Question about Microsoft Windows Xp Home Edition Sp2 English Mlp Na Only Additional License (n0901086) for PC
Task Manager/CPU Usage
Sir,
Before some time when i open any programme or word document my cpu usage was just 1/2%
But, Nowadays My CPU Usage is 90/91% without using any programme or donn't work anything.
What is Actually Problem is ?
  • 86 Answers
First thing scan ur pc..it may be infected by viruses
and check usage
Posted on Sep 30, 2008
I have a computer [AMD athlon(tm)]xp 1800+ 1.50 GHz]. My problem is when I switch on the system,the OS will open and i don't open any application then if i see in 'Task Manager - performance' there the...
Type "msconfig" on search bar there will be bar "startup apps" click that and click on disable all and restart your system...hope it works... Regards: imran
Sep 19, 2014 | Computers & Internet
Tip
How to Protect PC from Overheating?
Laptop over heating which is also known as Thermal Overload.This is mainly due to excess usage of CPU(More than 60%) for a long time.
To check CPU usage Right click on Task Bar>Select Start Task Manager>Performance.
or
Shortcut Ctrl+Shift+Esc
If your CPU usage is more than 50% you need to close some applications which are using 20++% CPU.
To check application which are using 20++% CPU
Right click on Task Bar>Select Start Task Manager> Processes
Search in this dialog box for programs which are using 30++% CPU
You need to close this application to prevent PC from over heating.Actually %age usage indicates load to CPU by the application.If load is to much CPU is to processes at faster speed which in turn increases temperature of CPU.
To close the program select the program,and select End Process.
If didn't found any program using 30++% CPU in this dialog box.
Select Show process from all users. and search in this dialog box and close the program.
Caution:some times your system also uses 30++% CPU inn some processes like anti virus scanning,at this if you closed the program your PC may shutdown.At this time you need to restart the PC.
This usually happens for out dated anti virus or incompatible programs.
There are some other factors like Graphics Properties and Graphic Memory,Display size, Processor type,etc.At this time its better top use a cooling pad.
Some program like camera drivers,Simulation softwares,games uses 50+% CPU.This is common these programs need to process large amount of data at short interval time which increases CPU usage but this is normal.
The processors properties are tested at 140*c so no need to worry.If the CPU exceeds the limited temperature PC will shuts down automatically,and after cooling you need to start the PC.
Thank you...:)
ANY SUGGESTIONS...?
on Feb 16, 2011 | Computers & Internet
High cpu useage
Open the Windows Task Manager - you should be able to right-click on the bottom task bar to do this or else, you can use Ctrl + Alt + Delete keys to invoke it too.
In the Task Manager window, select the Process page tab, then click on the CPU column header and sort the list of running processes by the amount of CPU being used - this should help you understand what is consuming high CPU on your computer.
Jan 03, 2012 | Compaq Computers & Internet
Laptop dell inspiron n5010 hanging suddenly
There are many things that might cause your PC to run slowly or restart at time and then. It could be a fragmented disk; fragmented registry; a virus, Trojan, or spy ware; high CPU and/or utilization due to too many programs running; high disk I/O; or something else.
To check your CPU and memory utilization, run Task Manager. You can start Task Manager by pressing CTRL+ALT+DEL and then clicking on the Task Manager Button. In Task manager, click on the Performance tab and check CPU Usage and PF Usage. PF Usage is an indicator of memory usage. If one or both of these is high, click on the Processes tab, and sort the columns by CPU or Memory to see what processes are consuming the resource. If you are not sure what the process "Image name" is for, Google the name and you should find what the process is for.
If your CPU and memory usage are reasonable, then you may have a different issue. Even if you running anti-virus software, it may be beneficial to scan your PC with another scanner to check for viruses. Here is a few good virus scanners that you can run to check your PC:
http://c74b6qq6lbo8zlievtv2q810g1.hop.clickbank.net/?tid=DMWDH6W3
Nov 24, 2011 | Dell Computers & Internet
What's your problem?It's stuck on logging off
Nov 05, 2011 | HP Compaq Presario CQ50-110US Laptop
Acer aspire one D250-0BK keeps freezing
If your CPU and memory usage are reasonable, then you may have a different issue. Even if you running anti-virus software, it may be beneficial to scan your PC with another scanner to check for viruses. No anti-virus software is 100% perfect at catching everything. Here are a few good free online virus scanners that you can run to check your PC:
http://security.symantec.com/sscv6/home.asp?langid=ie&venid=sym&plfid= 23&pkj=RRJEDTKJBTVISBYWWYP
Nov 05, 2011 | Acer Aspire One PC Notebook
Computer is slow to open file when connected to network
when connected to a network the cpu performance get highe, check your cpu performance by press control alt and delete on your keyboard at the same time to go to windows task manager, see the cpu usage by clicking performance, if the cpu usage is above 50% it means that wasn't normal, run a virus scan to make sure that your windows is free from viruses, if it can't fix your problem it mean you need to reinstall your operation system
May 12, 2011 | Acer Computers & Internet
My dell gx 260 p4 2.66/1GB/40HDD respond slow during operations and startup. it does not respond quick as other p4. i've installed a lot of applications. does this make the system slow. i've cleard my...
Check in the task manager wich program is consuming the most of your CPU usage.
1. Press Ctrl+alt+del to open the task manager window.
2. Go to processes tab, and check.
3. Uninstall the program or programs that are using the most of your CPU.
If that does not work, check your system page file. You do that also on the task manager in the ''performance'' tab. It will show you two graphs, the CPU usage and the PF Usage (page file usage). If the page file is bigger than the amount of RAM you have installed, I would recommend you two options: 1)upgrade your RAM to your system needs or 2) uninstall any unused program or programs that you don't use regulary.
You can also try to restore your system to a previous configuration date were you know the system was working perfectly. In windows go to start>all programs>accesories>System tools>system restore.
As last resort, I would recommend, to backup all your data, documents, applications and others that you might need in the future and after that reinstall windows.
Feb 06, 2011 | Dell OptiPlex GX260 PC Desktop
My Toshiba satellite pro M10 very slow.
check your system performance thru task manager. check for CPU usage. usually COU usage is 1% to 10%. if your CPU usage would peak from 10% to 100% there is a huge possibility that there is program running on your computer that eats up your memory. Or it could be spyware/malware
Mar 27, 2010 | Toshiba Satellite Pro M10-S405 Notebook
100% CPU usage
Try to monitor the CPU usage before opening CROME. If it is normal before opening it then there is some process under CROME which takes you CPU usage report to GOOGLE on this. and remove it through Add/Remove programmes under control panel.
Try to use Firefox instead of CROME.
If it happens again then there is some thing wrong with OS( most probabaly Spyware or trozen).
Jul 30, 2009 | Computers & Internet
Microsoft Windows Xp Home Edition Sp2 English Mlp Na Only Additional License (n0901086) for PC Logo
111 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
