Question about Garmin n vi 360 GPS Receiver
Reboot the Nuvi 360 to "Mass Storage Mode"
I have Garmin Nuvi 360
I use Mapsource V6.13.7 to make gmapsupp.img from Beijing map to Thumb drive.
Then I use Windows Explorer to copy file gmapsupp.img to my Nuvi 360.
I made mistake, instead of copying the file gmapsupp.img from Thumb drive to "SD card:\garmin", I copy the file gmapsupp.img to
"Nuvi 360:\garmin".
Now it will not boot up.
When Power ON it come on and said "loading maps..." on the bottom of the screen, then a blue horizontal bar appears and starts to fill with "Green color" from left to right then turns off.
I try to reboot by "Maintenance mode" and "Pre-Boot Mode" to erase all user data and that didn’t work either.
Please advise me how to boot the Nuvi to "Mass Storage Mode" so I can delete the file gmapsupp.img in "Nuvi 360:\garmin" directory.
Best regards
  • 2 more comments
  • tqp00 Sep 30, 2008
    Thank for your solution, but it does not work.
    1. I Connect Nuvi360 to PC vis USB Cable.
    It starts to boot up, and hangs up at
    "Loading Maps..." screen.
    2. The Nuvi360 Power Switch does not have (LOCK Position)
    3. The "Safely Remove Hardware" icon in system Tray on PC (Lower Right) never appears, because the Nuvi360 hung up.
    Thanks Ajkill for your solution, but it does not work.
    I follow your solution from step 1 to step 6 and the Nuvi360 hung up
    at "Loading Maps..." screen.
    Also I try to reboot by "Maintenance mode" and "Pre-Boot Mode" to erase all user data and that didn?t work either.
    Thanks Techgyrus for your solution, but it does not work.
    The Nuvi360 power switch does not have locked position (to the right).
    So I can not follow your solution.
    Thanks eagle338 for your 2 procedures, but it does not work.
    I follow both of your procedures and
    1. Nuvi360 hung up at "Loading Maps.." screen in procedure 1.
    2. Nuvi360 turn off ater "Loading Maps.." screen in procedure 2.
    New Friend:
  • 161 Answers
If none of the other things work....i belive the solution is to send it to garmin and have them reprogram it.....it really stinks but im pretty sure that the only fix if the other ideas dont work...gps systems are hard to work with....they make things difficult. they probably will charge you an arm and a leg for the service...it might even be better just to buy a newer unit.
Posted on Sep 30, 2008
  • 4,889 Answers
Try these two reset procedures
Procedure 1:
1)disconnect nuvi from external power
2)Flip up GPS antenna
3)Press the reset button
4)Connect nuvi to power source. The nuvi should turn back on and operate normally
procedure 2:
1)Hold your finger on the upper-right corner of the nuvi's screen while you turn it on. keep your finger until the pop-up window appears
2)Touch YES. All factory settings are restored. Your recent selections and audio bookmarks are also deleted
    Master:
  • 479 Answers
Here's how you can SAFELY use your GPS device while plugged into a USB cable. This works on the 7xx series, your mileage may vary on other series.
1. Plug your USB computer cable into the Nuvi. The Nuvi can either be on or off when you do this.
2. Wait for the Nuvi to go into USB mode and your computer to recognize the Nuvi.
3. Slide the power switch to the locked position (to the right).
4. Now safely remove the hardware from your computer. On Windows XP, you click the "Safely Remove Hardware" icon. Not sure of the process on Vista.
5. A message will pop up saying it is safe to remove your hardware. Do NOT unplug the Nuvi. The Nuvi will reboot on its own.
6. Once the Nuvi has rebooted, slide the power switch from the locked position to the ON position (center).
Your Nuvi is now in GPS mode and can be used normally.
OR
How to use a USB power adapter (Apple I-Pod, I-Phone, etc). This also works with any USB, to be used as a power source (Dose not require 18K, Pin-X wiring.)…
1) Set power switch to “lock.”
2) Plug-in a standard Mini-B-USB cable.
3) Let Nuvi complete booting as a, “mass storage” unit (green bar take longer than normal).
4) Once done booting, disconnect, USB cable (leave unit in lock).
5) Just as Nuvi starts to boot, plug USB cable back in. Once Nuvi has finished booting in GPS mode, move the power switch to “normal,” (operate) and it’s ready to use.
6) Done!
The Bad news, if you loose power, it will reboot as a “mass storage” unit (green bar take longer…) And, it draws 0.22A (220mA at 13.6Vdc) with or with out the GPS simulator, lock-on, etc…
DO NOT Disconnect power while the Nuvi is booting to, “mass storage” mode!
If Nuvi locks-up, acts like its been smoked, wont power on, and it is fully charged, plug in the USB power cord (that has power), hold power switch in the “ON” position for at least 15 Seconds, and release…
    Genius:
  • 2,035 Answers
  1. Start with the unit OFF and unplugged from thr power source.
  2. Use your index finger to press and hold the top right corner of the touch screen.
  3. Power the unit ON while continuing to press and hold your finger to the top right corner of the screen.
  4. After the unit powers ON, you will see the message: Do you really want to erase all user data?
  5. When this message displays, remove your finger from the top right of the screen and touch Yes.
  6. The unit will now go through the Reset.
  7. Follow the onscreen instructions to set up your nuvi.
    Genius:
  • 3,422 Answers
1. Connect Nuvi3xx to PC vis USB Cable for 7xx to go into
mass storage mode.
2. Slide Power Switch to the right (LOCK Position)
3. Click the "Safely Remove Hardware" icon in system
4. Click on "Safely remove USB Mass Storage Device -
Drives(x:and y:)" x: = mass storage for the 3xx and y: = the
SD card if one is installed
5. WAIT for 3xx to Boot UP.
6. After 360 Boots UP slide power switch to center
position
Garmin Nuvi 1350 showing on screen "no map data available"
Shut off the nuvi.
Remove any memory card (if equipped) from your nuvi.
Plug the GPS into your computer via USB cable.
Open the Garmin "drive" icon in "My Computer"
Navigate to the x:/Garmin directory or "folder" (where "x:" is the drive letter assigned to your Garmin). Locate either map files set(s) named: gmapsupp.img or gmapprom.img.
Some units store map files in the hidden x:/.System directory instead. To view the .System folder and contents, you must direct your computer to display both the "system" and "hidden" files.
If you lack large files named either gmapsupp.img or gmapprom.img (about 1 GB or more); your maps are missing from the internal memory of the nuvi and will need to be reloaded.
If you pulled a memory card above, reinsert it and check the directories for the same gmapsupp.img or gmapprom.img files. If they're not present there, the maps should be reloaded.
I hope this helps
Sep 15, 2011 | Garmin nuvi 1350 Car GPS Receiver
Gps has lost its maps, screen says can't unlock maps
There several reasons you may receive the message Can't Unlock Maps on your nuvi or zumo device.
  • Can you press OK and get to the Where To/View map screen?
  • Did you load maps to the unit using the MapSource or MapInstall program?
  • Did you load maps to an SD data card?
If one of the points above applies to you, please follow the steps below to clear the Can't Unlock Maps message:
  1. Remove SD card from unit, if applicable.
  2. Plug the unit into your computer with a compatible USB cable.
  3. Open MyComputer/Computer icon. (Mac users skip this step.)
  4. Right-Click on the Garmin drive and select Open. (Mac users can locate the Garmin drive mounted on the Desktop.)
  5. Open the Garmin folder.1
  6. Locate a file named gmapsupp.img
  7. Right-Click and delete file named gmapsupp.img
  8. Safely disconnect your unit from your computer to see if the Can't Unlock Maps message is gone.
1. Nuvi 1100/1200/1300/1400/1600/3700 and Zumo 665 users will open the Map folder instead.
*If the gmapsupp.img file does not appear in the Garmin folder, please create an unlock file for device.
Nov 28, 2010 | Garmin Nuvi 265W GPS Receiver
Garmin Nuvi 255w won't start up. tries loading maps and then goes in a continuous circle. acts if not charging. tried reseting and charging with wall charger and car charger
You should try to manually delete the maps (after a backup ) on the device , power cycle and retry sending the maps from MapSource or the Software CD from the manufacturer. The map is a single folder onto the device (eg. gmapsupp.img)
May 25, 2010 | Garmin nuvi 255W GPS Receiver
I have a nuvi 200 and updated my maps online. Now, It says cannot unlock maps. What do I do?
I googled an answer. I went to "my computer" and double clicked on the device file (mass storage system), there you will see a folder named "Garmin". In this folder look for the file named gmapsupp.img , right click on this file and delete as this file is causing the maps to lock.
Jan 21, 2010 | Garmin nuvi 200W GPS
Updating Garmin C330
TO GET 2009 MAP IS NOT EASY! Software update is, from the Garmin site you can update software easily BUT THE MAP... you must purchase for $69.99 OR if you're a technical person who knows the following instructions you can save some $$$
search torrent for
"CNNANT2009-1 MapID 396"
under torrent sites, you know what you're doing.
Use these instructions if you have downloaded it.
Download these first:
cgpsmapper.exe
gmaptool.exe
MapSetToolKit.exe
and MapSource where u can directly get from Garmin site
http://www8.garmin.com/support/download_details.jsp?id=209
Create these folders on the root drive: (I will choose one to make things easier, you can change)
C:/grmtmp
C:/grmtmp/extract
Connect your GPS to USB, and BACKUP then remove
X:/Garmin/gmapprom.img and gmapprom.sum (may be gmapsupp.[img+sum]) approx. 1GB
1) Copy gmapsupp.img from this torrent to C:/grmtmp;
2) Extract gmaptool.exe, cgpsmapper.exe and mapsettoolkit.exe to C:/grmtmp/extract
3) Open a command prompt, and navigate to the extract folder ("cd/grmtmp/extract")
4) Run "gmaptool -S ../gmapsupp.img" Note that is -(CAPITAL S), lower case s is for different option
5) The above will extract files, you will get some warnings about 10 degrees. Ignore them.
6) Run "cgpsmapper mapset00.mp"
7) Run "MapSetToolKit"
8) In MapSetToolKit, press "Install A Existing Mapset"
8a) TDB File: "mapset00.tdb
8b) Overview map: "mapset00.img"
8c) Registry name: "WhateverYouWant" (I did "Grm2009.1Update")
8d) Leave TYP files blank, and hit "Install"
9) Close MapSetToolKit and run MapSource
10) Ignore any requests to unlock map, not ready yet.
11) Go to "Utilities-Get Unit ID" and Find Device with your GPS plugged in USB. Write down Unit ID.
12) Run Garmin Unlock Utility, Enter that Unit ID at the top.
13) Select under "Select Map Product"
14) Ender 396 for the FID/MapID, use the Generate button to get 25char code.
15) In MapSource go to "Utilities-Manage Map Products"
16) Go to "Unlock Regions" Tab, and hit "Add...", enter 25char code, comment optional
17) Now on the main MapSource screen, type 'm' to enable map tool.
18) You should see a large white rectangle, with rectangle outlines (these represent NA maps)
19) Click and drag to select them all, you can click "Map Set Name" if wanted.
20) Click the "Send to Device" button. Wait an hour. Enjoy.
Feb 26, 2009 | Garmin StreetPilot C330 GPS Receiver
Backup Streetpilot C330
HOW TO INSTALL CN NA 2009NT ON A STREETPILOT C330
The CN NA 2009 NT mapset is too large to be installed in the C330 without putting part of it onto an SD card. My recommendation is to use MapSource to build an image file containing the lower 49 states, PR & the USVI and upload it into the internal memory as a new 'gmapprom.img' file, and then build a new 'gmapsupp.img' file for an SD card containing Alaska & Canada.
Start the process by using MapSource to create a new 'gmapsupp.img' file, choosing the lower 49 states plus PR/USVI. Make sure that the total mapset size is no more than 975MB (930MiB) MAXIMUM. Anything that's very much larger will cause the installation to fail, due to insufficient internal memory. Note: Even though MapSource lists the mapset size in "MB", it actually measures it in "MiB". DO NOT EXCEED 930.0 MAPSET SIZE AS LISTED IN MAPSOURCE! (Can you get away with "just a little bit more"? Yes, you can, but why push it when you can simply put the rest on an SD card? Otherwise, you'll spend 40 minutes uploading it to your C330, only to have it fail at 99%. No fun... )
After selecting these maps tiles, choose 'Transfer > Send to Device...', but do NOT select your C330 as the destination for your new 'gmapsupp.img' file; instead, choose to send it to a blank 1GB (or larger) SD card plugged into one of your USB ports by way of an appropriate adapter (or to the 'C:\Garmin\' folder on your primary hard drive if you're running a specially-modified MapSource executable). MapSource will automatically create a 'Garmin' folder on your SD card and create your new 'gmapsupp.img' file within it.
Once you've successfully accomplished this task, copy the new 'gmapsupp.img' file to your hard drive's 'C:\Garmin\' folder (unless that's where you sent it in the first place, as noted above), then re-name it 'gmapprom.img'.
Next, repeat the process, selecting Alaska plus all Canadian provinces instead. Do NOT select any of the U.S. map tiles you selected the first time around. Capiche? This time, however, after creating the new 'gmapsupp.img' file on your SD card, do NOT copy it to your hard drive and do NOT re-name it. Just plug your SD card into your C330.
Finally, we're almost ready to upload the first file you created -- now called 'gmapprom.img' -- into your C330. First, we have to make sure you have a copy of Garmin's WebUpdater package installed. Open your 'C:\Garmin\' folder. Is there a 'WebUpdater' folder there? Yes? Great! Look inside and you should see a file named 'WebUpdater.exe'. If you've got it, you're almost there.
You don't have WebUpdater installed? Go get it and install it; it's a free download from Garmin. I'm using Windows XP; be sure to get the Windows version that's right for you. (To the best of my knowledge, this procedure does not work on a Mac. Sorry... ) http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Now that you've got it installed, do the following:
- Right-click on an unoccupied area of your Windows Desktop; when the menu pops up, choose 'New', then 'Text Document'.
- Double-click this document; this will open up a brand new blank document in NotePad (or whichever text editor you've chosen).
- Copy and paste the following line of text into it...
C:\Garmin\WebUpdater\WebUpdater.exe /upload_file rgn=49 path=C:\Garmin\gmapprom.img -autorun usb /i
- Select 'File > Save' then 'File > Exit'.
- Re-name the file to 'C330_Map_Update.BAT'
- With the C330 connected to the PC by USB (your drivers have already been installed previously, yes???), double-click on your new 'C330_Map_Update.BAT' file.
- Sit and watch as the WebUpdater application opens up a command-line window and copies your new 'gmapprom.img' mapset into your C330!
- It will take approximately 35-40 minutes if all goes well.
-Don't forget, you'll need to have previously entered your 25-character unlock code into MapSource. That unlock code must be specific to your C330; just because your Nuvi's unlock code allows you to create mapsets in MapSource doesn't mean that those mapsets will work in your C330!
Jan 15, 2009 | Garmin StreetPilot C330 GPS Receiver
NUVI 310
you will need to erase a file from the units memory. Connect your GPS system to your computer; go to start then ‘My Computer’, and double click on your device file (mass storage system), there you will see a folder named ‘Garmin’. In this folder are several different files, look for file named gmapsupp.img. Right hand click on this file and delete as this file is causing the maps to lock.
Dec 09, 2008 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 610 No Maps
Do a hard reset on the device. Download Garmin Express and install it to your PC. Connect your device to your PC. Garmin Express will identify it and allow you to install all the maps and software that the device has a subscription to.
May 01, 2017 | Garmin Nuvi 610 GPS Receiver
Vista HCX Micro SD Problem
Vista only recognize gmapsupp.img files.Go to www.mapwel.biz/down.htm take MapUpload software then from mapsource select maps you want to transfer to sd card.Or directly from Mapsource select Transfer and send selected map to sd card.Maps must be unlocked.
Aug 19, 2008 | Garmin eTrex Vista GPS Receiver
Garmin nuvi 250 mapsource
Verify that you have the correct basemap for the country that you are in. There are two maps inside a new Garmin. The basemap which shows all the major highways and mapsource which shows all the street. If you don't have the correct basemap try changing 'Navigation' Advoidance to avoid highways and Toll Roads.
Sep 25, 2007 | Garmin nuvi 350 GPS Receiver
Garmin n vi 360 GPS Receiver Logo
1,069 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
