Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
My Xbox 360 Says No Wireless Network, 192.168 takes me to ask.com!
My Xbox 360 wont connect to live because there is no wireless network, but my laptop works fine, and the code takes me to ask...
Does Anybody Know Belkins Code? (Im With Tiscali)
Thanks
    Scholar:
  • 89 Answers
I believe you are referring to the network key set on the Belkinrouter. Since you do not have the code, you will have to access yourrouter's web interface.
Let's begin with your router:
Using your working laptop, open Internet Explorer type 192.168.2.1 (default IP address of Belkin routers) press Enter. It will ask for a username and password - by default it'sadmin for both. If it does not accept admin, type in the username andpassword you set to your router when you installed it for the firsttime.
Once you open the setup page of the router, go to the Wireless tab ofthe router (located on the left side of the web interface. Look forSSID and WEP key or Network key (SSID is the name of your wireless network). Take note of the SSID and WEP keybecause you will need to set this on the XBOX console.
On the XBOX:
Open the dashboard settings - select Network Settings. Configure your XBOX to connect to your wireless network. When it ask for the network key - type in the code that you will see on the router's web interface.
Try the steps I mentioned, give us an update and I'll reply ASAP if you need further assistance.
Good luck and have a nice day!
Posted on Oct 01, 2008
Xbox360 live setup
You need to forward these ports on both your router, and computer aswell as firewall you got one of those.
  • Port 88 (UDP)
  • Port 3074 (UDP and TCP)
  • Port 53 (UDP and TCP)
  • Port 80 (TCP)
You might aswell need to open 1863 (UDP and TCP) if you want to use video chat for the kinect.
Listed ports need to be forwarded when connecting to XBOX Live
A more detailed guide to setting it up is available here: http://support.xbox.com/en-us/xbox-360/networking/network-ports-used-xbox-live
Nov 15, 2013 | Netopia 2247NWG-VGx Wireless Router...
Having trouble connecting Xbox live. Have wireless router and wireless Xbox 360 adapter. Figured out where adapter goes. Now I'm stuck.
Is the router already setup and working? Do you have anything else that successfully connects to it "wirelessly", like a laptop or desktop or smartphone? If the answer is yes, here's how to setup the 360 to connect to your router:
1. Turn on the console and navigate to the wireless settings screen. On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings."
2. Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.
3. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)
4. Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead.
5. Save your settings and verify the network is functional. On the Xbox 360, use the "Test Xbox Live Connection" option.
Tips: Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.
What You Need: Active Xbox Live subscription (to access services)
edited from here: http://compnetworking.about.com/od/wifihomenetworking/ht/xbox2wifirouter.htm
Mar 05, 2011 | D-Link DI-624 Air Plus XtremeG Wireless...
I have a belkin router and 2 xbox 360 connected to xbox live. whats the settings to have on the router which allows both of us to play multiplayer on games? at the moment one computer kicks us off live...
Once you have all the wireless settings of the router, you are ready to connect the play station or the x-box to the wireless network.
X-BOX
On the x-box you will need to connect to the wireless network now.
Open the main Interface of the X-Box.
1. In the Xbox Dashboard, go to My Xbox and open System Settings.
2. Select Network Settings, Configure Network.
3. On the Basic Settings tab, select your wireless settings.
4. Select the name (SSID) of your wireless network. If your router isn't broadcasting your network's name, select Specify Unlisted Network and enter the name.
5. If your network has wireless security, enter your WEP or WPA key.
6. Try to connect to Xbox LIVE again.
Trouble connecting to the internet on X-box ,Play station or WII ?
You can try to reduce the MTU settings on the router. if the MTU on the router is set to 1500 then change the MTU to 1365. Also you will need to open the ports on the router.
For X-box port numbers are - 53, 80-88, 3074 .
Jan 23, 2011 | Computers & Internet
My xbox 360 says im connected to xbox live checked network setings and it says xb ox live is up and running...however when i try to play need for speed online..it says xbox live not working functionally?...
Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings." Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.) Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP. Save your settings and verify the network is functional. On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live. On the Xbox 360, use the "Test Xbox Live Connection" option instead.
If you need more help post back! Thumbs and testimonial are welcome!
Jan 15, 2011 | Computers & Internet
Cant connect Xbox 360 to this wireless router
Jan 15, 2011 | Linksys WRT160N Wireless Router
Want to set xbox on line havnt got a clue
If you have an original Xbox the online capability is obsolete and will no longer be supported by Microsoft if you have an Xbox 360 you need to purchase an xbox live account either at a retail location or online through your xbox dashboard (internet and credit card required). You need to connect a network cable to the back of the xbox the other end to your router or modem to access Xbox live. They also sell a wireless network adaptor for the 360 that you can use instead of a wired connection.
Jan 27, 2010 | NetGear WGR614 Wireless Router
Xbox live on netopia router
Okay, to connect to Xbox Live using Wireless Internet you will need this:
One Xbox Wireless connection unit, There are two types, the black and white versions. The black one is able to pick up the most diverse signals and has a higher potential for speed so I recommend that one.
You will also need, of course, a high speed internet source (modem) and a wireless router connected to the modem. When looking for wireless routers look for ones with marks claiming to be compatible with Xbox Live or a Windows OS. Those have been tested to work with Xbox.
Before trying to set up your Xbox Live, make sure your Router is set up with your computer, and set to be used as a wireless router. That's another tip all together but just follow your installation CD.
Okay so here we go!
First, Connect the wireless networking adapter to the back of your Xbox.
If you have a network cable plugged into your xbox, unplug it. Check to make sure the adapter's light is on.
Here's what the light's mean:
On the gray adapter:
No light: It's not getting enough power( try plugging it another USB slot)
Green light: It is connected to a wireless router, gateway or wireless access point.
Red light: It is not connected, and is ready for configuration.
Flashing red: There is a malfunction. (try again, if the problem persists return it for a replacement)
On the black adapter:
Green light: It is connected to a wireless router2_bing.gif, gateway or wireless access point.
Flashing green: The adapter is attempting to connect to a wireless router, gateway, or access point.
Now the CONFIGURATION, the reason most of you are reading this:
Turn your Xbox on and go to "My Xbox"
Go to "System Settings"
Go to "Network Settings"
Go to "Configure Network"
On the basic settings tab select "Wireless mode"
Select "Scan for Networks"
Select your Wireless source.
NOTE: If your Network isn't listed you will have to manually enter it.
To do this select "Specify unlisted network"
You will need to enter your SSID
Then choose which security you used to set it up on your Computer (ie: WPA, WEP...) Then enter your security code. If there is no code then select "no security"
Your adapter should have a green light now.
Now go back to "Network Settings" and select "Test Xbox Live2_bing.gif Connection"
If it works your good to go!
If not read visit: http://support.xbox.com/support/en/us/Solutions/wizardhost.aspx?wizardid=xlcsv1
Hope this tip helps :) Tell your friends and ratings are nice. Just kidding, I just hope I helped.
Jan 10, 2010 | Netopia 2247NWG-VGx Wireless Router...
How to connect to XboxLive via 1800HG 2WIRE+Linksys adaptor?
The easiest way to connect to Xbox Live without using your pc is to buy a
wireless network adapter for your Xbox.
You would then go into the system settings on the Xbox and configure the settings for your wireless network.
http://www.xbox.com/en-US/hardware/x/xbox360wirelessnetadapter/
Xbox 360 - direct to internet - No PC.
Jul 31, 2009 | 2wire 1800HG Router (RG1800HG00)
Xbox live cannot connect to network
I would suggest power cycling it, both the xbox and the router, sometimes routers can be funny with there connections.
Jun 30, 2009 | Linksys Wireless-G WRT54G Router
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
142 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
steve morris
steve morris
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
