Question about Symbol LS2208 Handheld
Ean 13 problem
I have a problem reading EAN 13.I set all parameters to the default values and in barcodes starting with a number different from 0 it's correct...reads 13 characters..but if i have a 13 character's barcode starting with zero read's only 12 characters..skip's the first zero..why??
  • mkonstadakis Sep 30, 2008
    i am reading the characters in notepad..not excel...i think probably needs the country code to be changed..any ideas??
    New Friend:
If the leading digit that is being missed is a zero then the likelyhood is that the barcode is a UPC-A barcode (12 digit) but displayed as 13 by using a leading 0. You can convert the UPC-A barcode to a EAN13 on the MS9520 by using the setting that comes either in the 9520 manual or the start-up guide provided in the box. See Conversion of UPC-A to EAN13
Posted on Feb 15, 2013
Dear bluegreenash, the EAN 13 has 12 real characters..the first one(13 character) shows the country code and it's called "check digit".The default settings in the bar code scanner do not show the 13 character if the value is zero!!(zero is the code for US and Canada).So,by going to the configuration manual I scanned the setting that enables and shows the check digit character and the problem solved!!thanks for the help!!
Posted on Sep 30, 2008
  • 661 Answers
You are probably reading to a inteligent software package like Excell, which sees the inputted data as a number (so ignores leading zeros) you need to specify to the sytem that the incoming numbers are TEXT not numbers.
  • Gareth Cockram
    Gareth Cockram Sep 30, 2008
    hmmm, if that is the case then the Scanner is OUTPUTTING the data as a number instead of as TEXT, so the problem lies with the configuration of the scanner itself....
    look in the code book for any settings regarding how the data is interpreted and output by the scanner, it looks like the scanner is recognising as a number and truncating leading 0s there should be a setting that stops this.
    it should certainly be in the configuration of the scanner
Enable Leading Zero in Gryphon M130
Can you show us the printed numbers before going further?
Oct 05, 2014 | Datalogic GRYPHON M130 C Wired Handheld...
With our Scanner NCR7875 , we have problem with all EAN 13 digit barcode . its give starts with F and then barcode . like F123456789123. what to do ?
It seems like you have a suffix set on reading.
You should download settings manual, i'll guide you when you do that
Mar 11, 2014 | NCR 7875
Honeywell
Scan "do not expand ean-8 to ean-13" in your programming guide.
Jan 18, 2013 | Honeywell Voyager 1200g Barcode Scanner...
Im trying to get my ls2208 scanner to read comic book barcodes its 13 plus the 5 digit extension can i get some help with this. im running windows vista 64bit not sure if that matters or not.
Just take a Print out this PDF file and Scan the Barcode
1st u need to scan the enable Interface Barcode then Scan Any barcode Length
Cheers
Hope its solves
Sep 05, 2011 | Symbol LS2208 Handheld
Cannot find a way to configure ls2208 to perform expansion of upc-a to ean-13 barcode. I need this characteristic enabled in order to transmit a complete ean-13 barcode when it starts with a "0",...
http://www.fixya.com/support/t1857832-need_convert_upc_barcode_number_ean_13
have a look there. it will explain.
http://www.modul-bio.com/media/Symbol_LS2208_Manual.pdf
Oct 01, 2010 | Symbol LS2208 Handheld
I would like to transmit EAN-13 bar code without check digit, but closed by ENTER.
If you would like the LS2208 to transmit only the first twelve digits of an EAN-13 barcode followed by an enter you will have to write an Advanced Data Formatting rule using barcodes from the LS2208 Product Reference Guide found here: http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880806apdf&sliceId=&dialogID=114420371&stateId=1%200%20114410810
The barcodes you will print and scan in the order they are listed are:
Begin New Rule
EAN-13 (from the Critera pages of the ADF section)
Send Next 12 Characters
Send Enter key
Save Rule
If all other barcodes require an enter key make sure you scan Scan Options, Data Suffix, Enter (from the same manual or from the Quick Start Guide) before scanning the ADF rule above.
Jul 13, 2009 | Symbol LS2208 Handheld
We need to convert UPC-A barcode number to EAN-13
Most scanners will convert UPCA to EAN13 as you scan if you have that setting checked. A 0 will be added in front of the UPCA to make it an EAN13. Nothing else changes. You can read about this stuff on Wikipedia.
Mar 24, 2009 | Symbol LS2208 Handheld
GP5385 incompatible with EAN 13
Dear Akiong, Please try to reset your scanner configuration, using some utilities from it's manual book (usually available at it's case/box), restore it by scanning it to factory configuration,or scan a label that would enable all symbologies.
Aug 24, 2007 | PSC Quickscan GP5385 Handheld
Symbol LS2208 Handheld Logo
2,554 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
