Question about Apple iPod classic MP3 Player
Ipod doesnt work
My ipod doesnt start if i charge for 6-7 hrs
  • 2,071 Answers
Did you try charging it with the USB cord or do you have an adapter that plugs into the wall? If you tried with the USB cord, how long did you let it charge?Did you plug cord directly into computer or do you have external USB hub?Many times the hubs will not have sufficient power to charge.Was your computer"go to sleep"after a while.The ipod will only charge while the computer is awake.
There are a variety of things that could be wrong. If the Ipod sat for a long time the battery could be completely discharged. I've not had this problem on the Nano, but on an old Ipod Mini my sister has. I've noticed that sometimes I need to plug it in with a wall adapter to get the battery charged enough to start up quickly. If the battery is completely discharged,it can take 30 minutes or longer to see any life from the ipod. I would let it charge for few hours if you can then try the reset.
Forgive me for asking this next question...lots of times I ask these basic question and people get mad, but the key lock is off, right? On my Nano there's a small slider switch on the top. In one position the controls are all locked. Please verify that you've got it set to the right position. Mine is locked when I can see the red dot.
Assuming the battery is not totally shot and the key lock is off, it's also possible that it's just "locked up". To reset the Nano press and hold both Menu and Select (center button) for about 5 or 10 seconds. If the Ipod is alive this will reset it.
From your post, I'm not sure if you mean the Ipod was sitting for a long time without being used. If that's the case and it used to work, and it has not gotten wet or anything, then the most likely problem is a bad battery. There are services on the web you can find who will replace the battery for a fee. If, on the other hand, it just suddenly stopped working and the reset does not help you may have a more serious problem. Unfortunately there's no way to tell.
Hope this may help you;
Regards,
VOTIT
Posted on Sep 30, 2008
Ipod shuffle won't connect to itunes and is not visible in my computer
charge it up fully, or leave it plugged into the charger for about 3-4 hrs then try again. sometimes it doesnt recognize the device if there isnt enough battery power
Mar 08, 2011 | Apple iPod shuffle 3rd Generation MP3...
4GB A1199 not charging... double checked USB port, cable, power source etc... Any way or anyone run diagnostics on iPods?
try restarting it by holding ceter button and menu button for 6 sec.then plug it again..if that doesnt work try a different charger
Apr 01, 2010 | Apple iPod nano
My green Apple Nano Chromatic iPod's batter life & other problems
turn the backlight down or maybe let it charge even when the battery says its fully charged!
Dec 15, 2009 | Apple iPod nano MP3 Player
My apple ipod shuffle blinks orange after 6 hrs of charging
1) Get the latest version of iTunes and install it.
2) connect your ipod, select restore.
3) sync your ipod.
Jan 30, 2009 | Apple iPod shuffle Second Gen. Silver (1...
Charging time
I called Garmin re this question. They said about 4 hrs in the car, about 6-8 on the computer. I left mine plugged to the USB port overnight and have a full charge. BTW Radioshack sells an AC adapter for about 30 bucks. If if also works for the latest iPod I think I will go with it. 4hrs.. says Garmin
Dec 28, 2008 | Garmin nuvi 250W GPS Receiver
Ipod wont work
Ok, Not to worry... Try this out and let me know?
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Dec 27, 2008 | Apple iPod nano
Dead ipod
get a new battery :)
that's fine if you have to replace it. you can get em anywhere.
you can ither order the battery and install it yourself, or send it in, and have someone else do it
Sep 30, 2008 | Apple iPod classic MP3 Player
My ipod doesnt turn on and nothing works... it doesnt charge and when i plugg it to the computer nothing comes up on itunes so i cant even restore it or anything, ive tried everything... please help
hi,
1. Make sure the Hold switch is off
2. Make sure the battery is charged
3. Reset iPod
4. Let iPod's battery drain
5. Update iPod's software
6. Make sure iPod is the only device in your FireWire or USB chain. Disconnect everything but the mouse, keyboard, and your iPod, then see if it will turn on.
7. Make sure you are using the FireWire or USB cable that came with your iPod, and that the cable is in good condition.
8. Try connecting iPod to the built-in port of a different computer to see if that works.
IF all the above is checked and if ur ipod still remains same please take it to an apple store and check with them!..thank you!!..
Jun 11, 2008 | Apple iPod nano
IPOD Video 30gm
Hold down on the center button while hold down on the menu button. The apple logo will appear. Your Ipod is now rebooted.
Is the new battery fully charged? Usually it takes 6 hours on a new battery.
Jun 08, 2008 | Apple iPod MA446LL/A MP3 Player
Apple iPod classic MP3 Player Logo
54 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
