Question about Cozy Enclosed Front Console Heater 20,000 btuh Propane
Pilot light has no gas coming out, verified gas going into gas valve, but no gas coming out when pilot light button depressed.
    Problem Solver:
  • 10 Answers
Pilot orifice may be clogged. Remove pilot tube and orifice. Blow out orifice with compressed air only and reassemble. Also, control valve may be bad.
Posted on Feb 05, 2009
How to I start my heater
If it is this heater, then you must:
1- turn the toggle switch to the ON position.
2- Turn the gas valve dial to the PILOT position.
3- Depress the pilot button while pressing the ignitor until you see a flame. Continue to depress the pilot dial for about 30-60 seconds.
4- let go of the button, and the pilot flame should stay lit. If it does , then turn the gas valve dial to the ON position.
5- Set the temperature and your done.
Apr 27, 2011 | Jandy Lite 2 Natural Gas Pilot Light...
I want to light the pilot but do not know how what is the red button for and do you turn on the gas to light pilot?
nope - don't turn on gas at the Range's front control panel to light the pilot lite.
but you do need to turn on the gas to the kitchen range at the plumbers black pipe valve to the Range.
To light the pilot light:
(1) depress the red button (that feeds the gas to the pilot light orifice)
(2) using lighter/match/lit rolled-up newspaper, etc, light the tiny amount of gas coming from orifice
(3) continue to hold dow red button for 1 or 1.5 minutes (this allows heat to bend the bi-metal contact)
(4) after 1-1.5 minutes with a lit pilot light, release the red button - the pilot should remain lit
(5) you're done lighting the pilot lite - turn on the oven (or broiler).
Dec 27, 2010 | Kitchen Ranges
Can't get the pilot light to start
Is this the newer style with closed combustion chamber. If so I would check to make sure that spark ignitor is working. If not it will need replaced. If ignitor is workingthen loosen compression nut on line to pilot and temporarily depress button on gas valve to make sure you have gas at that point.If you have gas there and tighten compression nut to pilot back up and it still won't light then you will need to remove screws that hold cover on burner compartment.Shut off valve to gas supply and remove gas line from gas valve remove pilot and thermocouple lines. Slide burner out ofcompartment and clean it .Remove nut from bottom of pilot assembly and clean out pilot orifice. Blow through pilot line to make sure it's all clear
Reassemble everthing using teflon tape or pipe joint compound as needed.Turn gas supply valve on and check for leaks.Set gas valve control to pilot and depress pilot button and hold. While you are holding button done push spark ignitor every few seconds until it lights. thank you and good luck
Dec 22, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
How do I change the termocouple on an older Dayton furnace
Locate the gas valve,there will be three lines coming off the bottom and going into the burner compartment. The center one is the largest and is the main gas feed to burner. The one on right is usually silver and about 1/4 inch in diameter. It is the pilot feed line. The third is usually coppercolored ,this is the line for the thermocouple. You can trace thermocouple line down into burner comparment. The tip of the thermoucople usually slips into a friction fit mounted right in front of pilot burner.Slip old thermocouple out of holder and unscrew fitting from the bottom of gas valve. Install new thermocouple into pilot burner assembly,make sure thermocouple is fully seated and in direct line of pilot flame. screw fitting into bottom of gas valve. Set gas valve control to pilot,depress pilot button and light pilot. Hold pilot button down for about 2 mins.Tip of thermocouple should be cherry red. If it'snot try to reposition so thermocouple is more covered by pilot flame. Relese pilot button and if pilot stays on rotate gas valve control to on.Hope this helps you. Yhanks
Nov 20, 2010 | Dayton Gas Furnace Heater
How do i relight my standing wall heater light, where is it?
There should be a removable panel on the bottom front. Remove this panel and you should see gas valve with two lines going into combustion chamber. The larger of the two will be for burner and the smaller to the pilot light. There may be lighting instructions on the inside of panel,or on front of burner compartment. If not look at gas valve and see if you can see where it is marked off pilot and on. Turn thermostat to lowest setting and gas valve to pilot ,locate pilot light and hold match to it while you depress pilot button . Pilot should light. If it does hold button depressed for 1 to 2 mins. Release pilot button and if pilot stays lit turn valve to on. Turn thermostat up to desired setting and see if burner comes on. If it does you should be done. Put cover back on. If pilot light does not stay lit or burner won't light I Would recommend you call a service tech as there are several things that could be wrong. Hope this helps you.Thanks
Nov 12, 2010 | Montgomery Ward (223600UP) Heater
We have an older (22 years?) 'Insta-Flame (model HE30 TN) natural gas fireplace insert. The pilot light is out, as we painted to inside of the firebox. The instructions show to 1) turn the dial to 'off'',...
On some gas valves the pilot setting is on the same dial as pilot on and on .on others the pilot light has aseperate button on right side of control dial. If yours has this there will be a cut out on cotrol dial that must be aligned with button to allow it to be depressed to light pilot. If yours has this align control dial cutout with pilot button,depress button and light pilot,hold for about one min. and slowly release,if pilot light stays lit,turn down thermostat and rotate control dial normally to right . There should be arrows or marks on dial and gas valve to line up. If pilot light stays lit turn dial to next position and check to see that pilot is still lit. This should be on position, turn up thermostat and burner should light. If your dial has pilot light setting on it then rotate dial to each position,try to depress dial and when you have right one dial will depress allowing you to light pilot. Follow same procedure as above and you should be in business. Hope this helps.Thank you
Nov 11, 2010 | Heating & Cooling
My wall gas heater pilot light wont light when I depress the pilot button. I think it is clogged. How do i clean or fix it?
Firstly, be certain the gas is on to the heater. (I know it's a simple mistake but it happens a lot more often than you might think). Once you've done that press the pilot button and feel to see if any air at all is coming out, if there is you will probably need to hold it down for a few more seconds to purge all the air out and then light. If there is absolutely no air coming from the pilot orifice then pull the pilot tubing off (there should be a brass fitting going back to the gas valve) and be sure that there are no obstructions to the gas flow. If you can push air through one side of the tubing and it comes out the other side then you have a bad gas valve, if not, you have a clogged pilot tube.
Mar 13, 2010 | Heating & Cooling
I have an older monterey wall heater that is gas that wont seem to light. I cant even get the gas to start from the pilot can you help me?
You could have a plugged pilot line. You will need to get to the gas valve and shut the gas supply off. Once you did that, unscrew the pilot line that supplies gas to the pilot assembly. You can then turn on the gas supply and rotate the pilot knob to the pilot setting. Depress the knob into the gas valve. You should be able to smell and hear the gas come out of the hole where you unscrewed the pilot line. Don't do this with a cigarette in your face. Once you verify you have gas, release the knob and shut off the gas supply. Take a can of air and blow thru the pilot tube, first from the pilot assembly in the heater then from the open end of the pipe. Replace the pilot tube making sure you don't cross thread the fitting. Tighten well. Again turn on the gas supply, spray or rub some soapy water on the fitting you tightened, depress the knob and hold it. The soap will bubble up if there is a leak. Fix it. Now light the pilot.
Jan 20, 2010 | Heating & Cooling
Lighting the pilot light
The steps involved can vary slightly depending on your furnace model and pilot valve type, so if possible try and find the instructions inside the furnace door cover or in the instruction manual. This is for a gas fired furnace, but applies to any gas-fueled appliance including water heater. Two of the most common types of pilot valve body assemblies either have a red reset button and a gas valve or no reset button and a valve knob that can be depressed. But whichever type you've got, if you have an older model furnace with a standing pilot (flame is lit all the time) then this is the basic procedure.
  • Turn you thermostat to 80 degrees or to a setting that will demand heat. Make sure the thermostat is in "Heat" mode.
  • Go to the furnace and find the pilot valve. The pilot valve body is a box shaped device into which the main gas line will run and is located near the gas burners. It will usually have a gas **** or valve knob that reads "On, "Pilot" and "Off." Locate this gas **** or knob.
  • Turn the knob or gas **** to the "Off" position and wait about 3 minutes for any residual gas to clear away.
  • Find the pilot. It's located near the gas burner tube assembly in the furnace.
  • Get your match or lighter ready. Sometimes the pilot is hard to reach. If possible, try and use a long fireplace match when you light it. If you don't have a fireplace match then a butane BBQ grill lighter works well too. If you don't have that, then you can fasten a match to the end of a stick when you light the pilot
  • If you have a pilot with a red Reset button, turn the gas valve from "Off," to "Pilot."
  • If you have a pilot with no red button, turn the knob from "Off" to "Pilot."
  • Place the lit match or ignited lighter tip at the pilot and depress and hold the button or depress the knob as appropriate. Depress the button or knob for about 30 seconds. This maintains gas flow to the pilot until the thermocouple gets hot enough to open the main gas valve.
  • Once the pilot stays lit, slowly release the button or knob and turn the gas **** or knob from the "Pilot" position to the "On" position. This will ignite the burners and keep the flow of gas supplied as required for the burners as called for by the thermostat.
  • If the burners fail to ignite then it may be because the thermocouple did not get hot enough to open the gas valve. Wait a few minutes and then repeat the above procedure. This time hold the red reset button or depress the knob for about 45-60 seconds.
  • Once the main furnace burners ignite, adjust the thermostat to the desired setting.
  • If you've followed the previous steps on lighting the pilot and it still does not light after, or will not stay lit, then you probably have a problem with the thermocouple or an adjustment needs to be made to the pilot. You'll need a furnace service technician to replace or repair these parts. You may find that the pilot lights, but it is an anemic looking flame. That's a different problem we'll look at in the next section.
  • If the pilot lights but the flame is a weak yellow flame, it will not get hot enough to heat the thermocouple to its set point allowing the gas valve to open.
    A natural gas flame should be a bright blue with the tip of the flame having just a tinge of yellow. A propane flame should have a bluish green flame with a tinge of yellow at the tip. The flame should be strong enough to hit the thermocouple tip about 1/2 inch from the tip end. If the flame is weak or shaky looking, check to see that a breeze or draft is not blowing on it. Adjusting the Flame
    There is usually a small screw on the pilot valve body that will adjust the flame. You may have to refer to the manufacturer's instructions to find the screw. Turn the screw as needed to adjust the flame throw. Yellow Flame
    A yellow flame is caused by lack of air and incomplete combustion. It can be caused by a dirty pilot tube tip. Split Flame
    This is caused by dirt in the pilot tube. Take a needle or small nail and gently clean the tube. Flickering or Wavering Flame
    A flame that flickers is usually caused by a draft.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 18, 2009 | Water Heaters
I need help relighting the pilot light on my Marco mfg gas fireplace-model # 794015c
First, turn the wall switch to the off position. Second, turn the key all the way tcountercockwise to the open position. At the front of the unit, below the hearth opening there is a black front access panel. Should have a little recessed part. pull it out and expose the gas valve. Turn the plunger/knob that says off, on, pilot to the pilot position. You'll knw your in the pilot position when it lines up with the indicator (usually a red or black mark on the gas valve body). If you are in the pilot position, you will be able to push in the pilot (it will feel springy). Push the plunger in and then push the red button (piezo ignition button) in until it makes a snapping sound. You may have to do this several times because the air has to bleed out from the pilot tubing. This should light the pilot BUT wait. DO NOT LET GO OF THE PLUNGER ONCE THE PILOT IS LIT. You need to keep the plunger depressed for about 30 seconds and then let it go. After 30 seconds let the plunger go and verify the pilot is lit. If not try the last step over. After the pilot is lit, you may turn the plunger/knob to the on position. Now go back to the wall switch and flip it on. If it doesn't come on tap it hard. Sometimes dust can actually prevent it from making good connection. I work on fireplaces for a living and coincidentally worked on this model today. Simple as pie.
Dec 28, 2008 | Heating & Cooling
Heating & Cooling Logo
245 people viewed this question
Top Cozy Heating & Cooling Experts
Paul Carew
vance jones
Mack Baxter
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
