Question about Sun Nitro (BMW4300V) 7.8" Real TFT Sunvisor Monitor
Nitro 8" visor monitors. bmwx-4300v, too dim
I installed these without a problem. When i first turned them on they were both on and you could barely see the picture. I mean. I had to shine a flashlight on them to see the no input screen. I disconnected the pass side from power and ground to reroute the wires and when i reconnected it it flashed dim then came on full and works great. I did the same with the other and it is still way too dim. There is no dimmer in the menu. They both use the 12v remote feed for the amps off the deck. They both have the same ground off the deck also. I tried disconnecting the working monitor and that didn't help. I used a voltmeter and everything read what it should be. The inline fuses are all in check. I don't know if there is a wire loose inside or what! I am not affraid of taking it apart i am good with small elctronics. Please help me if you can.
Thanks
Ryan
2 Suggested Answers
phoenixcomm
  • 17 Answers
SOURCE: I have a problem with my monitor Sun GDM-5010PT!
Im confused?!
1. How is when NOT CONNECTED "good" Do you mean that you can see and change the configuration menus?
2. Do you have installed a VGA/13W3 adapter between computer and monitor?
3. Have you changed ie swapped out the components?
a. video card
b. cable
c. monitor
4. Sun Monitors are the ultimit plug and play calbe;
0-0.0.0 NA
1-0.0.1 Reserved
2-0.1.0 1280 x1024, 76hz
3-0.1.1 1152 x900, 66
4-1.0.0 1152 x900, 76 (19in)
5-1.0.1 Reserved
6-1.1.0 1152 x900, 76 (17in)
7-1.1.1 No Monitor Connected
Posted on Feb 11, 2008
SOURCE: help, 24" sun monitor not displaying any red color?
Color card is finished. Change the color card
Posted on Aug 17, 2008
Looking for the plug in harness for a Nitro bmwx 33.2 where can I get 8th?
BMWx-33.2W :: 3.2" Widescreen Head Units, Digital TFT ...
www.nitroelectronics.com > Car Electronics > Car Video
HEAD UNITS Digital TFT One DIN Widescreen 3.2" BMWX-33.2 By Nitro. ... Camera Input (without camera); 4 Channel High Power Output; Plug-In Harness ...
One Din with Monitor - NITRO-AUDIO
www.nitro-audio.com/one-din-with-monitor.html
BMWX-3.2 3.2" Digital TFT One DIN Widescreen/Touch Screen ... Plug-In Harness • NTSC/PAL System Compatible ... BMWX-33.2W 3.2" Digital TFT One DIN ...
NITRO BMWX 5393BT Car Stereo Bench test - YouTube
? 1:36
https://www.youtube.com/watch?v=PHjoXd55mTo
Mar 11, 2013 - Uploaded by colorado4wheeling
Looking online i couldnt find anything about this unit , except for the stock ... Looking at the devic ...
Dec 09, 2015 | Cars & Trucks
Nitro car stereo manuals
Need settings code for an Nitro BMWX-4756 300Watt 7" Touch Screen Monitor In Dash Din DVD CD AM FM for the gps, settings it's a 4 digit code to change GPS settings
May 01, 2015 | Nitro Bmw-4741t In-dash Touch Screen...
Bmwx 5390
You Need to reset it basically easy way to do that is just turn off the car open your engine cover and unattached the battery for a while and put back the battery connections and check should work.
Apr 29, 2014 | Computers & Internet
I have the Nitro BMWX 483 4 channel amp, BMWX 484 2channel amp , and I have the Nitro BMWX 424 4 band EQ !! Now what I'm trying to do is hook up both amps together to the EQ ! So far, I hav the BMWX...
From what I have read about this EQ it is just for subsonic frequencies. You really don't want to run your components through this EQ. Leave the components running off of the 4 channel amp and your sub box on the two channel with the EQ in series between your head unit and the sub amp.
Jun 30, 2011 | Nitro BMW-483 Car Amp
CAN I GET FREE GPS MAPS FOR MY NITRO BMWX??
No, free maps are not available for this unit.
Thank you,
Lee
Aug 25, 2010 | Nitro BMW-5389 GPS Receiver
I bought a vehicle that has 2 nitro amps installed in it and the sound is crappy... i need the installation instuctions for the following.... BMWx-486 BMWx-483 help,help!!!
dude buy a new system for one never heard of a nitro and for two if you dont know **** about systems and your buying a beamer then you should have enough money to get a new better system installed
Aug 15, 2009 | Car Audio & Video
Screen wont turn on
YES YOU NEED A VIDEO SOURCE
Apr 19, 2008 | Nitro BMW-628F Car Monitor
Sun Nitro (BMW4300V) 7.8" Real TFT Sunvisor Monitor Logo
134 people viewed this question
Top Sun Car Audio & Video Experts
xxxxxx xxx
Are you a Sun Car Audio and Video Expert? Answer questions, earn points and help others
