Question about Viking Kitchen Ranges
WHAT KIND OF ELECTRICAL HOOK UP DO I NEED FOR THE MODEL VGIC368-4G
    Scholar:
  • 43 Answers
Good Evening Mesquite-196:
Hope that you are wellJ
Did you mean Hood?
At any rate, you can contact the manufacturer, directly and order the item that you need.
There are so many choices, depending on your needs that it is best to speak to their representative.
Viking Range Corporation
111 FRONT STREET • GREENWOO d, M S • 38930 • (662) 455-1200
Also, CALL 1-888-VIKING1 (845)4641
OR VISIT THE VIKING WEB SITE AT VIKINGRANGE.COM
If I can be of further assistance, please let me know.
And, remember, always include the type of Operating System and the type of computer you own, when you submit your questions. It simply makes for much faster solutions.
Have a wonderful evening.
Posted on Sep 30, 2008
  • Sonja Perdue Oct 03, 2008
    Please don't forget to leave a comment or rate me.
    Thank you!
If hooked up wrong will it blow a fuse or not work anymore
What did you hook-up wrong, hope it wasn't the battery? If you hooked up the battery wrong, not sure what kind of damage might have been done?If some other component, which one?
Any electrical component that doesn't work, check wiring diagram, check voltage and ground for that system.
What is year--make--model?
Nov 10, 2016 | Cars & Trucks
Bought a replacement control board for frididaire oven but it doesn't hook up with power strip but it looks like I can jump it but how
Hello friend, thank you for your post!
From my understanding you have a replacement control board for your Frigidaire range and the power strip doesn't hook up properly so you would like to jump it over. I would not recommend doing so because you would be unsure what kind of electrical miscommunication that could cause. The part you have ordered maybe incorrect. If you can provide me with your model number I can double check your parts manual. You can locate your model number on the door frame of the lower drawer. I look forward to assisting you. -Matt
Feb 18, 2015 | Frigidaire Kitchen Ranges
Need info on doing an electrical hook up on a MMA 1555 inverter welder
Has it been replaced before? I would recommend getting it checked out because you can cause a fire if it is not the right size cable.
Dec 09, 2013 | Welding Tools
Pulled a motor and transmission (still bolted together) out of a 4wd f150 and want to put them into a 2wd f150. are the transmissions the same or do i need to swap them out? would prefer to keep the...
YOU NEED TO USE A RWD TRANSMISSION FOR SAME YEAR AND MODEL TRUCK WITH SAME ELECTRICAL HOOK UP.USE A 4WD TRANSMISSION ELECTRICAL HOOK UP AND SHIFT CABLES WILL BE DIFFERENT.YOU WILL PROBLEMS WITH THE TCM AND PCM. WHICH CAUSE SHIFTING PROBLEMS CHECK ENGINE LIGHT FLASHING.
Jun 22, 2011 | Ford F-150 Cars & Trucks
Missing electrical hook-up, foot peddle, and manual
Need the make and model number if you need any help
Feb 19, 2010 | Sewing Machines
I just picked up a 12" type r in a box with a alpine m 350 how do I know what kind of type R I have without taking it out of the box?? and how do i hook it up to this amp??
Not to insult you in any way but u need to know how to wire into car's electrical system at the battery then to a fuse then to the amp and then output the signal from the deck to the amp.. finally to the subwoofer. you need to hook up 12V constant battery power , then remote from the deck ,ground wire from amp to chasis for power.. then wire to sub.
Sep 10, 2009 | Alpine SWR-1222D 12" Type-R Series...
Jenn air model JED8430bdb
A similar concern on a different model (8230):
To my knowledge, the:
green - ground
white - neutral
black - 120 to ground
red - 120 to ground but between red & black, it should be 240. A Jenn-Air JED8230 requires a 3-wire, 120/240 Volt, 60 Hz Outlet.
Pls consult/confirm with your local electrical utility/codes the availability/applicability of this power/wiring system or reference National Electrical Code, NFPA No. 70
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 12, 2008 | Jenn-Air JED8430 Electric Cooktop
Speaker Hook Up
Hi, Most if not all external speakers for 2way radios just uses two wires to 2 pins going to a mono baby phone plug. There are some models/versions that uses proprietary connector but very seldom. The connection is similar to a mono earphone except of course that instead of an earpiece, it uses a speaker/enclosure. Hope this be of some help/information. Post back should you need additional information and pls include brand/model of the radio. Good luck and kind regards.
Sep 29, 2007 | Radio Communications
Kitchen Ranges Logo
62 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
