Question about Pioneer Car Audio & Video
MY PIONEER 760 MAXIMUM POWER (GM-5100T) WILL TURN ON THEN WHILE PLAYING MUSIC IT WILL CUT IN AND OUT THE WHOLE TIME IT IS ON THEN IT WILL DIM MY LIGHTS EVEN THOUGH I HAVE A CAPACITOR AND STRONG BATTERY.
  • 1 more comment
  • PERALES_RYAN Oct 01, 2008
    THANKS FOR TRYING, I PUT A NEWER ALT. ON AND THE LIGHTS STILL DIM BUT I STRONGLY THINK IT IS THE AMP PLEASE TELL IF U HAVE ANY MORE SUGGESTIONS. THANKS RYAN
  • PERALES_RYAN Oct 02, 2008
    760 AMP AT 4 OHM AND A 10" DUAL VOICE COIL PLATINUM DB DRIVE SUB @ 2 OHM BY 1500 WATT!
  • PERALES_RYAN Oct 06, 2008
    93 GMC SIERRA HEAVY HALF SINGLE CAB TRUCK
    New Friend:
  • 161 Answers
Do you have a strong alternator to charge your battery? even though you have a capacitor and a strong battery you will also need to make sure you have a strong alternator to handle the charging needs when that capacitor puts out its juice that its been storing. Make sure your alternator isnt on it way out by bringing it to somewhere like autozone or advanced auto parts....they usually will do a free test and it only takes 10 minutes.
if it isnt that try a higher farad capacitor.....that could also be the problem.
check all your ground connections as well as look for corrosion on the battery terminals.
might as well check the battery fluid too. (be careful not to touch battery acid as it hurts like hell and is very flammable) you wont have to check your acid levels if its a maintance free battery. if the acid is low inside the battery you can add bottled water to it and run the car for awhile to change the water into acid.
Posted on Sep 30, 2008
  • Jarrid Crandlemire
    Jarrid Crandlemire Oct 01, 2008
    it also could be possible that your charging system just isnt strong enough for it.....but i have a question...what wattage amp do u have and what wattage sub do you have?
    Jarrid Crandlemire Oct 02, 2008
    well thats a big amp and a good size sub......i bet thats loud as hell...lol....what kind of car are you installing it in?
How much is the price of this product?
Look on amazon and ts about $109.17... But this amp use to be in Wal-mart
Aug 21, 2011 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Bass cut off when volume is too high
When an amplifier shuts the Bass off that means its going into protection mode otherwise it will burn out the outputs. One way is to turn your gains down, Pioneer amps are not the best amps for bass out there, they are more for car speakers, I personally wont use a pioneer amp to run my subwoofers especially if they are hard driven subs like JL , Kicker Solo's and MTX subs. But for now just turn the gains down to 3/4 and that should help u, you can also install a fan to keep your amp cooler, if this never happened before in 5 yrs and now it does then that means your amp is just tired and the inside components are overheating easily, thats common with Pioneer and Sony amps.
Good luck buddy.
Lex...
Jun 12, 2010 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Wont power on
Ssometimes the antenna wire is not enough to turn on the amp , some cars use relays in thier power antenna turn on set up which require low 500 ma 's . hit the amps turn on post with 12 volts directly from a jumper wire with alligator clips from main poower wire , if it still wont tunr on the amp the amp may be faulty , also check amps ground , metal its grounded must be free of paint , undercoating rug ect ....
Nov 17, 2009 | Pioneer Car Amplifier GM-5100T - 2CH 760...
No bass coming out
u probably have to replace the rca inputs on the amp or resolder the short on them if u can
Aug 31, 2009 | Pioneer Car Amplifier GM-5100T - 2CH 760...
What are the correct spaekers for the gm 5100t ?
    CEA-2006 Compliant Amplifier Power Standard:
  • 125 Watts x 2 @ 4 ohms <= 1% THD+N
  • 380 Watts x 1 @ 4 ohms BRIDGE <=1% THD+N
  • 75 dBA Signal-to-Noise Ratio
  • Peak Music Power: 250W x 2 (4 ohm) / 760W x 1 (Bridge)
  • 2 Channels
  • Continuous Power @ 4 Ohm: 125W x 2
  • Continuous Power @ 2 Ohm: 190W x 2
  • Continuous Power Bridged @ 4 Ohm: 380W x 1
  • Frequency Response: 10Hz-50kHz
  • THD (1kHz, 4 Ohm): <0.015%
  • Signal to Noise Ratio: >95dB
  • Dimensions: 11 13/16” x 2 3/8” x 12 7/8”
  • PWM Regulated MOSFET Power Supply
  • Balanced Isolator Input Circuit
  • Oversized Screw-Type Power/Ground Terminals
  • 2 Channel RCA Inputs
  • Speaker Level Input
  • Screw-Type Speaker Terminals
  • Hi-Volt Input Level Control (200mV-6.5V)
  • Bass Boost (50Hz, 0/6/12dB)
  • Selectable LPF (80Hz, -12dB/Oct.)
  • Pioneer 1-Year Warranty
I'm assuming the subwoofers were bridged and couldn't handle the power. Make sure you have atleast 300 watts peak power wattage.
Feb 05, 2009 | Pioneer GM-5100T Car Audio Amplifier
Hits intemittently
ive had problems kinda like this ... normaly its a crossed or reversed speaker wire check the positive and negitive wire into the speakers "they move sometimes when there is more air moving around the speaker"
second make sure you have the impedence correct "possitive to positive negitive to negitive'
hope this helps
Dec 21, 2008 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Car Audio & Video Logo
83 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
