Where to hookup front panel (PIII-3754LMR - )
Can you maybe tell me where YOUR front panel pins, pin into the mobo
  • 33 Answers
Hello!
In this image USB connectors for a fron pannel header are marked as Q and R, and the audio connector for a fron pannel is marked U
Hope this helps!
Posted on Oct 02, 2008
I can't find where the connections of the front panel are on the motherboard or where they go?
The eMachines T2893 desktop computer uses an Inte G845GVSR mobo. (MOtherBOard)
Intel Support>D845GVSR>Motherboard Manual,
(Intel's name - Product Guide),
http://www.intel.com/support/motherboards/desktop/d845gvsr/sb/cs-008823.htm
I would like you to left-click on the top file.
Click right on - Product Guide - PDF, in blue.
(File name underneath it is -
File Name: D845GVSR_Product Guide_English.pdf )
May take up to 30 seconds, before you see the first page.
(You will be staring at a blank screen until the first page comes up. The file is downloading in the background)
Took 5 seconds before I saw the first page, and an additional 12 to fully download, using a medium speed DSL connection.
The Front Panel header on the mobo is shown on Page 31. (C on the illustration. J9G1 on the mobo)
The Front Panel connections are on Page 32.
Barring that you cannot download this PDF file, or do not understand the manual, I will detail the Front Panel header connections.
Orienting the motherboard so we are both looking at it the same way;
The Processor is at the top, the ram memory slots are to the right side of the mobo, and the white PCI slots are to the bottom.
There are three PCI slots. The one closest to the Processor is PCI 1.
The one closest to the edge of the mobo is PCI 3.
To the far right of PCI 3 is the Front Panel header.
It's the header located closest to the Right side of the mobo, and the bottom edge, and is directly below the
CMOS battery.
There are two rows of pins.
Four across the top, Five across the bottom.
The top row of pins are numbered Evenly.
The bottom row of pins are numbered Odd.
Starting from the Left side of the mobo, going to the right, on the Top row,
Pins 2, 4, 6, and 8. (There is No 10)
Starting from the Left side of the mobo, going to the right, on the Bottom row,
Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the Harddrive Activity LED
If you have a wire with a + sign on it (Positive) it goes to Pin 1.
B) Pins 2 and 4 are for the Power On LED.
(Pin 2 to the Green LED lamp, Pin 4 to the Yellow LED lamp, if applicable with your computer)
C) Pins 5 and 7 are for a Reset switch. (If applicable)
(Pin 5 is Ground)
D) Pins 6 and 8 are for the Power On switch.
(Pin 8 is Ground)
E) Pin 9 is for the +5 Volt power.
(You are following Anti-Static precautions, right?)
Have any questions just post in a Comment.
(Believe upper right of your page)
Jun 13, 2010 | E-Machines T2893 PC Desktop
Asus P5LP LE Emery motherboard MANUAL
does your case have set pin slot sets your case manual should tell how to install your motherboard type hope this helps
Jan 04, 2010 | ASUS Computers & Internet
First time building power hookups on mobo
the general guidline is that if your power supply has the extra cables and your mobo can support them, then plug them in... those extra 4 wires in your long power strip will normally be used for grounding, so that's a must. check your mobo manual to see the exact specs. ... as for raid, wiki it man.
Jul 17, 2009 | ASUS P5WD2 Premium Motherboard
Foxconn LS36 mobo , front panel (34pin) connection DETAILS needed
Dell has never published the pin-outs of their proprietary ribbon connectors to the front panel
Jun 03, 2009 | Dell OptiPlex GX270 PC Desktop
Where to hookup front panel (PIII-3754LMR - AMPTRON)
Front Panel Connector The front panel header is where the connectors of hard disk drive activity lights, case speaker, reset button, power on/off button, computer power on light, and key lock, are connected to make them function smoothly. In the past days, users always have difficulty connecting the front panel due to a lack of standard location on the motherboard. Today, AOpen integrated all these disorder but essential front panel connectors into one 20-pin connector for easy usage. Connecting the front panel would no longer be the headache of installing motherboard anymore. Below is a view of this user-friendly front panel connector of AOpen motherboard.
please rate this post.
or donate on madridtelecom@gmail.com
Feb 08, 2009 | Intel Motherboard
(Just in case you don't see the image:
The connector is called J4
2-10 : Key Lock
1-7 : Speaker
13-14 : TB Led
15-16 : HDD - Led
17-18 : RST
19-20 : SPD - Led
21-22 : Power Switch
Best regards, hope it helps.
Eugenio
Oct 01, 2008 | Computers & Internet
check arrow hok up the procesor from where u see arrow after removing fan etc .
Sep 29, 2008 | Amptron PM-9100A Motherboard
Amptron motherboard
Hi...
Although there is a huge list, I have found a place where there IS a manual for that specific MB
http://www.motherboard.cz/map.htm
Let me know if this helps
~~Jasta~~
Computers & Internet Logo
106 people viewed this question
David Payne
David Payne
