked with virus the moment you connect. I suggest you check very carefully whether the cable modem (if that's what it is) does/does not have a firewall as you would be very unwise connecting up like that.
Next, forget USB connection to the router/cable modem. That technolgy we've moved on from.. Your Vista shodul be 'plug n play' adn should configure the router for you. obviously that bit isn't so slick on yours.
Let me know how you get on..
Aug 31, 2008 | Toshiba PCX1100U High Speed Cable Modem
Westell 6100 ethernet
the prob may b with the ethernet adapter on the computer or the ethernet port on the modem or the ethernet cable.....
to check ethernetadaptor  ping 127.0.0.1
to check the ethernet port on the modem...if u plugin the cable u should have a light lid up on the modem ..
to check the ethernet cable  try with an alt cable which is proved to be working
Jul 26, 2008 | Westell Wirespeed LiteLine 6100...
Ethernet vs. usb
FYI for those people trying to use a ethernet and usb cable from a cable modem - it may work for a while but it won't work forever - your ISP will only allow one IP address out of the modem unless you pay for additional addresses (then you need a switch). Each device you have on the modem is fighting for that IP and eventually it will just quit working (if it works at all).
If you want more than one computer on your network (on the Internet or sharing printers/files, etc) then you need a router or a gateway (cable modem/router combo which I DON'T recommend).
Feb 09, 2008 | RCA Thomson Digital Cable Modem (DCM305R)
X box live
yes you do need an ethernet cord to play xbox live also an internet connection and you can connect to your computer thats how i run mine cause i have a usb modem and it works fine no you dont need a modem but if you have more then 3 things in your home network it would be adviseable if you need to contact with help my email mid.nightlub@hotmail.com add me when you have xboxlive general joel458 see you online lol!!
Jan 01, 2008 | Microsoft Xbox 360 Console
Computers & Internet Logo
David Payne
David Payne
