Ovens Logo
Patricia Langton Posted on Nov 29, 2011
Bottom Oven Fan on Whirlpool AKP951 not working properly
Bottom oven not reaching and maintaining temperature. I have now discovered that the fan is only working very slowly and making a strange noise.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Nov 29, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
0
Helped
5606
Points
8
Sounds like the fan is locking up and not turning all the time. If it is a howling sound the fan will have to be replaced.
Tricity Bendix SE556SV lower oven not reaching tempature, new element, themostat and fan
First need to see if supply voltage is correct.
Verify oven probe sensor to the thermostat Is working properly? (usually done by Ohm test)
Thermostast offer an option for calibration?
Also have you verified actual oven temperature with an external thermometer?
Jun 09, 2015 • Ovens
1helpful
I have a double whirlpool fan oven. The fan doesn't always work, seems to stick. What do I need to do to get it working? We've had it less than 3 years but I've never cleaned it. Is this why it doesn't...
Do you mean the fan inside the oven box in the back wall. This is the fan for the Convection bake etc. If so this is how it works..
a) Bake feature - that fan does not come on
b) Convection bake - that fan comes on during bake cycle
So that fan works for several features but not for all. It helps to circulate the hot air inside better for a more even, fast bake.
Do you mean the fan in the control board area. It is there to get the hot air trapped in the oven walls out. Not the heat inside the oven bake box area. This fan works differently depending the model and/or brand. Some models fan works from the time you start. Some models fan comes on only when that area reaches a certain high temperature.
We bought a deDietrich oven UMP412 (Ser No 02-24-06004) on 31/08/2002. Recently the heater behind the in-oven fan blew and was replaced together with the lower heater (which was found failed) and main...
Hi Maurice.
Circulating is Fan Assisted mode. In this mode the fan kicks in when temperature is reached and runs all the time.
Here an extract from manual.
There is no preheat unless you set temperature. That is why you get the fan from start.
1helpful
My Neff eletric oven works on top and bottom heat, but does not heat up on the fan setting fan. It heats slightly and the fans works but it does not reach temperature.
You need to replace the oven element
This is located at the rear of the oven compartment behind a removeable cover, it is usually circular in shape
4helpful
Looking for a manual for Whirlpool BS0801/WH oven
I have a paper copy of the manual - if you need to know anything more than the information below post a more specific question.
The function symbols on Knob F, clockwise from the top, are as follows:
  • 0 = Off
  • Lamp symbol = Lamp Only, no fan, no heating.
  • Fan + Drip Symbol = Lamp + Fan, but no Heating - this is for defrosting.
  • Fan inside a Circle symbol = Lamp + Fan + Oven Heating - this is the normal cooking position. The temperature of the oven is set on the Temperature Knob.
  • Final position = Grill. The temperature of the Grill is set on the Grill knob.
The red indicator light only comes on when the Oven is heating (not the Grill), and goes off when the oven has reached it's set temperature.
The bulb is 25W 230V Type E-14 300 Degree C.
The oven draws a maximum of 2300W so requires a 10A supply.
Nov 29, 2010 • Ovens
3helpful
2answers
My oven turns off on me after only a minute never heating up fully
Could be caused by either of following;
1. Faulty thermostat.
2. Faulty thermal cut out switch. (controls power to cooling fan).
3. Faulty cooling fan (not fan inside oven).
Test thermostat by setting thermostat to low temperature like 60 oC. If oven gets much hotter then its a faulty thermostat.
To test cooling fan and thermal switch take oven out and remove top or rear panels to expose components.
When oven gets hot the cooling fan should turn on. If it doesn't then check to see if there is a mains voltage present.
If mains current exist but fan is not turning then replace fan. If mains voltage is not present then its the thermal switch.
3answers
Oven doesn't maintain temperature
When an oven doesn't maintain the set temperature, first make sure no one is allowing the heat to escape by opening its door. If not, the oven control either needs to be re-calibrated or replaced. To have the control replaced, call an appliance service person.
Top Whirlpool Ovens Experts
ZJ Limited
ZJ Limited
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
