Question about Delstar DS 31024 MP3 Player
Starting After replacing the old battery with a new one, the display says starting and nothing else happens.
  • 4 more comments
  • Anonymous Oct 05, 2008
    no matter what i do every time i cut it on it just says starting
  • tigerlill Oct 10, 2008
    after replacing my mp3 with a new battery it just keeps saying "starting"
  • gswyers Oct 13, 2008
    My unit starts and the menus come up, but I can't access my music. It will play thru my computer.
    Greg
  • baxter-james Oct 21, 2008
    I replaced the old battery in my unit, and now it just says starting and won't do anything else.
  • Anonymous Oct 24, 2008
    same problem....starting.....
  • Anonymous Nov 25, 2008
    Mp3 player works when plugged into my computer, but when I try to turn it on nothing happens.
Zzzzzzzzzzzzzzzzzzzzzzzzzzzzzz comes up when i am riping music from computer
Posted on Oct 04, 2008
Battery keeps going dead
Might be the alternator.
Jan 30, 2014 | 2000 Chevrolet Impala
I cannot get the outside temperature to show on the inside monitor
Try the usual fix by removing batteries and reinstalling/replacing batteries starting with the outside unit. Wait for as long as 10 minutes for the ouside temperature to be displayed on the indoor unit. If nothing happens after 10 minutes, the outside unit may have failed.
Oct 20, 2013 | Oregon Scientific Bar806hga Helios Solar...
Audi a3 no start
How do you know the battery is fine? Sure sounds like you have a weak battery- the symptoms are all the electrical bits work- except starting the car. All your electrical systems don't need much current, but your starter needs a lot. If your battery isn't fresh then your car won't start, but everything else will appear to work. You can test the battery by looking at voltage across the terminals when you try to start the car, if it's less than 12 volts your battery needs to be replaced. If your battery is more than 5 years old it should be replaced anyway. Good luck, let us know how it goes.
May 13, 2013 | Audi A3 Cars & Trucks
Treadmill will not turn on - nothing on display, and only fan comes on.
please adjust the Reed swithc,test for open or faulty. Clean it, Tight the connector very well.see the diagram attached.
2) Tight the ribbon cable for keypads inside the display board.
3) Replace the old batteries and put and new one, with the same marks, and o.k polarity, clean the contacts batteries very well witch c. cleaners.
God bless you
Jan 09, 2013 | Proform 400 Gi Treadmill Walking Belt
My VW golf TDi won't start since I changed my battery. It started fine for three days and now there is absolutely nothing there when I turn the key not even a click. Please help
1. Do all lights, accessories, central locking system etc in the car all operate normally.
2. Have you tested to see if the car starts when you try jump starting from another vehicle.
3. What warning lights were displaying on the vehicle a day or 2 before you had the problem.
4. Were you having the same starting problems with the old battery that you have just replaced.
Dec 27, 2012 | Cars & Trucks
Car was rinning perfect. One day it would not start. there was nothing, no clicking ,bell and guages were working. Jump start was nothing. Installed a new battery there was nothing. Went bact back 2 hours...
It sounds like you have an issue with your PassLock security system. I had the same with my 2002 Impala. Key turns OK, but won't start, won't crank. Wait 20-30 minutes, and car starts normally. There is usually a clue from the Battery and Security lights.
The problem starting to happen once a month, and eventually 1-2 times a week.
There are several write-ups on this problem for several GM cars for 2000-2006(?). Search this website, and search the web.
The official solution is to replace the ignition switch. The best solution is to bypass the Pass Lock system. I went ahead and did a full bypass, which involves cutting wires and adding resistors to the ignition circuit. I have not had a problem since.
Aug 19, 2011 | 2004 Chevrolet Impala
New starter new battery still wont start last
Very likely the new battery is defective - it happens. If you have a know good new battery, then also connect a jumper from the battery negative to the block just to be sure its not a defective or loose ground cable.
Aug 05, 2009 | 1986 Chevrolet Suburban
2003 GMC Intermittent Starting Problem
Check the other end of battery cables, may have good connection at battery but not at starter or ground. (Always check ground first, often a source of problems.)
Next time it happens, try hooking up jumper cables and see if the intrument panel lights up.
Also, check for loose fuse, not properly seated fuse. And cables to fuse block. (That model may have more than one fuse block)
Jul 27, 2009 | 2003 GMC Envoy Xl
2000 monte carlo starting problems
Most likely, this is your starter bendix going bad. Time for a new starter. Hope this helps. Good luck.
Aug 25, 2008 | 2000 Chevrolet Monte Carlo
Delstar DS 31024 MP3 Player Logo
Top Delstar Audio Players & Recorders Experts
steve cannon
Level 1 Expert
Lori
Level 1 Expert
Mister Danger
Are you a Delstar Audio Player and Recorder Expert? Answer questions, earn points and help others
