Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Dead spot? We just moved into a house and the built-in frigidaire oven, model no: CFEB27S2AS1 bakes on only the low heats, 0 - 250 and high heats, 450 - max but does not heat (red indicater light not come on nor any heat) at mid-range. Is there something I am not doing, or does it need to be "rebooted", and if so how do I get to the power plug/switch as it is embedded in the wall?
  • 750 Answers
Hello
You said, We just moved into a house and the built-in frigidaire oven, model no: CFEB27S2AS1 bakes on only the low heats, 0 - 250 and high heats, 450 - max but does not heat (red indicator light not come on nor any heat) at mid-range. Is there something I am not doing, or does it need to be "rebooted", and if so how do I get to the power plug/switch as it is embedded in the wall?
To reboot just turn of off the breaker for 5 minutes and this will reset the system perhaps!
I hope this works for you and you are alright!
Before you invest money into this oven remember this oven is 10 years old!
Here is an interesting report I just read!
Repair or replace?
When to pull the plug on your old oven
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your oven,
How much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense
If your range is under warranty or less than four years old ,
paying for a repair makes sense.
Note that ranges under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your ranger is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new range.
Data also shows that it doesn't pay to fix a less-expensive range
eight or more years old.
Thanks to better recycling programs, less than 10 percent
of ovens you replace are likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Posted on Oct 03, 2008
My old Jenn-Air W230 wall oven only gets to "warm" in the bake position - even at a temperature setting at 500 degrees. However the broil function works well. Could the problem be a bad thermostat o
the oven sensor could be bad,its a small rod inside the oven cavity near the top,or you could have a bake element with a "hot-spot" in it that can no longer pass enough current to properly heat the oven to the correct temperature setting(most elements with a hot spot will show a discolored area on the element where its been overly hot)this is the "hot-spot" it will soon break apart there
Nov 30, 2012 | Jenn-Air Ovens
I have a frigidaire self cleanig oven and I want to clean it. I pushed the clean button and it lopcks the door but it does not get hot and act like it is cleaning. The oven is over 6 yrs old
These may be dumb questions... but do your bake and broil typically work correctly? What model do you have?
Depending on model, you should be able to press clean, high or low (2 or 3 hrs), then clean again. At that point the door should lock and the bake element should begin to get hot.
Aug 29, 2011 | Frigidaire Ovens
I have a frigidaire 30" wall oven GLEB30T8CBA.
The control on the upper bake element has failed.and needs to be replaced
Nov 28, 2010 | Frigidaire 30" Built-In Double Electric...
Frigidaire Electric Range Model FEF355ESB
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 07, 2010 | Frigidaire FEF355 Electric Kitchen Range
Built in oven won't get hot
hello there
Usually, when an oven won't heat up or bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it. Now if the oven It bakes poorly Here are two instances of when food "bakes poorly:" When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out. You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results. If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component. When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly. If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective. Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details. Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem
Hope thisis very helpful for you
Best regards Michael .
Mar 08, 2010 | Ovens
My oven is burning my baked goods, but shows the right temp with a thermometer. Do I have to turn the dial to broil and then back to the desired temp? Even if the rack is in the middle, everything burns....
If it is convection bake you have to turn the temp down (25 degrees or so) that is listed in the recipe.
The broil setting is not used to bake because it operates differently from the bake setting. So, don't go to the broil setting at all.
The element for bake is under the floor of the oven. You have not indicated whether it is gas or electric, but both of these can have issues with the burner or element.
If you are baking on the correct setting and the oven is heating from the bottom, not the top, this can be caused by hot spots that are created by elements/burners.
to check, look under the floor of the oven. Turn the bake heat up to high and see if the flame is uneven. For an electric oven, the color of the element should be evenly red, no brown spots.
If you are using an oven thermometer, move the thermometer to the spot in the oven that seems to be burning things the most.
Nov 27, 2009 | Kenmore Ovens
Gas Oven doesn't work under 450 degrees
most common issue is a bad bake ignitor, easy fix, probalby about $75, located on the side of the bake burner, simple to replace a few screws and 2 wires
Nov 17, 2008 | GE JGRP17 Gas Single Oven
Frigidaire conventional oven won't heat up
My frigidaire model is CPLEF398CCB conventional electric flat top oven. Everything is working fine except my oven. When I select pre-heat, broil or bake nothing lid up. No heat on the coil, only fan.Any suggestions?
Jul 03, 2008 | Frigidaire PLEF398AC Electric Kitchen...
1992 Frigidaire built-in oven with F4 error
f4 is the code for a shorted oven probe try first replacing it
Feb 12, 2008 | Frigidaire GLEB27S7A Electric Single Oven
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
111 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
