HP Workstation xw4400 Beep Codes
My infant son repeatedly pressed the power button, now when I press the button all I get is 4-4-4-4-4 beeps. I removed and unplugged everything one at a time and still get the beeps. The only thing I didn't unpulug is the fan that isn't spinning do you think this could be the problem. If not then what.
Thank you
    Genius:
  • 1,226 Answers
Unplug all the computer from the wall outlet and then..open the CPU (computer system) Try to remove the memory and then clean and insert in again and then test
Hope this an initial help,
tell me what so ever happen.
melnavz
Posted on Sep 30, 2008
  • 1 more comment
  • Ronesh Prasad Sep 23, 2010
    Hi melnav
    Is it possible if the user removes all the power connections and then starts the pc and then after that plugs the connections back and then power on the PC.
  • NOAH BANIRE
    NOAH BANIRE Feb 19, 2014
    i did remove the memory and cleaned it but the beeping still continue.
  • NOAH BANIRE
    NOAH BANIRE Feb 21, 2014
    i have gotten the solution now is the power connection box .
My Panasonic inverter split zircon with r410a blinking the red timer running indoor motor while out door unit not running?
To display memorized error (Protective operation)
status:
1. Turn power on.
2. Press the CHECK button on the remote controller
continuously for 5 seconds.
3. "- -" will be displayed on the remote controller display.
Note: Display only for "- -". (No transmitting signal, no
receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote
controller. The code "H00" (no abnormality) will be
displayed and signal will be transmitted to the main
unit. The power LED lights up. If no abnormality is
stored in the memory, three beeps sound will be
heard.
5. Every press of the button (up or down) will increase
abnormality numbers and transmit abnormality code
signal to the main unit.
6. When the latest abnormality code on the main unit
and code transmitted from the remote controller are
matched, power LED will light up for 30 seconds and
a beep sound (continuously for 4 seconds) will be
heard. If no codes are matched, power LED will light
up for 0.5 seconds and no sound will be heard. 7. The breakdown diagnosis mode will be canceled unless pressing the CHECK button continuously for 5
seconds or operating the unit for 30 seconds. 8. The same diagnosis can be repeated by turning
power on again.
To clear memorized error (Protective operation) status after repair:1. Turn power on.
2. Press the AUTO button for 5 seconds (A beep
receiving sound) on the main unit to operate the unit
at Forced Cooling Operation mode.
3. Press the CHECK button on the remote controller for
about 1 second with a pointed object to transmit
signal to main unit. A beep sound is heard from main
unit and the data is cleared.
• Temporary Operation (Depending on breakdown status)
1. Press the AUTO button (A beep receiving sound) on
the main unit to operate the unit. (Remote control will
become possible.)
2. The unit can temporarily be used until repaired
Apr 24, 2017 | Panasonic Heating & Cooling
HP xw4400 workstation wont boot/start if RAM are inserted.
If you are increasing the RAM from 1Gb to 2Gb then the RAM maybe incompatible. Try using a RAM module as the original make and speed.
Try installing one RAM module at a time to see if one of the RAM modules is faulty.
Removing the RAM will give a POST error code of no RAM or faulty RAM.
Feb 25, 2013 | HP xw4400 Workstation - 1 x Intel Core 2...
Cannot install new hard drive on HP xw4400 Workstation
Check the to see if its in master or slave configuration.Also a great boot tool is Hiren's BootCD and here the link below.If you a tech to call you for a step by step help go to our website and the that link is below as well and take care.
http://www.hirensbootcd.org/download/
http://www.ezsystemrepairs.com/
Nov 08, 2012 | HP xw4400 Workstation PC Desktop
I receive 9 beeps on power up of a HP xw9300 workstation. It keeps repeating. What does 9 beep codes mean for this pc type
rholinga:
According to this PDF file that appears to be a troubleshooting guide for this workstation (click here), This means:
1. Replace the system board. 2. Replace the processor.
Thank You for using FixYa.
Feb 14, 2011 | HP xw9300 Workstation PC Desktop
I did everything except this time now it says "
Try a Restore
PS3 Recovery Menu
  1. Place the PS3 in standby mode
  2. Press and hold the power button for a couple of seconds, you should hear a beep
  3. Keep a hold of the power button for a couple more seconds, the PS3 should shut back down to standby mode
  4. Once this happens, press and hold the power button again for a couple of seconds, waiting for 1 single beep.
  5. Ignore this beep and keep it pressed until you hear 2 consecutive beeps, release the button.
Try restoring the file system (Option 3), then repeat with rebuilding the database (Option 4).
Feb 10, 2011 | Sony Playstation 3 (PS3) Console
How do i turn up volume on hp officejet all in one
Adjust the volume
The HP All-in-One provides three levels for adjusting the Ring and Beep Volume and
the Phone Line Monitor Volume.
The ring volume is the volume of the phone rings. The beep volume is the level of
button press and error beeps. The default Ring and Beep Volume setting is Soft.
The Phone Line Monitor Volume is the volume of dial tones and fax tones. The
default Phone Line Monitor Volume is Medium.
To adjust the Ring and Beep Volume from the control panel
1. Press Setup.
2. Press 4, and then press 4 again. This selects Basic Fax Setup and then selects Ring and Beep Volume.
3. Press to select one of the options: Soft, Loud, or Off.
4. Press OK.
To adjust the Phone Line Monitor Volume from the control panel
1. Press Setup.
2. Press 4, and then press 5. This selects Basic Fax Setup and then selects Phone Line Monitor Volume.
3. Press to select one of the options: Medium, High, or Low.
4. Press OK.
Trust this is helpful. Please vote. :)
Dec 14, 2010 | HP Officejet 4355 All-In-One InkJet...
How to enter radio code for siemens vdo c500
It is showing SAFE because wrong codes have been entered.
To restore, leave SWITCHED ON...UNDISTURBED for as long as it takes to automatically reset itself (usually an hour or two.)
Code Entry Instructions
Switch the ignition key ON
Press and hold AS button * and the ON button at the same time
Display Shows SAFE then goes to 10 - - - - with a "Beep" from the speaker
Press Preset Button " 1 "repeatedly until the 1st Digit of your Code is displayed
Press Preset Button " 2" repeatedly until the 2nd Digit of your Code is displayed
Press Preset Button " 3" repeatedly until the 3rd Digit of your code is displayed
Press Preset Button " 4" repeatedly until the 4th Digit of your code is displayed
If the display now shows the correct Code number then
Press Button AS and hold to Enter and if successful there should be a "Beep" from the speaker and the radio should switch on
May 22, 2010 | Car Audio & Video
How do I replace a battery?
Remove upper plastic panel by grasping sides near the bottom. Pull hard, rocking a bit. Replace 4 AA batteries (smooth negative end of battery should touch each spring). To set up codes: Press black button on electronic panel, enter first code (4-8 digits), then press lock button to set code. You should hear a 2-second beep. Press black button twice, enter second code, then press lock button. You should hear a 2-second beep. To test codes: Press lock button, then enter code. Lock should retract. Repeat for second code. If both codes are working, replace plastic cover over electronic panel. Position top of cover, then snap bottom of cover into place.
User manual is here:http://www.weiserlock.com/PDFs/install_sheets/pb_eng_install.pdf
Jul 15, 2009 | Weiser Lock Powerbolt 1000 Lock
Computers & Internet Logo
1,699 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
