Question about Refrigerators
I have a Fisher & Paykel fridge/freezer model N500B a CFC model with the freezer below the fridge. We have started to get a frost biuld up at the top of the back wall of the fridge compartment. A registered repair man has suggested it is a know Fisher and Paykel problem and can only be temporarily addressed by melting the ice build up with hot water and/or a hair dryer. The build up seems to be increasing and i don't like the idea of using a hair dryer..doesn't seem to be a fully safe thing to do. Dave
    President:
  • 1,462 Answers
Using a hairdryer is ok. don't let water drip on it and don't point too close to plastics
ice build up on fridge wall can be due to:
short of gas
partial blockage in sealed system
compressor starting to fail
stat switchback temp wrong
insulation failure
Posted on Sep 30, 2008
Fisher & paykel fridge e521t no power to fridge,not any power coming to fridge
Did you try an other electrical outlet? Can you test the outlet has any voltage?
does the fridge have an on / off switch? I don't think so, so if nothing works also check the cable and the plug going in the outlet.
Mar 17, 2015 | Fisher & Paykel Paykel E521TLX2 Fisher...
F & P N500B Fridge Freezer Not working at all
Gas problem not worth reparing if this is the case.
Oct 05, 2014 | Fisher and Paykel Refrigerators
Fisher and Paykel N500 B fridge vegetables in vege tray are frozen
it sounds like your thermostat is not working it may need to be replaced.
May 16, 2014 | Refrigerators
Fisher & paykel active smart fridge not keeping cold
Do you see any ice buildup on the back wall of the freezer or behind it?
Nov 28, 2012 | Fisher and Paykel Active Smart E522B...
I am looking for crisper bins for a F & P N500B fridge
Here is a parts store you can call 6 days a week and order any part you need I did not find that model listed but you can talk and find the number. here it is and hope this helps thanks for using fix-ya.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=E522B
Jan 24, 2010 | Fisher and Paykel Active Smart E522B...
Fisher and Paykel N500B fridge freezer. Freezer not freezing
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Oct 28, 2009 | Refrigerators
Lights on but fridge not working on Fisher and Paykel N500B
There could be a few reason 1 you may have a faulty temp control switch try taping it to see if it kicks on.If that does not work remove the compressor start switch shake it to hear any noise like pieces burnt in it.If not try advancing your defrost timer to see it kicks on also.If those do not work you may have an elecrical problem.
Jan 18, 2009 | Whirlpool ED2GHEXN Side by Side...
Refrigerators Logo
320 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
