Question about Briggs & Stratton 11HP 6200W Es Generator
Briggs & Stratton Burnt Brushes
I have a Briggs & Stratton EXL8000 generator. I keep having to replace the brushes. The "furthest in" brush (black wire) is always broken and it appears that the casing for the brush melts. What could be the problem?
Sometimes it will work for a month. Other times a few days and even less.
I did find out that the inner slip ring was worn down. Still unknown why and the repair tech we took it to twice just replaced the brushes and never looked at the slip rings.
My solution, which has worked for over two months now (knock on wood) is as follows:
The slip ring on this unit can only be replaced by replacing the whole rotor assembly. I looked at the width of the brushes and the width of slip rings. The slip rings are twice as big as a brush. The solution was to move the brushes outward by one brush length. In order to do that, I had to turn the brush assembly around because of the extra plastic on the unit and space it out one brush length. Note: Still hook the wires as if the brush assembly was not turned around.
I used an old brush assembly and cut the two areas where the screws go through to make my spacers and it works perfectly.
Posted on Dec 03, 2008
  • 169 Answers
Are you running something that has a high startup current? A well pump, air conditioner, air compressor, etc.
All of these things draw more than the rated power from your generator for a little while, then settle down and draw the regular rated power they have on the dataplate. This higher level of power is called the surge rating of the generator ( think the EXL8000 is something like 8250 watts for 30 seconds, check your manual) - if you regularly go over the surge rating you'll burn brushes, mess up slip rings, and potentialy kill a voltage regulator once in a while.
When we calculate how large a generator to use for an emergency backup system we add up all of the currents required by all of the things that have to run, then we calculate the maximum surge power for all the loads that have this requirement. We try and get a generator that will supply the "regular" load at 80% of it's rated capacity and still be able to handle the expected surge load. Sometimes we have to use a larger generator than needed for the regular load to get the surge load to be OK.
So you might need to trade up to the 10Kw Briggs to handle your load.
Carl
Need wiring diagram,from alternator to plug-ins for briggs & Stratton (3500) Elite series Model # 030208-0
No wiring diagram available from Briggs. Try re-magnetizing the rotor. No AVR or Capacitor listed in the parts list.
Disconnect the wires to brushes ( pay attention to the order) and apply 12vdc to brushes. Positive goes to brush closest to the bearing. Start the generator and check for output. If output is normal run the unit a few minutes to ensure re-magnetization then shut down normally. After shut down disconnect the 12 vdc source and re-install the previous disconnected wires. Now re start the generator and test for output should be okay provide there is no problems with the alternator. If no output during the above re-magnetization then your rotor windings my burned out.
Oct 10, 2014 | Briggs & Stratton Gas Powered 3500-4375...
Need help with diagnosing generator not producing power
may be a bad breaker or a shorted wiring problem. not generating any power, I would ck. the brushes inside the generator.
May 19, 2013 | Briggs & Stratton Power Products 5,550...
Briggs and stratton 8000 watts generator, the output of the 120 is only 102. How do I adjust the output?
Voltage is adjusted by increasing rpm of engine. Use meter with Hz setting and try to adjust to 60 cycles and check voltage to be at about 115-120. If engine is turning 3600rpm/60 cycles and voltage is very low, then problem is most likely with brushes/ commutator rings, or voltage regulator. Some voltage regulators have an adjustment screw to bring voltage up/down (adjust to proper rpm/cycles first). Good luck
Sep 09, 2010 | Briggs & Stratton Electrical Supplies
Remove motor from generator
aramature must be removed to get to the mounting plate it will slide out off case loosen long bolt in center of armature hold armature and hit bolt briskley will pop off be careful putting arm back may be 2 brushes inside have a helper hold brushes back
Jul 30, 2010 | Briggs & Stratton Briggs and Stratton...
I had it repaired about a month ago. it needed brushes. and now today it will run but not put no currant out put so it probaly the same thing. But where can i just buy the brushes myself. cant find...
Try starter / alternator rebuild shops. NAPA auto parts sometimes carries a small selection as well.
If you just had brushes put in a month ago, problem likely lies somewhere else. I have several hundred hours on OEM factory brushes on most of my generators, and no problems. Some sets have brushes that have outlasted the engine. Something else is going on.
Dec 25, 2009 | Briggs & Stratton 6200 Watt Electric Start...
Replaced new brushes on generator how do you charge system up with 9 volt battery ??
That is called 'flashing the field' Give me the make and model and I can help you
Aug 31, 2009 | Briggs & Stratton Electrical Supplies
I have a Briggs & Stratton Generator 5550Watt model 030253 That is showing an output of only 4.6 Volts at the pannel. Suggestions???
Check to see if this unit has brushes and rings. If it does, then make sure that the brushes are making a good contact on the rings. If the contact is good, then your voltage regulator could be bad. This would require more troubleshooting.
May 04, 2009 | Briggs & Stratton Power Products 5,550...
Briggs & Stratton 11HP 6200W Es Generator Logo
742 people viewed this question
Top Briggs & Stratton Electrical Supplies Experts
John Trevino
Falcon52
Level 1 Expert
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
