Question about LG RU-52SZ51D 52" Rear Projection HDTV-Ready Television
LG DLP Projection TV Green/Brouwn vertical Bar
We have an DLP Projection TV from LG Model RT44SZ21RB.
I replaced the lamp about 2 months ago and now suddenly a 3 CM brouwn/green vertical bar has appeared on the LH side of the screen.
It is kind of transparent but not clear.
Is there anyone who also experienced this and can suggest a way to fix.
I do not want to spent too much bringing it to a electrician since I am not completely happy with the TV nor with the LG support ( no LG for me )
  • CBR1100 Nov 13, 2008
    I took the TV to the repair facility since the so called light tunnel was collapsed. likely it is not too hard to replace it yourself but to get access is the issue you have to dismantle almost the whole TV so at the end got it fixed for 300 AU $ now picture cristal clear again.
    Thanks
  • 70 Answers
Hi there.
The excessive heat from your lamp has burned one or 2 polarizing lenses.
To replace this you have to pull the optic engine out of the unit and dismantle it.
You will see 3 square lenses in there, remove one by one until you find the burned one.
Then go to ebay and type in hoya polarizing lense.
Buy the 72mm one and cut it to size.
hope this helps.
Posted on Oct 15, 2008
LG DLP TV won't turn on
Your lamp has probably failed. You can buy a new bulb for under $100. http://projectorlamps.com/lg-zenith-dlp-tv-lamp-ru52sz51d-bulb.html RU52SZ51D Bulb LG Genuine High Quality Original Projector Lamps now...
Jun 01, 2015 | LG Televison & Video
After fixing a ballast lamp and color wheel how long would a tv last?
I have the same telly for the last six years and i only changed the lamp two weeks ago i think there a very good telly
Jan 20, 2013 | Samsung SP50L6HX 50" DLP HDTV
Tv turned off by itself, red light came on. when i turned it back on if had a flashing green light the turned solid green, there was sound but no picture, it turned off again within 2 minutes of turning it...
Tv probally needed a new tv projection lamp.This tv has not been change it projection lamp like 1 1/2 or 2 years already?Tv been on and used it like 4 or 5 hours everyday?Yes,than the tv flashing or solid on green LED light is on have a word "LAMP" written on it tv bazel frame?Yes,tv 100% require a new tv projection lamp replacement.
Aug 31, 2011 | Mitsubishi WD-73737 73 in. HD-Ready TV
No picture, siren type noise as restarting
My Toshiba dlp 62hm116 was used for 3 months then stored for 2 years, I turned it on yesterday and it makes a loud grinding noise which I think is probably from the exhaust fan area and the picture is black except white at both vertical sides. It worked fine the last time I used it 2 years ago. Any ideas?
Jan 13, 2010 | Toshiba 62HM95 62" DLP HDTV
Tv turns on and off 3 times before picture appears
Ballast Board its what turns Lamp on Call Encompass or visit their website. 1-800-638-3328
Dec 14, 2009 | Toshiba 56HMX195 52" HDTV DLP Projection...
Where is the projection lamp in an LG DLP TV, model RU-44SZ51D? How easy is it to install myself?
Hi,Lg lamps are usually in the back.This is your part # 6912B22007A you have to choose between the small square lamp with 4 corners and 2 ventilation holes or big and round lamp. Found it here: http://www.discount-merchant.com/SearchResults.asp?Search=6912B22007A Here's instructions to replace it http://www.youtube.com/watch?v=3hoaqR3jt1A God bless you!
Oct 07, 2009 | LG Televison & Video
Our L.G tv ( model RT-44NA11T)has color problems.
If your TV is not DLP, replace STK ICs convergence.will have part # ON THEM . Projection has 3 tubes a red/ a blue and a green TUBE ---DLP has 1 Lamp.
Sep 18, 2009 | LG Televison & Video
I have an LG DLP. that turns off after 15 -30 seconds
If the second light is blinking to orange or red, that is usually the lamp indicator light on an LG DLP tv. That indicates your bulb needs replaced, or something surrounding the bulb has failed (like the cooling fan for the bulb for example) IF you have a spare bulb handy, I'd replace the bulb, keeping in mind if you touch any part of a new bulb with your bare hands, you just cut the life of the bulb by more then half.
Jul 30, 2009 | LG RU-52SZ51D 52" Rear Projection...
My samsung dlp has no picture or sound. Model hls5066wx, power comes on lamp light flashes for 15sec and then the standby lamp comes on then it goes back to the lamp light flashing. It repeats this a few...
hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...
thank u!!!
rate me
Jul 12, 2009 | Samsung HL-67A510 67" DLP HDTV
Mitsubishi dlp does not get picture
the plug the connects underneath is not connecting right you have to get at the plug and seat it correctly
Dec 08, 2007 | Mitsubishi WD-52525 52" Rear Projection...
LG RU-52SZ51D 52" Rear Projection HDTV-Ready Television Logo
807 people viewed this question
Computer Repairing
Computer Repairing
