Question about LG Televison & Video
LG 50Px5D D.O.P. Aug 07 There were three quite audible clicks 1. Full screen but image only vision 2. Second click abot ten minutes later - no vision but sound - could still change chanels 3. Third click no vision - no sound - the TV shows a green light for a few seconds when switched on but then shows the red off light. The above happened mid-viewing. All power connections checked
Still have the problem - but I have no way of paying you for your advice - hence I didn't proceed any further
Posted on Sep 30, 2008
TV switches off automatically.
if you take the cover off, then take a look at the capacitors.
check if any have bump ..
Jan 13, 2014 | LG Televison & Video
The user profile service failed the logon. user profile cannot be loaded
Anyway.. If you can, follow these steps. They might help! If not, give me a bell! It looks complicated, but it's very easy.
Also, before this happened, did you trying doing a Windows Update? If so, that was the cause, especially if it failed. I don't know why it locks the account, however.
1. Open the Start menu.
2. In the white line (Start Search) area, type regedit and press Enter.
3. If prompted, either click on Continue or enter the password for the Administrator account.
4. In regedit, go to: (See screenshot below step 5)
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList
5. In the left pane, look for the S-1-5..... folder (SID key) with the long number that has .bak at the end of the numbers.
(See screenshots below steps 6A and 7B)
NOTE:
A) In the right pane, look at the ProfileImagePath to verify that this is the user account profile that has the error.
B) You may have another S-1-5..... folder (SID key) above it with the exact same number without the .bak at the end of it.
6. For Two S-1-5..... folders (SID key) with the same Number -
NOTE: This is if you have two S-1-5..... folders (SID key) with the exact same numbers, but the second (below) one has the .bak at the end of the numbers.
A) In the left pane, right click on the first (top) S-1-5..... folder (SID key) that does not have .bak at the end of the numbers and click Rename. (See screenshot below)
wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 828x303.wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 828x303.wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 828x303.2803d1221837039-user-profile-service-failed-logon-user-profile-cannot-loaded-repair.jpg
B) Add .bk to the end of the numbers. (See screenshot below)
wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 828x303.wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 828x303.wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 828x303.2804d1221837039-user-profile-service-failed-logon-user-profile-cannot-loaded-repair_bk.jpg
C) In the left pane, right click on the second S-1-5..... folder (SID key) with .bak at the end of the numbers and click Rename. (See screenshot above)
D) Remove only .bak from the end of the numbers and press Enter. (See screenshot below)
E) Now go back and Rename the first one with .bk to .bak now at the end of the numbers and press Enter.
wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 828x303.wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 828x303.wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 828x303.2805d1221837039-user-profile-service-failed-logon-user-profile-cannot-loaded-repar_bak.jpg
F) Go to step 8.
7. For Only One S-1-5..... Folder (SID key) with .bak -
NOTE: This is if you only have one S-1-5..... folder (SID key) for your user account with .bak at the end of the numbers.
A) In the left pane, right click on the S-1-5..... folder (SID key) with .bak at the end of the numbers and click Rename. (See screenshot below)
B) Remove only .bak at the end of the numbers and press Enter. (See screenshot below and below step 10)
wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 836x303.wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 836x303.wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 836x303.2737d1221837039-user-profile-service-failed-logon-user-profile-cannot-loaded-repair_reg2.jpg
8. In the right pane of the one without .bak now, right click on RefCount and click Modify. (See screenshot below step 10)
NOTE: If you do not have RefCount, then right click on a empty space in the right pane and click New and DWORD (32 bit) Value, then type RefCount and press Enter.
A) Type 0 (number) and click on OK. (See screenshot below)
2738d1202983360-user-profile-service-failed-logon-user-profile-cannot-loaded-modify_refcount.jpg
9. In the right pane of the one without .bak now, right click on State and click Modify. (See screenshot below step 10)
2739d1202983366-user-profile-service-failed-logon-user-profile-cannot-loaded-modify_state.jpg
10. The registry will now look like this for the one without .bak now. (See screenshot below)
11. Close regedit.
12. Restart the computer.
13. See if you can logon now.
Mar 14, 2013 | HP Computers & Internet
Everytime i turn my lg 50PX5D on about ten seconds later it switches off?????
Hello
There is some over current consumption when the set heats up. Just see whether its cooling fans are working well. It can't be predicted the fault, as it need a through check up.
Feb 12, 2012 | LG 50PX5D 50 in. Plasma HDTV
I have pentium 4,model is old 6 years,and I have LG Flarton w 2230s monitor,and I cant see a full image on my display,borders are shorter for 4cm in both side,maybe my graphic card is old?
I think that you have the wrong resolution set on the computer.
1/ Right click on the background part of your screen, click on settings, look at the screen resolution, adjust the screen resolution for wider setting.
2/ Try downloading the latest drivers for you graphics card and installing them.
3/ If you have a cd with drivers for the monitor install them and that will be fixed.
Or you may need a later model graphics card.
Jun 27, 2011 | Computers & Internet
My archos vision 1 is not recognised by computer
Hi, archos vision 1 player not recognized by the computer
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see archos vision 1 player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the archos vision 1 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: archos vision 1 Players can connect to your computer in MSC or MTP mode. Exceptions are archos vision 1 Connect and archos vision 1 Express which only use MTP mode. MTP mode is the recommended and default method for archos vision 1 Players when used with Windows OS.
The archos vision 1 player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Have a nice day....
Feb 19, 2011 | Audio Players & Recorders
LG 50PX5D, I heard a loud pop and the screen went
Ur Main Tuner signal board is dead.Replaced the Main Tuner signal board will solved ur picture problems.
Jan 23, 2010 | LG 50PX5D 50 in. Plasma HDTV
How do I project my laptop screen onto LG 32LG30 HRTV?
assuming that you connected it with the right wire , now find the function key (should be one of the 'F' keys at the top line) that has a screen-like image.
click on Func + that 'F' key until you see your laptop desktop on your TV.
another option is to:
1. right click on your desktop
2. select properties
3. go to advance
4. click on the second screen and enable it.
now you have two screens and you can drag your browser or any other open window you have to the TV
Aug 10, 2009 | LG 32LG30 32 in. LCD HDTV
3D like view on my screen
you ned to replace both convergence ICs they are STK392-570 you can get replacement ICs at the following link with free installation instructions.
http://servicemanuals.vstore.ca/
Aug 21, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Tv Died
the tv probably got banged or something spilled onto it
Dec 23, 2007 | LG 50PX5D 50 in. Plasma HDTV
Televison & Video Logo
77 people viewed this question
Computer Repairing
Computer Repairing
