ADJUST THE SPEED SENSOR:
Make sure the sensor is as close as possible to the pulley withouttouching it. You will see a magneton the face of the pulley; make sure the sensor is aligned with themagnet. There is a screw thatholds the sensor in place that needs to be loosened to adjust thesensor. Re-tighten the screw whenfinished.
ADJUST TOO: 1/8" THE SENSOR SWITCH SEE THE DIAGRAM.
See the block diagram for any treadmills. how the main controller board has the aprox 90% of function. You must finally test the Main C.B.
Sincerely.
E.CUADRA
