Question about Stoves Kitchen Ranges
Need building code for woodstove installtion in garage
Check out Code Check Complete. They have all up to date building codes at codecheck.com
Posted on Sep 30, 2008
If I am building a garage on my property, do I have to register it with the NHRBC?
sadly we have no idea if where you live has building codes or not
Sep 26, 2017 | Building Materials
How do I close up a garage car port into a room?
Check with lo al building department. Most garages are not insulated for use as a room so you may need to do that as well. There are also codes regarding window requirements. All this must be addressed prior to doing this job.
Nov 15, 2016 | Building Materials
Garage door opens randomly
Steve, If you have a remote door opener, change the code, as one of your neighbors may have their door using same code. Also make sure there is nothing hanging or blowing in front of sensor lights.
below are links, how to.
press the helpful button
How to Program Garage Door Remote Change the Battery Craftsman 315
Garage Door Help How to Program Your Garage Door Remote Control
How to Adjust Your Garage Door Opener Travel and Force
Feb 12, 2016 | Building Materials
Where can I get a owners manual for my brunco wood burning furnance
One manual in pdf format is available here: http://www.brunks.com/20071119190220946.pdf . It is posted online at http://www.woodstoves.net/brunco/bruncofurnace.htm . If this manual doesn't cover your particular model, the folks at Obadiah's Woodstoves can probably help you out. Their phone number is 1-800-968-8604.
Oct 16, 2011 | Heating & Cooling
Operating manual for RSF advent airtight woodstove
You have actually posted to the washing machine forum- but the answer would probably be the same!
You will need to type into your search engine/web browser 'RSF advent airtight woodstove' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Oct 07, 2011 | Washing Machines
Fan on woodstove not working regularly. Model no WOODSTOVE 1800/2400. Thanks, Brendan
Brendan, if you can access the blower remove it and clean it. Note if any lubrication of the fan's shaft needs lubrication (light weight machine oil will work). Also, check the outlet that the fan is plugged into, to make sure it' still has power. If it's an automatic fan that has a senor to turn it on and off, that sensor may have failed and will need to be replaced. Depending on the age of the wood stove and the blower assembly plays an big role in this. They don't last forever.
Apr 26, 2011 | Heating & Cooling
My napolean woodstove has smoke coming from the ash box when I start a fire.It seems to come out of the fresh air damper slider.After the fire is well started it goes away.What could be causing this....
That is usually caused by lack of draft. You may have a partial blockage in your vent pipe or somewhere going to it. Once the heat builds up the draft increases and the smoke is exhausted. Good luck...Lee
Dec 05, 2009 | Napoleon Auburn Pellet Stove Heater
Kitchen Ranges Logo
311 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
Tony Houde
Tony Houde
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
