Question about Dell Latitude D600 Notebook
D600 doesn't recognize power supply
I know Dell went to a lot of trouble (probly had meetings of the Difficulty Commitee) to make their laptops only accept genuine Dell power supplies or properly functioning supplies. Is there any way to overide this built in conspiracy so I can charge my battery and just use the computer normaly, without buying annother power supply?
Don't respond with instructions how to overide the warning in the Bios. If it was that simple I wouldn't be asking.
  • n3sjh Oct 01, 2008
    If you read my question, It is published that Dell actually uses the
    center wire to identify the power suppy so it knows if it one of
    their's or not. I want a way to tell the computer to disregard this
    information and go ahead and charge the battery.
    By the way I am a ham radio operator (technition class) and almost 20
    years ago I was repairing electronic medical equipment to component
    level so I see volts and amps in my sleep. I wish the answer was
    that simple.
  • Anonymous Feb 03, 2009
    I have four Dell laptops that all take pa10 adapters. Only one of them doesn't recognize the adapter, and it won't recognize any of them or charge the battery. Dell keeps telling me it's the adapter or the battery and they want to sell me one, but the battery is good because it works in another notebook. The adapter works on all of them except the 1721. So I'm assuming it's the mother board.
  • 1,472 Answers
N3sjh
Sorry to hear that you are having trouble charging your D600. In regards to the message that you are getting it most likely just a warning to make sure you plug the proper rated AC Adapter into the system. To my under standing there is no why for the noteboook to know if you are plugging in an AC Adapter that is not from Dell. However the notebook can tell if the power out is not right. So it may not accept the charge as a safety thing to keep you from frying the notebook.
Now if your original adapter is not working but you still have it this is good because you will need to get info off it. The important part is the output voltage and amps. The info has to match the info of the one that you are trying to use, if it does not the adapter will not work. The other thing is to look at is the WATs is needs to be the same or higher. It can not be lower or you will not enough power.
So in most cases if you are trying to use another adapter from other notebook it may not work. Note this is not a Dell thing, all the manufactures do this. Granted there may be an adapter that works for several model but they are usually in the same series.
Now if you can not use the original adapter then you can get a non Dell adapter. There is several 3rd party adapters out there you just need to make sure that it is made to support your system. Most of you big chain stores carry them. Like I mentioned above different notebooks have different power requirement. The down side to this is since they are made for serveral different models they usually cost a lot. However in regards to Dell's systems most of time you can get a better deal by getting a replacement from them.
Let me know if you have any more problems and/or questions regarding this issue.
Issken
Posted on Oct 01, 2008
I have trouble booting up my Dell Latitude D600. When I press the power button status lights on right flicker for few seconds then shut off.
try removing the battery (keep ac power), test
if nothing, try the opposite,
remove both ac power and battery test,
for some reason holding down f10 and cursing at the machine seems to help. Mine does this but typically will boot after a few attempts (and lots of cursing)
Sep 12, 2011 | Dell Latitude D600 Notebook
My dell D600 laptop fails to boot, when i press the power button the three indicator light on it will on for 3 seconds and will off.
Try flexing the whole bottom assembly. that is with the laptop open put your knee in the middle and grab the unit with one hand on the corner closest to you and the other near the screen and put enough pressure to "flex " the mobo right after you push the start button if it doesn't start try it the other way... this has been working for my grandsons d600 for 6 months. i tried a new switch board because the guy that sold me the mobo said the plug for that is know to crack. good luck ps you will know it has worked when the 3 lock lights go out and the power light stays on.
May 12, 2011 | Dell Latitude D600 Notebook
Power supply isn't recognized
Hello there!
I would reccomend you to send your Dell Studio to service, since there are good chances the problem is with Motheboard. I would really reccomend you that! :)
Please rate solution! =)
Sincerely
Aleksandar Adzic
Apr 16, 2010 | Dell Studio 17 Laptop
How to find the part number of HDD 20 GB of Latitude D600?
Dell is very good at supplying part numbers on their home page. One of the ways to find it is do a yahoo search for dell latitude d600 parts.. This should bring you lots of info on d600. From there you can find a Dell parts supplier. here is a link from the search I did: http://www.parts-people.com/index.php?action=category&id=140&subid=117&refine=hard drive
Please note. You wont find a Dell hard drive. They use Western Digital and other brands. Most any hard drive brand will work.
Apr 16, 2010 | Dell Latitude D600 Notebook
My Dell610 laptop says that it can not recognize
you need a 90 watt power supply,the one you have is bad
Sep 05, 2009 | Dell Latitude D600 Notebook
My dell latitude d600 won't recognize the AC power adapter and doesn't show that the battery (which is new) is charging. I had to leave it plugged in for about a week when I put in the new battery before...
There was a class action suite against Dell for this problem with this model laptop due to overheating and destroying the power supply. Browse the web for more information. I have one and it is a parts machine now.
Jul 29, 2009 | Dell Latitude D600 Notebook
Dell Laptop Power Cords
may i know the older Dell laptop you have, & also the new Dell LAtitude laptop you have now.... charger must meet the exact wattage and amp of the laptop..
Jun 17, 2008 | Dell Latitude D600 Notebook
D600m dell laptop
the power adapters are known to have problems
Mar 29, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
947 people viewed this question
Alun Cox
