Question about Minolta Office Equipment & Supplies
C 0500 IN DI 152
How i can cancel code c 0500 in di 152
  • 145 Answers
Turn machine off hold down stop botton while turning on power ,hold down untel machine comes on
good luck
Posted on Oct 01, 2008
How to clear error code c0f32 problems by minolta Di152
replace the developer and drum , clear counter and run F8
Mar 24, 2015 | Konica Minolta Bizhub 180 Di 152 152f...
Error code sc23.03
Minolta Di 750 error code SC-23-01 i want solutions this code.
Sep 17, 2013 | Konica Minolta Minolta Di 650 Di 551 Di...
(C-0500) error code konica di 470
There is a trouble rest button inside the front door above the fuser unit. There is a small panel with one screw in it, remove the cover and you will see a PCB with two black switch's on it. One is the trouble rest button, have the copier ON and press the trouble rest button and close the door and you are done... If it will not rest, check what you did and make sure it is put back correctly.
May 06, 2013 | Konica Minolta Minolta Di450 Di470 Di550...
Minolta di 520 -malfunctioning code c 0500
Open the front cover to your left you should see a small access cover remove the bolt press the trouble reset button if the code comes back then have tech look at it below is a web site for parts, do not continue to reset the part you are resetting is the fuser the hot part could catch on fire that would ruin a perfectly good day
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
May 23, 2012 | Minolta DiALTA Di520 Laser Printer
Dialta di 152 error 0L ; i can not print and can't copy.
ol mean there's a door which is open, try to check ur front door and right side cover if its open, dn. if ok, there something wrong with the door swithc
Nov 11, 2009 | Konica Minolta DiALTA Di183F Copier
Minolta dialta di 250 error code 0500
Hello
E0500 means :"Fuser problem. Warm-up incomplete"
Feb 08, 2009 | Minolta Office Equipment & Supplies
Code C-0500 on Di 620
Try opening the front door with the copier on, on the right hand side you will see a small cover held on by 1 screw, remove this and press the reset button then close the door. If the error is still present it will return.
May 18, 2008 | Minolta DiALTA Di520 Laser Printer
Minolta Di 151
How to clear a C-0500 error code.SolutionHold down the [Clear/Stop] key while turning on the power.
For the Di151f, hold down the [0] key while turning on the power.
if the code comes back replace the fuser unit. DO not continue to reset the fuser can catch on fire and that will ruin a perfectly good day.
Oct 21, 2006 | Minolta Di151F All-In-One Laser Printer
125 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
