Question about Maytag Refrigerators
Water/ice dispenser activates at will, selector panel locks up
Model MSD2354ARW. Several times lately the dispenser has activated by itself. Opening the freezer door stops this. Touch panel and dispenser lock up and the dispenser light stays on. Main board and solenoid have been changed, but problem exists.
  • 172 Answers
Hi jrupich,
There is only two things that can cause this problem. One would be the dispencer control board. Part #61003425
The other thing is a stuck or shorted dispencer switch
part #61005520
Since you say that you have already replaced the control, I would have to go with the switch, but in rare cases the new board installed in the dispencer can also be faulty. Some appliance techs will even sell you a used one and tell you it is new. You have to trust your repairman. Good luck to you and I hope this will FixYa. please dont forget to rate me.
Mike Anderson (Owner)
Anderson Appliance
(865)945-3808
Posted on Sep 30, 2008
MODEL XRSS267BB REPLACED WATER CARTRIDGE RESET CONTROL BOARD BUT STILL WATER AND ICE ARE DISPENSING TOGETHER ANY IDEA WHAT THE CAUSE MIGHT BE ????
thanks for providing a model number I know this answer is a little late but there's no easy way to tell you how to find a short circuit causing the dispenser and the ice auger and ice door to open and activate you have a short circuit in the dispenser control to resolve this problem sorry wish there was an easy answer
Appliance 911 Sea Breeze
Sep 21, 2015 | Refrigerators
Water dispenser doesn't work, side by side, model # GSS22JEPA BB
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
Mar 04, 2010 | GE Refrigerators
The outside door water does not work
Can I assume the ice and water are activated by two different switches? The ice switch activates the motor that dispenses ice. The water switch activates a solenoid that opens to dispense water. If you can, find the solenoid and make sure it's not stuck closed (tapping it with a screwdriver handles usually help persuade it a bit). I would tap the solenoid while pushing the water button. Listen for the solenoid to activate. If you can't activate the solenoid, find the switch and depress it with a small screwdriver. Usually, these switches are just simple little microswitches that need a little cleaning and coaxing
Feb 25, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Maytag MFI2266AEU Water and ice dispenser locked, control panel
Door Panel Locked
Press Door Alarm and Freezer "-" at the same time, then release Door Alarm but continue pressing Freezer "-". You will see PE _ _ _ _.
Press Freezer "-" until PE # # # # shows on the panel.
Using Freezer "+" to move cursor, Refrigerator "+" and "-" to change numbers, bring all numbers to "0". Press Freezer "-" until PE and numbers blink. Unplug refrigerator for 45 seconds, never beyond 1 minute or you'll have to start over.
Look inside refrigerator door and locate the serial sticker. To the right of the serial number is the CODE ####. Plug in your refrigerator.
Press Door Alarm and Freezer "-" at the same time, then release Door Alarm but continue to press Freezer "-". Using the same method as above, enter the four digit CODE number you found on the serial sticker. Press Freezer "-" until PE and numbers blink. You have just reset your panel. Unplug for 45 seconds. Plug in refrigerator and you should now have full use of your door panel.
This unit has a built in safety timer mechanism. If it dispenses water for two minutes, it assumes it is flooding your house and shuts the panel down. If you are filling a pitcher of water, just stop dispensing halfway through to reset the safety timer.
Feb 01, 2010 | Maytag MFI2266AE Side by Side Bottom...
Ge model gsl251frfbs side by side. Ice maker/water dispenser not working when activated. makes ice, just won't dispense ice or water through front door. don't hear motor activating.
I would check the door switch that turn the light on for freezer. When the door opens the switch changes to deactivate the controls on the dispenser panel and when shut should turn it back on. I will help you trace the problem because sometimes there is a broken connection from the dispenser panel to control board. Let me know, Sea Breeze
Dec 16, 2009 | GE Refrigerators
The refrigerator by itself activates the water or ice dispensing
could be the water valve or water switch (depense switch)
Apr 01, 2009 | Refrigerators
Ice and water won't come out dispenser
here is link to your owners manual subzero.com
and here are instructions for using the lock feature..
LOCK For Models 685 and 695, the lock feature is used to prevent unintended ice and water dispensing. When the dispenser is locked, all key pads on the glasswell are deactivated to allow cleaning or to prevent small children from using the dispenser. To activate the lock feature, hold down the LIGHT key pad on the glasswell until the key pad lights flash once and the red LOCK icon is illuminated (approximately five seconds). The lights will remain in the state they were in before the lock feature was activated. To deactivate the lock feature, hold down the LIGHT key pad until the key pad lights flash once and the red LOCK icon is no longer illuminated (approximately five seconds). The lights will remain in the state they were in before the lock feature was deactivated.
Thanks Peyton
Mar 02, 2009 | Sub-Zero 695/S Side by Side Refrigerator
Hotpoint Refridgerator HSS251FMBWW, Ice dispenser runs by itself
Hi! Hopefully the manual of a similar Hotpoint fridge witll help you. There may be not a unique reason of this problem. Seems that it might be a problem of a cube dispenser.
https://manualsbrain.com/en/manuals/820483/?page=32
Aug 09, 2017 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Ice dispenser comes on by itself.
you need to replace the dispenser selector board.
Sep 03, 2007 | Frigidaire FSC23F7D Side by Side...
Refrigerators Logo
161 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
