Stylus760/u760 OLYMPUS 1. The zoom lens will not retract.
2. The Mode Dial is not operating from taking still photographs to
video, instead I am getting 4 lines of numbers: 5f08, 8234, 5f08
8234.
Wonderful. Share a website with you , (http://top4biz.com) Believe you will love it. credit card and f ree s hipping. I bought two pairs. Cheap, good quality, you can
go and ship with there
You have either experienced a lens error or your zoom dial is broken (both usually caused by some sort of impact damage, but which can be spontaneously occuring).
Look for an error message on your camera's LCD screen such as "E18," or "lens error restart camera." If you do not see a lens error but simply cannot retract your zom lens (go into wide angle mode) via the zoom lever then it simply maybe a broken command dial. Either way, however, you will need to have the camera serviced in all likelihood. Call tech support at 1-800-828-4040 M-F from 8 am to 12 midnight EST and Saturdays until 8 pm EST. Hope this helps.
We had this problem for about 2 weeks, we discovered that having the camera auto retracted after the "ZOOM ERROR" message, giving the camera couples of light slaps (slap the camera's LCD side and aim the camera down), this fixed the camera right away
The unusual beeps usually occur when the lens cannot be extended or retracted, often due to dirt in the gearing or the lens cap being left on.
Try using canned air to blow around the outside of the extension cylinder, and, putting a fresh set of batteries in the camera (it probably got stuck on since it couldn't fully retract the lens and didn't complete the shutdown).
If that doesn't work, try taking it to a camera store with repair technicians and having them take apart and clean the lens extension/retraction mechanism.
The small gears that link the viewfinder and lens may be out of sync.
If you are a technical person, you can remove the frontcover, first taking off the topcover, (one screw is hidden under the mode dial). Power up the camera and remove the batteries when the lens is fully extended. BE CAREFUL NOT TO TOUCH THE CAPACITOR!
Gently lift the viewfinder and move the viewfinder gear one tooth. It will probably only move one way.
Put the batteries back in and try the lens. If this does not solve the problem, you may need to replace the lens or viewfinder.
The D-460 Zoom shares the following features with the D-450 Zoom:
•1.3 megapixel resolution - 1280 x 960 pixels
•Olympus 5.4mm to 16.2mm (equiv. to 35mm to 105mm on a 35mm camera) lens: all-glass, 8 element, 6 groups, 2 aspherical lenses
•Automatic TTL focus system
•Macro mode allows the camera to auto focus as close as 8 inches
•Automatic aperture selection: f2.8 to f8.0 wide, f4.4 to f12.6 tele
•2x digital telephoto mode
•3x image magnification inspection mode
•Sequence mode: Up to 10 images at 2 frames per second intervals (SQ mode only)
•Panorama mode: Allows multiple pictures to be "stitched" together to create wide views
•NTSC video output to TV
•12-second self timer
•8 MB SmartMedia card included
•Built-in, pop-up intelligent flash: Auto low & backlight, red-eye reducing, off, fill-in, slow-sync
•Automatic white balance control or 4 manual settings (daylight, cloudy, tungsten light, fluorescent light)
•Automatic ISO sensitivity or manual selectable ISO settings (125, 250, 500)
•Uses 4 AA size batteries. AC Adapter is available as an optional accessory
In addition, the D-460 Zoom has the following functions and features:
•Industry standard icons for button labels and operation menus
•Easy to use jog dial and button design allows easy menu navigation
•2 compression ratios are now selectable in SQ mode
•Selectable Sharpness: Normal or Soft
•Selectable Memory Mode Setting: Reset camera settings at power-off or Retain all camera settings
•2 Olympus brand CR-3V long life lithium batteries included. Provides 20-30 times the power/life of alkaline batteries
