Question about Riso RZ220 Duplicator
Problem on Riso GR1700
When the machine runs out of ink it did not recognize it, the copy is faded so I
changed the cartridge. I found out that the ink pump is not working.
  • Anonymous Mar 24, 2014
    replaced finished ink cartridge with several new ones but machine showing red lights on Ink and 2,i.e. showing like ink cartridge is not inserted
  • 318 Answers
Sometimes it is a one way pully inside the drum that is slipping.This is a mission to repair.
If you want to try it let me know.
Posted on Oct 30, 2008
D04-561 riso error code
It is not recognizing your ink cartridge. Try another tube of ink. Otherwise you may need to reprogram the drum.
PrntNow.com
Apr 19, 2013 | Riso RZ220 Duplicator
Error d-04 534
D04-534 means incorrect ink cartridge set. This could be caused either a) it IS the incorrect ink cartridge, or b) the RF tag that is struck to the end of the ink bottle is damaged. Try a new ink bottle.
Make sure to use RISO ink designed and made specific for same machine
Feb 25, 2013 | Riso RZ220 Duplicator
Can you use Riso GR1700 drums in a GR2700 or GR2710 machine? If so, is the ink also interchangeable?
The masters and ink should work. Cannot remember if the drum does. Put in the duplicator it will either fit or it won't. It will not damage the machine unless you try to force it in. If compatible it will slide right in and the machine will recognize it when you close the front door.
Mar 09, 2011 | Riso Office Equipment & Supplies
Riso rz230 aw has error codes d-04 -534
riso mz series has error codes D04-534 and D44-538
Jan 06, 2010 | Riso RZ220 Duplicator
Error Code -534 on my Riso RZ 390. Drum is stuck in machine and won't release.
Make sure to use RISO ink designed and made specific for an RZ230.
Jan 03, 2010 | Riso RZ390 Duplicator
E11 on riso gr 1700
When machine displayed E-11 it’s interrupted the operation.
Its means Pressure Control Motor Lock –
If the Pressure centering sensor does not detected on & off within 5 seconds from the start of the machine.
This problem is the engine of pressure, this is located by uncovering the back, more or less in the middle and bottom, there is a small motor that is attached by screw(s). When the machine is turned on its intial position should be detected and if not , the sensor can be bad or the starting position is dirty or broken cable, or motor cables are bad, inspect them, reset the code and turn the machine off and back on.
Dec 21, 2008 | Riso RZ220 Duplicator
Riso
probably needs a new adf stripper pad.. the first little rubber pad on the bottem of the inside of the adf
Aug 11, 2008 | Riso RZ220 Duplicator
Faded left hand copies
Pleas check that you inserted the K toner correctly, check, that transfer belt and/or drum cartridge is installed correctli. also check that 2transfer roller, its one big black roller.
Jan 23, 2008 | Konica Minolta magicolor 2400 Laser...
260 people viewed this question
Top Riso Office Equipment & Supplies Experts
Marius Chiriac
paulfvincent
Adorjani Laszlo
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
