Question about Soyo DYLT032D 32 in. LCD Television
TV volume increases by itself and doesn't decrease or respond to the remote control
My philips TV volume just suddenly while watching TV increases by itself up to 100 (the highest) and when you try to use the remote control to reduce the volume, it doesn't respond at all. So I switch it off from the mains and switch it on again. Sometimes, it comes on and is normal, sometimes, it still stays up. In fact, you can see the blue light flashing as though someone is using the control to increase the volume. If you leave it for a while, the light may stop flashing and you can reduce the volume with the control. Other times, no matter what you do, it's uncontrollable with the control. Please note that the only part of the TV affected is the volume.
I'd be VERY grateful for some help! the volume goes up by itself and stays at maximum and will not stay down. the tv is out of warranty by one day and parts are not available. is there any way i can use a home theater speaker system to control the sound? it has nothing to do with the remote. condello@mts.net i am in canada
thank you ruth
I have the same problem, also with a Philips TV
  • 1,879 Answers
Connect all A / V sources to the Home Theater Receiver then Video-Out from the receiver and totally mute) the TV.
Posted on Sep 30, 2008
The volume control works to decrease volume but is very difficult when trying to increase volume
This may be an issue with the button itself getting caught on the plastic bezel of the remote. Sometimes this happens when the remote is dropped or the plastic bezel is nicked.
My recommendation is to reprogram the device you are trying to control the volume of. This issue may occur when the incorrect IR code is programmed into the remote. Some IR codes may work intermittently and as rolling codes. Check the program and respond if problems persist.
Jul 27, 2011 | Logitech Harmony 890 LCD Remote Control
I have a 42PC5 LG Plasma, and the problem is that the TV Remote control and Buttons (on the TV) are not working/responding. The only way to close the TV is by plugging out the Electricity Cable, and when...
i think that there is a shorted buttons or in normally close position, try to press each buttons slowly and you will feel something that is ticking if one of the buttons does not tick it is damage it is in normally close position that will be the cause of the problem. specially check the volume button.
Jul 02, 2011 | Televison & Video
LG TV 32H3300 - volume increasing and decreasing by itself. It will increase if it was turned up via remote last and then will decrease by itself when volume is decreased via remote because it was too...
The cause of the problem is that the switch of your tv is dirty when cleaning it you must be familiar to the unit and the parts you will remove to prevent any damage you can use a contact cleaner, when applying a contact cleaner you must only spray it to the switch. Consult a expert technician to do it for you actual.
May 15, 2011 | Televison & Video
Remote control will not decrease volume. it will increase volume though. Sanyo HT27546 TV
Check to see if it will decrease on the TV itself,install fresh batteries, mash the down button on the remote applying a little pressure, button may be stuck. hope this helps..
Mar 25, 2010 | Sanyo HT27546 TV
Toshiba volume increases by itself
This model do have a Remote Control right? Try to check that out... the remote could be the one setting the Volume up suddenly.
Mar 16, 2010 | Microsoft Windows XP Professional With...
We cannot increase or decrease the sound. There does not appear to be a volume control on the set and it does not respond to the remote. The remote is working in all other respects.
Make sure the speakers are turned on in the audio menu. Usually when the speakers are turned off the set goes into a fixed sound level at the audio output jacks. These jacks are used for external amplifiers, etc. Hope this helps. Thanks
Oct 28, 2009 | Philips Magnavox 27MS343S 27" TV
I have a new Philips tv that did the same thing on me I left it off for a couple of minutes and that seems to work
Dec 27, 2007 | Philips 42FD9954 42 in. Plasma HDTV
Toshiba 42H82 remote problem
Bad volume down tactil switch? Remove suspect switch and see----
May 29, 2007 | Toshiba 42H82 42" Rear Projection...
Soyo DYLT032D 32 in. LCD Television Logo
1,094 people viewed this question
Top Soyo Televison & Video Experts
ted dux
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
