Question about BenQ Computers & Internet
Acer / BenQ CRT analogue VGA cable reqd.
Dear Sir, I am looking for a SVGA analogue cable originally from a CRT Acer V771, I require the entire cable that has the Acer / Benq 1 X 15 pin socket that connects internally fairly simply. Obviously I also need the 15 pin D-sub connector and while a new cable would be ideal, it's OK if you have only a s/h cable off a similar internal connecting CRT monitor cable from Acer or BenQ models of which there are quite a few with the identical connector. I had a kid allow a door to slam onto the end of the cable of my spare monitor, which near severed it, while it in several years old since purchase it's unfortunately nearly new with very little use and a shame to scrap it when it works fine. Thanks David J York.
5 Suggested Answers
  • 300 Answers
SOURCE: "No signal detected" when LCD connected with DVI-D Cable
Thank you for providing your configuration details.
You have failed to specify wheather or not your LCD Display is under Warrenty.
Perhaps these simple trouble shooting procedures will get the job done.
1. use the DVI to VGA adaptor that came with your card
Plug in a regular CRT monitor to the Primary Display Output Port using the DVI to VGA adaptor
( either port can be designated as the primary by you )
I like to use the Port nearest to the motherboard as the Primary
2. plug in the your LCD monitor on Secondary Display port using your DVI cable
At this point you should be able to see your desktop on the Primary CRT Display
3. Go to the display properties and use the Nvidia Dual Display Setup Wizard
set both desktops to CLONED at a resolution of 1024x768 and set the refresh to 60Hz
which is default for most LCD displays , some have higher refresh rates , consult your user manuel
If the display resolution and refresh are set incorrectly for your CRT or LCD you will see
Signal Out of Range ( if the display has the ability to display that error message )
At this stage both displays should be showing a Windows Desktop
If you now see your desktop on both displays , you can now put the LCD on the Primary Port
No Signal Detected ( this means the display device is not receiving a signal )
If your LCD display is still displaying the error message
"No Signal Detected" after performing the trouble shooting proceedures
You may need to read the user manuel about how to enable DVI signal input.
If you are certan you have done everything correctly but still see only "No Signal Detected"
Your LCD Display may need replacement
Loch Hime :-)
Posted on Sep 14, 2008
  • 107 Answers
SOURCE: benq t905 monitor blank
Fist check the fuse on the inverter board if it is blown replace it if not you need another inverter board as it has fried. But I looked and was unable to find a new/replacement inverter online so I wish you the best of luck
Posted on Dec 08, 2008
SOURCE: benq 937s monitor stopped working. Green light on but blank scree
I have the same problem and have gotten it fixed twice. Going to be my third time now. Every time, they replace a costly part. I've submitted multiple emails during it's warranty through the tech support form at BenQ's official website and never once gotten a reply.
To solve this problem, pay to have it repaired and auction it in a yard sale to cover the cost. Then never buy a BenQ again.
~ Northkin
Posted on Feb 12, 2010
  • 732 Answers
SOURCE: Benq E2200HD No Cable Connected!
mnk1001, Possible Failure of internal "switch-mode-power-supply"/ "CCFL inverter supply" of E2200HD. Will need to investigate to see if SMPS is in emergency shutdown mode. Please post back if you find out root cause of failure. 12fixlouie
Posted on Apr 11, 2010
Dear Sir/Madam, I have an Acer Aspire 5735-642G25Mn laptop and I don't know how to connect it to my TV (Sony KDL55NX810). Could you please advise me on how to do this. Thank you. Regards, Erik
The video output on your laptop uses a VGA port, and the video in on the tv uses HDMI. You cannot plug one directly into the other, you will need to buy a special VGA to HDMI converter (NOT just a plain VGA to HDMI cable, you need a converter to change the analogue VGA signal to a digital HDMI one). Something like this:
Naturally you will also need a VGA and an HDMI cable to connect everything up.
Jun 01, 2011 | Acer Tablets & eReaders
The cable has been cut off of my acer monitor (v771-m) I took the back off the monitor and want to fit another cable from a different make, can someone tell me which colour wires go to which pin on the...
Have you already removed the wire from the back of the monitor or have you already replaced the wire and now want to reconnect the 15 pin D-type plug?
If its just the D-type you want to reconnect then have a look here:
Its not the easiest diagram to follow but all you need to remember is that some wires are used and some are not.
If you dont have a particular colour of wire then it probably isnt used.
I hope that helps...
May 12, 2009 | Acer Value V771 (White) 17 in.CRT...
How to watch laptop in my Sony Bravia?
you need to clone the acer screen using ati utility
Jan 26, 2009 | Televison & Video
Can you connect a acer aspire one to the tv via hdmi
You cannot connect your acer aspire one via HDMI as its not having HDMI port. But you can connect via VGA cable and most of the TV supporting HDMI will also definitely support VGA input.
Jan 10, 2009 | Nokia IP 350 Firewall
Benq v772 CRT show only Blue and Green color
It has to be either a cable or an IC issue. Get your cable checked first (VGA cable)
Oct 01, 2007 | BenQ Value V772 17" CRT Monitor
Toshiba laptop won't work with new optoma projector
-toggle the laptop display using the FN keys and F5 I believe. -lower laptop resolution to 800 x 600 -look in laptop display properties for lcd or external display settings, see if it (external crt) has to be enabled on the laptop first.
Aug 26, 2007 | Optoma Projector Multimedia Projector
Computers & Internet Logo
Top BenQ Computers & Internet Experts
JP Services
JP Services
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
