SOURCE: Insignia NS LCD32 standby light blinking off and on. No Power
I had this problem as well. Actually best buy just left my hosue to fix it. This is the second time they were here to fix it. The first time they said a part was loose. This time they had to replace a part.
SOURCE: No picture, no sound, does light the insignia sign. Why?
In about 90% of the time the power supply is defective if the TV fails to power ON.
I repair these power supplies, if you need further assistance write to [email protected]
SOURCE: Insignia NS-LTDVD26 won't turn on
It is always recommended to ensure that your TV is powered down before connecting or disconnecting cables. Unfortunately, it is likely that your TV requires service for the power issue.
SOURCE: no sound from speakers on my Insignia NS-H2002
Very hard to know without actually seeing this first. You may have blown an internal fuse. Or, it simply may have died prematurely (if new and under warranty)
SOURCE: insignia NS-H2002-U have a a disc stuck inside the
Reset the player to factory defaults by power-cycling the unit (turn it off and unplug for several minutes), then try to remove the disk. More details can be found in the owner's manual. If the problem persists, I recommend returning with the unit to the place of purchase for further assistance.
